Tyro129 + FlySky X6B RX Voltage monitoring
Hi all,
New member here, just assembling the Tyro 129 kit I recently purchased. I have also acquired the Flysky I6X TX and X6B RX.
I understand the RX has the ability to monitor battery voltage of the drone and relay this back to the TX. However I am unclear on how this is wired up to the Flight Controller on the Tyro129.
Outputs from the RX for the voltage monitor are (according to the PCB labels), Gnd, Bat, Gnd. Although this should already be grounded by the main RX connection to the FC.
As for the FC I think I have 2 spare UART ports as follows:
 - 10v, NC, NC, VTX, TX3
- Gnd, Buz, RGB, 5V
There are also spare solder points:
- TX5
- RX5
- PB0
- TX2
- RSSI
Any thoughts would be appreciated.
Thanks
Tom
The FC has a port for the receiver called RC. Next to that port, there is 3 jumper pad. You want to solder bridge middle pad with the pad labeled DSM/IBUS. Wire the IBUS from your radio to the RC. Then you need to setup betaflight correctly. If you don't know what to do for the settings, post a dump file. We can help you with that.
As for telemetry (aka FC battery voltage), your receiver do not support it. Flysky protocol typically does not support telemetry. You want to move to a Frsky, Crossfire, Ghost, or Tracer capable radio/receiver system for telemetry.
You will have telemetry in the OSD regardless.
FlySky does support telemetry.
X6B has telemetry - I get both Vbat and RSSI.
There is a port at the bottom for voltage sensor.
Look at X6B Manual. You connect it to battery pads.
https://intofpv.com/t-flysky-x6b-and-i6x...al-voltage
  Tip & Trick Li-Ion 18650 Batteries and Low Voltage Cutoff iFly4rotors 54 11,560 04-Jun-2021, 11:41 AM
  Solved ?? Voltage regulator to fix “LVC” problem on 2s ?? Joshua_A 14 1,611 14-Feb-2021, 05:05 PM
Last Post: Joshua_A
  Build Tyro129 - first build Musiquealchemy 38 8,763 12-Jan-2021, 02:12 AM
  GPS Monitoring on iPhone senatorperkins 1 451 09-Jan-2020, 02:47 AM
Last Post: sim_tcr
