Help needed - blackbox file samples to finetune Flight time prediction model
Hi all,
I'm building a neural network model for Betaflight to predict how much flight-time you have left.
Currently this only works in Betaflight if you calibrate your current meter and enter your battery capacity into Betaflight configurator (details here Calculated Flight time gives wrong calculation · Issue #7769 · betaflight/betaflight (github.com)
The good news: the preliminary NN model can predict quite well the remaining flight time
However, to train and tune the model, I would need many full-flight* blackbox data (BTFL_BLACKBOX_LOG_...BBL) from many different quads and setups
* important to have the data from 100% battery to all the way to 0-ish ("LAND NOW") so the model can learn to predict the unique LiPo discharge curve
If you happen to have such data lying around - or even better, if you want to wipe your blackbox now and do a full log during your next flight, save it then upload the BBL fiel somewhere (Dropbox, Google Drive), that would be a huge help to make this model more useful for everyone.
Many thanks  Heart
BUMP - HALP pls Smile
  random uncommanded yaw issue in flight? husafreak 30 981 16-Jan-2024, 05:32 AM
Last Post: husafreak
  Hang Time Question Bad Raven 15 577 06-Apr-2023, 02:06 PM
Last Post: mstc
  Flight Duration (or not) BadRaven 7 410 15-Feb-2023, 08:16 AM
Last Post: Lemonyleprosy
  Image transmission stopped during flight Snyfir 4 1,130 08-Feb-2023, 02:22 PM
  Component failure mid flight, Rob Axel 6 514 24-Jul-2021, 12:26 AM
Last Post: MrSolo
