Betaflight and Mini Hex
Has anyone set up a mini hex with betaflight recently? I had my Blackout Spider Hex running well but it has been hiding in the cupboard for quite some time while I played with all the new mini's.
From memory the P gain had to be reduced as well as the I I assume but can't remember how much I was dropping the settings.
Any first hand experience with this you can pass on and I will forever be in your debt......
I have loaded BF 2.9 on a Naze32 Acro Rev5.
Look at the frame design, it's very front heavy. You need a custom motor mix to make it fly properly
the PID controller will iron out a lot of the issues, but if you want it flying 100% perfect, then a custom mix is the only way to fix it.
Check out the Blackout hex thread, borisb worked out some motor mixes:
http://www.rcgroups.com/forums/showthrea...1&page=238
Righto so I loaded up CF 1.12 and dialled down P and I a fair bit and it is close to tuned, looks like BF is broken for hexes.
And applied the custom mix, made a big difference.
  Betaflight Github questions Rob Axel 6 227 13-Feb-2024, 11:40 AM
  betaflight config 10.10 RC2 issue Rob Axel 3 282 10-Feb-2024, 01:21 PM
  Betaflight Motor Test Results in SmokeStopper overvoltage LoganFPV 5 251 01-Aug-2023, 11:22 AM
  Build T-Motor F7 stack - Betaflight Gyro update frequency 3.2kHz ???? MindBenderFPV 2 3,125 18-Jun-2022, 09:10 AM
  Solved Betaflight 4.3.0 RC3 SoCal_FPV 5 542 17-Feb-2022, 06:30 PM
Last Post: SoCal_FPV
