Air Bird 10 in Quad
Hello one and all
I am not set to build my Air Bird yet, but wanted to run my parts list by you all, see what you think.
                             Air Bird a 10-inch quad
The Air Bird will be a FPV Long range Cinemaphotography quad. Her goal in life will be photographing Radio Control Sailboat racing. Mostly the DF-95 Class. And any other times I like to fly her.
     The Air Bird will consist of the following parts: (In Red I have)
Frame :
iFlight DC 10 V2 (Dead Cat Frame) Kit
Motors:
iFlight Xing X2814 1100 KV
Props (Propellers)
Not sure yet
FC – Flight Controller /4in1 ESC :
Mamba F722S App/F60 Pro
Receiver:
TBS Crossfire Nano RX
TBS Crossfire Antenna:
VAS 915mz X Fire Pro Ultra-Flex
Switch for on and off
Li-Lon 4S Battery:
4S 4200mah
Battery Strap and pad
TX 60 Battery lead with 14 gauge wire
Barometer:
Not sure yet
FPV Camera/ Action Camera:
Runcam Hybird
Video Transmitter (VTX):
Not sure yet
FPV antennas:
Not sure yet
Beeper with built in Battery:
Vifly Finder 2 Buzzer
TB Crossfire:
Not sure yet
GPS-with compass:
BN-880 GPS
LED’s on the Arms
Silicone Strips(for Base)
O Rings(for camera)
Goggles:
Eachine EV800D
Transmitter:
Radio Master TX16S
iNav Configurator
Thanks for any help
Bulldog Bill
[-] The following 2 users Like [email protected]'s post:
  • Joshua_A, Krohsis
I assume you meant 1100kv not 100kv on the motor.
Thanks edit done
Hi Bill,
I found your new 10 inch build.
Yep you did can’t hide from you HaHa
Feed back?????
Bill
Do you have a TBS Crossfire module for the TX16S transmitter ?
Harry
No I do not, have the Nano receiver and the Vas antenna for the frame but have not brought the TBS module for my TX16S yet.
Bill, I guess that TBS Crossfire module will be one of your next purchases since you will need it to fly this thing.
Harry
My camera will be the next purchase, as it is part of the frame build, both big $$$$$$$$$$$
When I get to that point of my build if I have to I will change out the Nano and install a Jumper R-1 just to test the Air Bird.
I ordered a new sail for my DF 95 a few months ago and it got here yesterday, so have that to install on my DF-95 sail boat(RC).
Tying to install iNav on my Ga. 5 in, on and on. I will keep busy till I can get the TBS cross fire module. But the Air Bird will be my go to quad.
Still looking for efficient props.
Bulldog Bill
[-] The following 1 user Likes [email protected]'s post:
  • iFly4rotors
Bill,
You might consider starting a discussion thread for 10 inch props in the Long Range section. Krohsis might chime in; he is pretty much the King of long range. Plus, it might generate ideas, options, and sources for others as well.
Bill, What camera are you considering for the Air Bird??
Harry
I am looking at the Runcam Hybird, was just looking at the threads here, not a very good review seems those that are using them , are having SD card problems, was just checking you tube.
Bill
Did a little work on getting the frame set to build.
2020-12-28
Frame :
Arm Weight: 55 grams  Total 220 grams
Top plate Weight: 23 grams
Middle Plate Weight: 27 grams
Bottom Plate Weight: 37 grams
All screws and stand offs Weight: 42 grams
Total Built Weight:
[Image: 5FFxW00l.jpg]
[Image: tyqExpsl.jpg]
[Image: tfT5jnhl.jpg]
[Image: Q5ht7mXl.jpg]
[Image: 1ZdHsgLl.jpg]
[Image: HlK8Jlll.jpg]
[Image: eEH3742l.jpg]
[Image: JfWqimfl.jpg]
As you can see here all the screws etc. where in one bag, unlike the Diatone projects ,where I got these bags for this build.
Next step I will assemble the frame
Bill
  • iFly4rotors
2020-12-29
Building the Frame.
The first thing I did before assembling the frame, was to wash all the frames parts.
Then I placed them all where I think they need to go. Photos 003-1 to 007.
Next I placed all the screws in sperate bags, so when installing them I did not have to go thru the whole bag of pieces. Be careful when installing the screws some are only 2mm differs. Use the guide only as a references only.. See Photo 007-a and 008-a.
Total weight of the frame when built is 334 grams. Photo 018
A couple of items to take note of when building the 10-inch frame.
1)    Notice the end of the Arms, there is a slight differences. See Photos 001-1.
2)    Notice photo 008 when putting bottom and middle frames on arm, be sure they are all flat when done.
3)    Notice how the camera frames go, Very import only goes as shown in photo 009 and 010.
Sorry the photo number did not show up and I dont have time to fix them.
[Image: asklyTFl.jpg]
[Image: URCByPel.jpg]
[Image: QWcfMYMl.jpg]
[Image: Kwb64kHl.jpg]
[Image: zQ3t7Isl.jpg]
[Image: KytDXAjl.jpg]
[Image: 59sALbOl.jpg]
[Image: 3tlurhil.jpg]
[Image: kAomsS9l.jpg]
[Image: kY3guAXl.jpg]
[Image: DonZRzll.jpg]
[Image: k4PKl1Xl.jpg]
[Image: zmgc12bl.jpg]
[Image: 8SuoFY1l.jpg]
Will install the motors next.
Wow, that is one massive frameBig Grin
  Discussion High Speed efficient quad setup for car chasing MindBenderFPV 5 1,453 03-May-2023, 04:51 PM
Last Post: truglodite
  Initial PID settings for 10" quad navillus5 4 6,821 16-Feb-2022, 10:37 PM
Last Post: romangpro
  Solved the problem!! (10" quad - iNav - motor2 20% faster) navillus5 0 859 28-Nov-2020, 05:26 PM
Last Post: navillus5
  10" quad - iNav - Intermitent "twitch" navillus5 4 1,514 27-Nov-2020, 12:13 AM
  Discussion Gotta get a bigger Quad? Aaron 6 2,328 23-Jun-2018, 01:46 AM
Last Post: Aaron
