Threads: 71
Likes Received: 339 in 253 posts
Likes Given: 156
19 And what is the image like when the three, Goggles, Quad and Tx are NOT jammed up against each other, like at distances when you would fly??
Threads: 38
Likes Given: 430
118 I had the same bands on my 1S toothpick and had to replace the Crossfire mini immortal t antenna to a full size antenna. Eventually I replaced the Crossfire rx with an ELRS rx (ceramic antenna).
Twist and turn all wires. Keep the receiver and vtx as far away as possible. Experiment with rx antenna placement and orientation. Since the rx is 2.4ghz avoid any wires lengths of 31mm on the build.
Threads: 38
Likes Given: 430
118 I know you are running a FrSKY R-XSR receiver but any system that transmits telemetry back to the radio can cause this issue.
Threads: 5
Likes Received: 0 in 0 posts
0 So i increased the video cable lenght but it didn´t change anything. I even tried it with another camera but it didnt help.
Threads: 38
Likes Given: 430
118 In that case you might just have a noisy TX on the radio but video signals get such bands when there is a transmitter near by even if its not on 5.8GHz. There is no real solution to this.
Even wifi broadcasting at 2.4GHz can cause such an effect on video feet.
I still feel the original issue you have reported is related to the receiver/antenna combo. Try holding the antenna or the receiver with your hand and probably the bands will disappear.
Threads: 5
0 I ve found a fix.
I am using the lowest or the highest Vtx frequency cannel.
So i just use E 3/4 or E8
My Controller is probably sending out 5.8 GHz interference frequencies.
So iam just using the lowest or the highest frequency of my Vtx.
Thanks
