Threads: 21
Likes Received: 3 in 2 posts
Likes Given: 3
0 Hi -
I am working on a 10" quad design. I am running iNav using default settings for a 10" quad, and I have successfully implemented both Position Hold and RTH. The quad has a mass of 1.0 kg without the battery mounted and I am getting about 7 minutes of flight time with a 4s 1550 battery.
The one nagging issue is an intermitent "twitch" which I believe may be due to improper gyro filtering. I have a short video of a flight that I made today and I was hoping someone could take a look and provide some troubleshooting advice.
The link is youtu.be/4aoBAfjmzE4
Thanks
Threads: 14
Likes Received: 163 in 126 posts
Likes Given: 1
12 23-Nov-2020, 06:35 AM (This post was last modified: 23-Nov-2020, 06:36 AM by EVILsteve.) I believe your idea of gyro filtering is on the right track. I was instantly thinking flight controller vibration issue when it looked like it had a high frequency vibration before you zoomed in but it's hard to pinpoint that without knowing the control inputs your giving it. The big twitche's when your zoomed in sure point in the direction of vibration or filtering as well.
What is his anyway an older flame wheel or clone? Are these all new components. The props especially are these the newer style multirotor props or the older ones with that plastic insert to make them fit the motors.
I'd start with ensuring perfect balancing props and the stack is not loose or too tight then adjust some filtering and see how it responds. At least it's very flyable right now so any small adjustments in the wrong direction shouldn't make it fall from the sky but youl know when your on the right track.
Threads: 118
Likes Received: 1,411 in 728 posts
Likes Given: 1,069
41 navillus5, one of the twitch movements appeared to happen on a pure yaw move. I had this on a much smaller 5" quad that was solved by installed a low ESR power capacitor across the power terminals of the 4in1 ESC. I know you had another twitch occur that didn't appear to be yaw related - but I would check that you have a low ESR cap on your ESCs (connected directly to the power pads on each esc) and one also on the power pads of the flight controller just to be safe. This might not be the problem though, just my simple view on things, lol... Also if you can post the BB logs then our local filtering guru samurai could help diagnose it for you.
good luck,.
ph2t.
Threads: 125
Likes Given: 99
388 Yaw twitch is usually cured by installing caps as you mentioned. If caps do not work, you have to look to increasing filtering.
