30-Dec-2019, 12:28 AM
(30-Dec-2019, 12:12 AM)BastifromGermany Wrote: ive ordered the R9MM.
With a T Dipol Antenne.
can i contakt you if i have the same trouble ?
Of course If you get any troubles then probably best to start a new thread specifically related to the R9MM. Did you get the regular R9MM or the R9MM-OTA? The latter is only really useful if you have an ACCESS equipped transmitter which you won't have if you have one of the older X9D's with "ACCST" written on the front.
When you get the R9MM, do the following:-
- Flash the latest version of the FLEX FPORT firmware to the R9MM receiver.
- Connect the "Inverted S.Port" pad of the R9MM to the T6 pad on the GEPRC Span F4 FC.
- Re-run all the CLI commands in post #2 to be sure the setting are all correct.
- Bind your R9M to the R9MM.
- Watch your stick movements work in the Receiver tab (I hope ).
