07-Jan-2024, 11:10 AM
Hey guys!
I am relatively new to the sphere so please forgive me if my request here ist very uneducated.
I have a 7" quad that I used with the MATEK M10 chip and the GPS mate by ViFly.
All was wired correctly and setup well so that I can use it as rescue to home, if Failsafe stage 2 kicks in.
Now that I lost that gps module on a crash, I got myself the M10 module from GepRC (GEP M10 DQ).
As I connected it to my gps mate nothing seems to work. I have double and tripple checked, that my TX and RX are set correctly (crosswise) and decided to try it without the gps mate and had still no success so far.
It seems to me, that there is a problem with the resources since I use the Speedy Bee F405 V3 that has also a barometer (as soon as the M10 module is connected and restarted the barometer indication beside the gps in betaflight disappear).
I have found this from GepRC but could not find out where the sections in Betaflight are, which they are referring to.
https://geprc.com/wp-content/uploads/202...orking.pdf
Many thanks for your help so far!
This is my CLI Dump:
# dump all
# Betaflight / STM32F405 (S405) 4.4.2 Jun 1 2023 / 03:55:37 (23d066d08) MSP API: 1.45
# config: YES
# start the command batch
batch start
board_name SPEEDYBEEF405V3
manufacturer_id SPBE
mcu_id 003600203033470937323334
signature
# name: -
# resources
resource BEEPER 1 C05
resource MOTOR 1 B06
resource MOTOR 2 B07
resource MOTOR 3 B08
resource MOTOR 4 B09
resource MOTOR 5 B00
resource MOTOR 6 B01
resource MOTOR 7 B05
resource MOTOR 8 B04
resource LED_STRIP 1 C09
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 C10
resource SERIAL_TX 4 A00
resource SERIAL_TX 5 C12
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 C11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource INVERTER 1 NONE
resource INVERTER 2 NONE
resource INVERTER 3 NONE
resource INVERTER 4 NONE
resource INVERTER 5 NONE
resource INVERTER 6 NONE
resource INVERTER 7 NONE
resource INVERTER 8 NONE
resource INVERTER 9 NONE
resource INVERTER 10 NONE
resource INVERTER 11 NONE
resource INVERTER 12 NONE
resource I2C_SCL 1 NONE
resource I2C_SCL 2 B10
resource I2C_SCL 3 NONE
resource I2C_SDA 1 NONE
resource I2C_SDA 2 B11
resource I2C_SDA 3 NONE
resource LED 1 C08
resource LED 2 NONE
resource LED 3 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 NONE
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 NONE
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 NONE
resource ESCSERIAL 1 NONE
resource ADC_BATT 1 C00
resource ADC_RSSI 1 C02
resource ADC_CURR 1 C01
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource SDCARD_CS 1 A15
resource SDCARD_DETECT 1 NONE
resource PINIO 1 C03
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource OSD_CS 1 B12
resource GYRO_EXTI 1 C04
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A04
resource GYRO_CS 2 NONE
resource USB_DETECT 1 NONE
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
# timer
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer B08 AF2
# pin B08: TIM4 CH3 (AF2)
timer B09 AF2
# pin B09: TIM4 CH4 (AF2)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer B05 AF2
# pin B05: TIM3 CH2 (AF2)
timer B04 AF2
# pin B04: TIM3 CH1 (AF2)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
timer A03 AF2
# pin A03: TIM5 CH4 (AF2)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 0
# SPI_MOSI 2: DMA1 Stream 4 Channel 0
dma SPI_MOSI 3 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 0
# SPI_TX 2: DMA1 Stream 4 Channel 0
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 0
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin B06 0
dma pin B07 0
dma pin B08 0
dma pin B09 NONE
dma pin B00 0
dma pin B01 0
dma pin B05 0
dma pin B04 0
dma pin A08 0
dma pin A03 0
# pin A03: DMA1 Stream 1 Channel 6
dma pin B03 0
dma pin C09 0
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature RX_SERIAL
feature GPS
feature TELEMETRY
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
serial 0 131073 115200 57600 0 115200
serial 5 2 115200 115200 0 115200
# mixer
mixer QUADX
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper -GPS_STATUS
beeper RX_SET
beeper ACC_CALIBRATION
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper BLACKBOX_ERASE
beeper CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon -RX_LOST
beacon -RX_SET
# map
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 4 1875 2100 0 0
aux 1 1 1 1375 1650 0 0
aux 2 2 1 1825 2100 0 0
aux 3 27 3 1875 2100 0 0
aux 4 13 0 1875 2075 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
adjrange 0 0 2 900 2100 29 2 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 0
vtxtable channels 0
vtxtable powerlevels 0
vtxtable powervalues
vtxtable powerlabels
# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 h
rxfail 4 s 1000
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set gyro_lpf1_type = PT1
set gyro_lpf1_static_hz = 0
set gyro_lpf2_type = PT1
set gyro_lpf2_static_hz = 1000
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = AUTO
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_count = 1
set dyn_notch_q = 500
set dyn_notch_min_hz = 150
set dyn_notch_max_hz = 600
set gyro_lpf1_dyn_min_hz = 0
set gyro_lpf1_dyn_max_hz = 0
set gyro_lpf1_dyn_expo = 5
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_roll = 0
set acc_calibration = -40,-32,-2,1
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 2
set baro_i2c_address = 0
set baro_hardware = AUTO
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rssi_smoothing = 125
set rc_smoothing = ON
set rc_smoothing_auto_factor = 60
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = CRSF
set serialrx_inverted = OFF
set serialrx_halfduplex = OFF
set adc_device = 1
set blackbox_device = SDCARD
set blackbox_disable_rc = OFF
set blackbox_mode = NORMAL
set blackbox_high_resolution = OFF
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 300
set dshot_burst = ON
set dshot_bidir = ON
set dshot_edt = OFF
set dshot_bitbang = AUTO
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 10
set failsafe_off_delay = 10
set failsafe_throttle = 1040
set failsafe_switch_mode = STAGE2
set failsafe_throttle_low_delay = 250
set failsafe_procedure = GPS-RESCUE
set align_board_yaw = 0
set bat_capacity = 4000
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_sag_lpf_period = 2
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 386
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = ON
set mixer_type = LEGACY
set crashflip_expo = 35
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set small_angle = 180
set imu_process_denom = 2
set gps_provider = UBLOX
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = ON
set gps_ublox_mode = AIRBORNE
set gps_ublox_use_galileo = ON
set gps_use_3d_speed = OFF
set gps_sbas_integrity = OFF
set gps_rescue_min_start_dist = 20
set gps_rescue_alt_mode = FIXED_ALT
set gps_rescue_initial_climb = 10
set gps_rescue_ascend_rate = 300
set gps_rescue_return_alt = 60
set gps_rescue_ground_speed = 800
set gps_rescue_max_angle = 45
set gps_rescue_roll_mix = 150
set gps_rescue_pitch_cutoff = 75
set gps_rescue_descent_dist = 30
set gps_rescue_descend_rate = 100
set gps_rescue_landing_alt = 4
set gps_rescue_disarm_threshold = 20
set gps_rescue_throttle_min = 1129
set gps_rescue_throttle_max = 1700
set gps_rescue_throttle_hover = 1275
set gps_rescue_sanity_checks = RESCUE_SANITY_FS_ONLY
set gps_rescue_min_sats = 6
set gps_rescue_throttle_p = 15
set gps_rescue_throttle_i = 15
set gps_rescue_throttle_d = 20
set gps_rescue_velocity_p = 8
set gps_rescue_velocity_i = 40
set gps_rescue_velocity_d = 12
set gps_rescue_yaw_p = 20
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 1
set simplified_gyro_filter = OFF
set tlm_inverted = OFF
set tlm_halfduplex = ON
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set ledstrip_brightness = 100
set sdcard_mode = SPI
set sdcard_spi_bus = 2
set sdio_clk_bypass = OFF
set sdio_use_cache = OFF
set sdio_use_4bit_width = OFF
set osd_units = METRIC
set osd_warn_bitmask = 73661
set osd_rssi_alarm = 40
set osd_rssi_dbm_alarm = -60
set osd_rsnr_alarm = 4
set osd_cap_alarm = 3200
set osd_alt_alarm = 120
set osd_distance_alarm = 0
set osd_esc_temp_alarm = 0
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_logo_on_arming = OFF
set osd_tim1 = 2064
set osd_tim2 = 2577
set osd_vbat_pos = 234
set osd_rssi_pos = 234
set osd_rssi_dbm_pos = 234
set osd_rsnr_pos = 234
set osd_tim_1_pos = 2533
set osd_tim_2_pos = 234
set osd_remaining_time_estimate_pos = 2602
set osd_flymode_pos = 2121
set osd_g_force_pos = 4330
set osd_throttle_pos = 234
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 14681
set osd_ah_sbar_pos = 4442
set osd_ah_pos = 4314
set osd_current_pos = 234
set osd_mah_drawn_pos = 2596
set osd_wh_drawn_pos = 234
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 234
set osd_pilot_name_pos = 234
set osd_gps_speed_pos = 6249
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 3468
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 23655
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 14613
set osd_avg_cell_voltage_pos = 2469
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_battery_usage_pos = 577
set osd_disarmed_pos = 14743
set osd_nheading_pos = 234
set osd_up_down_reference_pos = 4410
set osd_ready_mode_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_rcchannels_pos = 234
set osd_camera_frame_pos = 35
set osd_efficiency_pos = 5450
set osd_aux_pos = 234
set osd_sys_goggle_voltage_pos = 234
set osd_sys_vtx_voltage_pos = 234
set osd_sys_bitrate_pos = 234
set osd_sys_delay_pos = 234
set osd_sys_distance_pos = 234
set osd_sys_lq_pos = 234
set osd_sys_goggle_dvr_pos = 234
set osd_sys_vtx_dvr_pos = 234
set osd_sys_warnings_pos = 234
set osd_sys_vtx_temp_pos = 3500
set osd_sys_fan_speed_pos = 234
set osd_stat_bitmask = 1828
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set osd_displayport_device = MSP
set osd_framerate_hz = 12
set osd_aux_channel = 1
set osd_aux_scale = 200
set osd_aux_symbol = 65
set osd_canvas_width = 53
set osd_canvas_height = 20
set osd_craftname_msgs = OFF
set system_hse_mhz = 8
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set enable_stick_arming = OFF
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_low_power_disarm = ON
set vtx_softserial_alt = OFF
set vtx_freq = 0
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = HD
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = NOMINAL
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set displayport_msp_fonts = 0,0,0,0
set led_inversion = 0
set pinio_config = 129,1,1,1
set pinio_box = 0,255,255,255
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_sensor_align = CW0
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 0
set gyro_1_align_yaw = 0
set gyro_2_bustype = SPI
set gyro_2_spibus = 0
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_sensor_align = CW0
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 0
set i2c1_pullup = OFF
set i2c1_clockspeed_khz = 800
set i2c2_pullup = OFF
set i2c2_clockspeed_khz = 800
set i2c3_pullup = OFF
set i2c3_clockspeed_khz = 800
set mco2_on_pc9 = OFF
set scheduler_relax_rx = 25
set scheduler_relax_osd = 25
set serialmsp_halfduplex = OFF
set rpm_filter_harmonics = 3
set rpm_filter_q = 500
set rpm_filter_min_hz = 100
set rpm_filter_lpf_hz = 150
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set craft_name = -
set pilot_name = -
set altitude_source = DEFAULT
set altitude_prefer_baro = 100
set altitude_lpf = 300
set altitude_d_lpf = 100
set box_user_1_name = -
set box_user_2_name = -
set box_user_3_name = -
set box_user_4_name = -
# profile 0
set profile_name = -
set dterm_lpf1_dyn_max_hz = 100
set dterm_lpf1_dyn_expo = 5
set dterm_lpf1_type = BIQUAD
set dterm_lpf1_static_hz = 75
set dterm_lpf2_type = PT1
set dterm_lpf2_static_hz = 0
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_sag_compensation = 100
set pid_at_min_throttle = ON
set anti_gravity_gain = 80
set anti_gravity_cutoff_hz = 5
set anti_gravity_p_gain = 100
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 15
set iterm_windup = 85
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 100
set throttle_boost = 5
set p_pitch = 55
set i_pitch = 99
set d_pitch = 57
set f_pitch = 192
set p_roll = 56
set i_roll = 100
set d_roll = 50
set f_roll = 195
set p_yaw = 56
set i_yaw = 100
set d_yaw = 0
set f_yaw = 195
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 37
set d_min_pitch = 42
set d_min_yaw = 0
set d_max_gain = 37
set d_max_advance = 0
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
set thrust_linear = 0
set feedforward_averaging = 2_POINT
set feedforward_smooth_factor = 45
set feedforward_jitter_factor = 6
set feedforward_boost = 15
set feedforward_max_rate_limit = 95
set dyn_idle_min_rpm = 20
set dyn_idle_p_gain = 40
set dyn_idle_i_gain = 50
set dyn_idle_d_gain = 50
set level_race_mode = OFF
set simplified_master_multiplier = 125
set simplified_i_gain = 100
set simplified_d_gain = 100
set simplified_pi_gain = 100
set simplified_feedforward_gain = 130
set simplified_pitch_pi_gain = 95
set simplified_dterm_filter = OFF
set tpa_mode = D
set tpa_rate = 65
set tpa_breakpoint = 1350
profile 1
# profile 1
set dterm_lpf1_type = PT1
set vbat_sag_compensation = 0
set acc_limit = 0
set crash_delay = 0
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set d_min_roll = 30
set d_min_pitch = 34
set d_min_yaw = 0
set d_max_gain = 37
set d_max_advance = 20
set dyn_idle_min_rpm = 0
set dyn_idle_p_gain = 50
set tpa_mode = D
set tpa_rate = 65
profile 2
# profile 2
set acc_limit = 0
set crash_delay = 0
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set d_min_roll = 30
set d_min_yaw = 0
set d_max_gain = 37
set tpa_mode = D
set tpa_rate = 65
profile 3
# profile 3
set acc_limit = 0
set crash_delay = 0
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set d_min_roll = 30
set d_min_yaw = 0
set d_max_gain = 37
set tpa_mode = D
set tpa_rate = 65
# rateprofile 0
set rateprofile_name = -
set thr_mid = 50
set thr_expo = 0
set rates_type = ACTUAL
set quickrates_rc_expo = OFF
set roll_rc_rate = 7
set pitch_rc_rate = 7
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set pitch_srate = 67
set yaw_srate = 67
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
set roll_level_expo = 0
set pitch_level_expo = 0
rateprofile 1
# rateprofile 1
set thr_mid = 50
set thr_expo = 0
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set yaw_srate = 67
rateprofile 2
# rateprofile 2
set thr_mid = 50
set thr_expo = 0
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set yaw_srate = 67
rateprofile 3
# rateprofile 3
set thr_mid = 50
set thr_expo = 0
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set yaw_srate = 67
# save configuration
save
# dump all
# config: YES
batch start
signature
# name: -
# resources
resource LED 1 C08
resource LED 2 NONE
resource LED 3 NONE
# timer
timer B06 AF2
timer B07 AF2
timer B08 AF2
timer B09 AF2
timer B00 AF2
timer B01 AF2
timer B05 AF2
timer B04 AF2
timer A08 AF1
timer A03 AF2
timer B03 AF1
timer C09 AF3
# dma
dma SPI_MOSI 1 NONE
dma SPI_MOSI 2 0
dma SPI_MOSI 3 NONE
dma SPI_MISO 1 NONE
dma SPI_MISO 2 NONE
dma SPI_MISO 3 NONE
dma SPI_TX 1 NONE
dma SPI_TX 2 0
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 0
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin B06 0
dma pin B07 0
dma pin B08 0
dma pin B09 NONE
dma pin B00 0
dma pin B01 0
dma pin B05 0
dma pin B04 0
dma pin A08 0
dma pin A03 0
dma pin B03 0
dma pin C09 0
feature -OSD
feature -AIRMODE
feature -RX_SPI
feature -ESC_SENSOR
feature RX_SERIAL
feature GPS
feature TELEMETRY
feature OSD
feature AIRMODE
# mixer
mixer QUADX
# beeper
beeper RX_LOST
beeper -DISARMING
beeper -ARMING
beeper BAT_CRIT_LOW
beeper BAT_LOW
beeper -GPS_STATUS
beeper RX_SET
beeper READY_BEEP
beeper MULTI_BEEPS
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper CRASH_FLIP
# beacon
beacon -RX_LOST
beacon -RX_SET
# map
map AETR1234
led 0 0,0::C:0
led 1 0,0::C:0
led 2 0,0::C:0
led 3 0,0::C:0
led 4 0,0::C:0
led 5 0,0::C:0
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
# adjrange
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtxtable
vtxtable bands 0
vtxtable channels 0
# vtx
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 h
rxfail 4 s 1000
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set acc_lpf_hz = 10
set rssi_offset = 0
set adc_device = 1
set dshot_edt = OFF
set ibatv_scale = 0
set beeper_od = OFF
set deadband = 0
set osd_tim1 = 2064
set osd_tim2 = 2577
set osd_profile = 1
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_freq = 0
set craft_name = -
set pilot_name = -
# profile 0
set acc_limit = 0
set crash_delay = 0
set p_pitch = 55
set i_pitch = 99
set d_pitch = 57
set f_pitch = 192
set p_roll = 56
set i_roll = 100
set d_roll = 50
set f_roll = 195
set p_yaw = 56
set i_yaw = 100
set d_yaw = 0
set f_yaw = 195
set d_min_roll = 37
set d_min_yaw = 0
set d_max_gain = 37
set tpa_mode = D
set tpa_rate = 65
profile 1
# profile 1
set acc_limit = 0
set crash_delay = 0
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set d_min_roll = 30
set d_min_yaw = 0
set d_max_gain = 37
set tpa_mode = D
set tpa_rate = 65
profile 2
# profile 2
set acc_limit = 0
set crash_delay = 0
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set d_min_roll = 30
set d_min_yaw = 0
set d_max_gain = 37
set tpa_mode = D
set tpa_rate = 65
profile 3
# profile 3
set acc_limit = 0
set crash_delay = 0
set p_pitch = 47
set i_pitch = 84
set d_pitch = 46
set f_pitch = 125
set p_roll = 45
set i_roll = 80
set d_roll = 40
set f_roll = 120
set p_yaw = 45
set i_yaw = 80
set d_yaw = 0
set f_yaw = 120
set d_min_roll = 30
set d_min_yaw = 0
set d_max_gain = 37
set tpa_mode = D
set tpa_rate = 65
# rateprofile 0
set thr_mid = 50
set thr_expo = 0
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set yaw_srate = 67
rateprofile 1
# rateprofile 1
set thr_mid = 50
set thr_expo = 0
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set yaw_srate = 67
rateprofile 2
# rateprofile 2
set thr_mid = 50
set thr_expo = 0
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set yaw_srate = 67
rateprofile 3
# rateprofile 3
set thr_mid = 50
set thr_expo = 0
set yaw_rc_rate = 7
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 67
set yaw_srate = 67
save
