Threads: 20
Likes Received: 3 in 2 posts
Likes Given: 4
0 I want to try the HMDVR-S on my GEPRC Dolphin, but I'm having trouble figuring out what goes where. Specifically:
1) Where do I get the video signal from? I don't see a V out pad on the VTX. Maybe there's a way to get it via the pinouts on the VTX, but it's not clear from GEPRC's wiring diagrams. Ideally, I'd feed the DVR video without the OSD, but easier is better.
2) Where do I get power? I've got a buzzer connected, but can I double up on those pads?
Threads: 125
Likes Given: 99
388 You have to split the video signal that is coming out of the camera if you don't want to record the OSD. Or split it at the VTX if you want the OSD recorded. So basically, solder the video in from DVR to either the VIN or VOUT on the FC. But remember to leave the wire that is already there connected.
Threads: 20
Likes Given: 4
1) Where do I get the video signal from? I don't see a V out pad on the VTX (the triangular GEPRC whoop-sized stock VTX). Maybe there's a way to get it via the pinouts on the VTX, but it's not clear from GEPRC's wiring diagrams. Ideally, I'd feed the DVR video without the OSD, but easier is better.
Threads: 20
Likes Given: 4
0 Hey, I got it working. Now I just need to figure out where to put it...?
Threads: 595
Likes Received: 9,037 in 6,688 posts
Likes Given: 1,428
796 Good news. There's not a lot of space in the Dolphin so you might have to mount it on the bottom. Maybe using a custom 3D printed mount.
