Threads: 1
Likes Received: 0 in 0 posts
Likes Given: 1
0 Hello everyone I connected a betafpv M03 vtx to a FOXEER Razer fpv camera and when I connected it to betaflight it starts to overheat. I am wondering if the camera is drawing to much current. Also there is no picture only OSD?
Threads: 118
Likes Given: 127
20 03-Apr-2024, 08:12 PM (This post was last modified: 03-Apr-2024, 08:25 PM by Rob Axel.) Your camera is either bad or you wired ur wrong..inspect your solder connections REAL GOOD! Use a jewelers loupe .. if it looks good se-solder and reconnect to betaflight.. see if your vtx gets hot..
But double check your wiring first if it’s a plug.. they are not so pinned the same
Threads: 0
0 The camera works on a different vtx and I just checked the wires with a magnifying glass and I could not see any short circuits and the vtx still gets hot
Threads: 75
Likes Received: 1,357 in 1,014 posts
Likes Given: 786
41 Is this while it's sat on the bench, running at the full 400mW without cooling? Or while running at 25mW without cooling? Or while on a quad flying at 30mph?
Try Not, Do or Do Not
- Yoda
