Threads: 11
Likes Received: 1 in 1 posts
0 Hello all, I am trying to understand how to use and work with the Little Yellow Tick Marks in the Ranges area of the MODES Tab, of Betaflight Configurator. I want to understand how to and where to move them.I qreatly appreciate any help I can receive.
soky157
Threads: 581
Likes Received: 8,919 in 6,599 posts
Likes Given: 1,425
786 The yellow tick mark is the current value of the channel. For a channel that is assigned to a 2-position switch the yellow tick mark will move from 1000 to the 2000 positions as you flip the switch to each of it's 2 positions, and for a 3-position switch the yellow tick mark will move from 1000 to the 1500 to the 2000 positions as you flip the switch to each of it's 3 positions. You just need to make sure that the yellow activation range bar spans the value(s) that you want the mode activated for. It's as simple as that.
Threads: 581
Likes Given: 1,425
786 Configuring the Modes tab is explained in the videos linked to below...
Threads: 11
0 Thank you SnowLeopardFPV so very much. You have helped ALOT in the past! Now I feel much more comfortable with the Tick Marks. Also, thanks for responding sooo quickly!
soky157
