21-Jul-2023, 11:34 PM
Hello!
I'm finishing my second drone build and am having a bit of trouble with testing my motors in Betaflight. When I attach a battery via SmokeStopper, connect to the drone in betaflight, go to motors tab, and enable the motor testing, it gives me an overvoltage error on the smokestopper. It doesn't give any problems when initially plugging in with the smokestopper and battery, only when attempting to test the motors while having done so.
I found this thread:
https://intofpv.com/t-weird-motor-behavior-on-new-build
I believe I may be experiencing the same issue, but am not positive because the other poster was able to test at a lower RPM, whereas I am not able to get any movement from my motors prior to the smokestopper tripping when lifting the master slider or single sliders individually. This is my only concern.
As this is a new build, I'm a bit skiddish to plug it in raw but having not found any other cause of failure, I think I may just be being overly cautious.
Any help/advice is much appreciated!
Troubleshooting I've tried:
I've flashed the most recent version of Betaflight
I've flashed the ESC with the most recent version of BlueJay
I checked for continuity between points around the drone and found none, at least not where there shouldnt be
I am using DSHOT 300 in betaflight, 3.2khz PID loop frequency, and esc local frequency set to 48khz via bluejay
Build info here:
5" Apex Clone
SpeedyBee F4 Flight Controller Stack
SpeedyBee TX800 VTX
XING-E Pro 2207 1800KV Motors
RunCam Phoenix 2 SE Camera
HGLRC Mini M100 GPS
VIFLY GPS Backup Battery/Buzzer
Happymodel ELRS EP1
5.1" 51477 Props
Build info here:
5" Apex Clone
SpeedyBee TX800 VTX
HGLRC Mini M100 GPS
Happymodel ELRS EP1
5.1" 51477 Props
-Logan
I'm a total noob, flying full speed by the seat of my pants
