Blackbox Logs PID Tuning help.
Hey guys. I have some blackbox logs that I would like you to look over. This is on luxfloat with P at 1.9 on pitch and roll and 3.5 on Yaw. I and D are at default values. They are too big to attach here in the forum so here is a dropbox link with my logs of today. https://www.dropbox.com/sh/a7d2259adew8j...Pd9Wa?dl=0
your D on roll and pitch definitely needs to come down. It is swamping the Pterm. drop it by about 2 on both axis and try again. Yaw looks ok and your gyro traces are pretty clean so not much noise getting to them. You could probably raise P on pitch by one or two points. But certainly drop the d term on roll and pitch down some. A copy and paste of your dump could b helpful.
I fly luxfloat too (but on betaflight) and generally yaw P is too high on stock. Most have to go to between 2 and 3. Are you on cleanflight? Maybe its not the same on cleanflight, im not sure on that.
Yea Dal75 is right you D term is very noise on both pitch and roll.
it would help if you could post your CLI command as well (use code button in editor)
I reckon you don't have your Dterm_cut_hz enable... set it to 60 see if it's better, if not set it to 40 should do it.
  Help Help needed - blackbox file samples to finetune Flight time prediction model whiterabbit 1 228 25-Jul-2023, 12:20 AM
Last Post: whiterabbit
  Rate tuning B4tn 3 399 24-May-2023, 05:02 PM
Last Post: Rob3ddd
  PID Tuning Guide Oscar 5 26,998 03-May-2023, 12:06 AM
  When an angry Kookaburra helps you sync your gyroflow logs ph2t 1 303 25-Apr-2023, 07:32 PM
Last Post: drumgod
  Help High Elevation Builds / Tuning blanco 1 551 21-Sep-2020, 03:26 AM
Last Post: blanco
