Blackbox tip.
As I've discovered yesterday ...... on your blackbox log a motor showing maxed out on your graph can also mean a desync occurred in that esc.
I'm using blheli_S dys xs30a escs and was having this issue.
Anyways I thought it was a good thing to share. So if you see a motor going to max it can also mean a desync.
first thing I would try is lower motor timing in ESC. But I have been hearing some desync issues with XS ESCs... what motors are you using?
Also try to update ESC firmware to the latest see if that helps.
  Help Help needed - blackbox file samples to finetune Flight time prediction model whiterabbit 1 235 25-Jul-2023, 12:20 AM
Last Post: whiterabbit
  Tip & Trick Another Banggood frustration and a tip for items on backorder SnowLeopardFPV 13 11,424 24-Jul-2019, 01:19 PM
  i-term stair step blackbox line?? nitro20% 6 1,480 18-Jan-2018, 01:51 PM
Last Post: Oscar
  Trouble understanding blackbox log w0_op 3 1,226 29-Dec-2017, 03:02 PM
Last Post: unseen
  PID's -> Knowing when it's too much or not enough on Blackbox log FlyinB 4 1,186 22-Oct-2017, 08:17 AM
Last Post: FlyinB
