Threads: 1
Likes Received: 0 in 0 posts
0 help pls new build So it arms once everything spins once i disarm it wont let me rearm with throttle at zero and trying to rearm nothing even after power cycle. and when i am in betaflight and i try and look at why its disabled it spins and spins waiting for info,
Also OSD is frozen will need help
SpeedyBee F405 Mini BLS 35A 20x20 Stack
hdzero freestyle VTX
Threads: 4
Likes Received: 65 in 60 posts
Likes Given: 17
8 So your setup has only worked once basically? you havent gotten the motors to spin since that first time? if you cant connect to betaflight anymore you may have burned out your FC. Does it light up with all the normal LEDs? the manual shows you what LED indicates what for the speedybee
Do you get all 5 beeps when plugging in your lipo?
Threads: 50
Likes Received: 104 in 92 posts
Likes Given: 203
4 You say in Betaflight it “spins and spins”. Is this the quad image on the first Betaflight page? Or on the Rx tab?
Threads: 79
Likes Received: 1,411 in 1,061 posts
Likes Given: 833
42 Broken gyro maybe if it spins constantly.
If it's only ever armed once, you've probably broken something. If you can no longer connect to Betaflight, then your FC is probably toast.
Try Not, Do or Do Not
- Yoda
