small (65/75mm) digital whoops, managing flight times
(15-May-2024, 01:21 PM)Pathfinder075 Wrote: If you find something you like, then i would use it. Wink  I have Lipos I like, lipos I don't like and a lot of mid level stuff that I use because it's cheap, but has downsides.  If I have to carry double the number of cheaper lipos to get the flight times I would on half the number on more expensive, then I just accept it, since I have no issues carrying 20-30 lipos to a site.
Yeah for a while before I found ways to stretch the flight time I was ready to content the fact that the work around is to fly shorter flights but do more back to back flying.
(15-May-2024, 02:06 PM)ph2t Wrote: >>I'm staying with the stick batteries as they fit the 65mm frame natively.<<
That is one of my mental issue. I want the battery to fit the frame natively without clunky attachments. That's why I was asking if your frame can handle the Lava 550 cell. None of my 65mm frame could do it except for the ones with the carbon bottom plate. Then I am adding more weight just to hold the battery in place "natively". That's what prompted me to go up to the 75mm frame.
I've managed to make my lightest 65mm build yet, coming in at 22.8g.   Lighter than a mob6 hdzero eco which is a reported 23.2g.   Take that low-fi digital! lol.
[Image: attachment.php?aid=12323]
I'm starting to approach 3:00 min flight times which is great.
Things I did to help with the weight.
  • On the aio I shortened the battery pigtail, removed the rubber sleeve on the bt2 connector and used a paper shim (between terminals) with liquid electrical tape to insulate.
  • The canopy is the mcstinky 30deg (from thingyverse) which is lighter than the betafpv ultralight canopy.
  • Motors are the 0702se 25000kV, lower than what I would put on but wanted to try for better runtimes.  One of the lightest 0702s around atm.
  • Removed motor plugs, direct solder to aio
  • Peek screws for the motors
  • Vtx has all heatsinks removed with the soic mounted topside for airflow
  • Vtx antenna is ORT, lighter than the stock dipole
  • Stack screws are lighter M1.2 10mm than the stock M1.4 10mm.
I'm still finding the tattus reign supreme.
Averages for now.
tattu 300mAh (folded, bt2) - approx 3mins
lava 300mAh (folded bt2)  - approx 2:30mins
gnb 380mAh (folded a30) - approx 2:00mins
tattus are the heaviest, gnbs are the lightest.
gnb batterys for this scale continue to be very poor, even the marketed folded cell.
GNB 1S 3.8V 380mAh 60C Lipo Battery Cabled A30 BT2.0 High Current Discharge Connector For FPV RC Tiny Whoop Drone 3.8v Battery (aliexpress.com)
battery sag performance is similar
From best: tattu (approx 0.2 - 0.3 V) through to gnb with massive sag of up to 0.6V.
[-] The following 4 users Like ph2t's post:
  • drumgod, hugnosed_bat, V-22, Cyberess
#19
I dunno.
maybe try 25mw on vtx?
Its a whoop. Not gonna fly far anyway.
#20
(24-Jun-2024, 04:45 AM)romangpro Wrote: I dunno.
For analog yes but I don't know if there is a 25 mW setting for digital.
#21
(24-Jun-2024, 02:42 AM)ph2t Wrote: I've managed to make my lightest 65mm build yet, coming in at 22.8g.   Lighter than a mob6 hdzero eco which is a reported 23.2g.   Take that low-fi digital! lol.
<snip>
That is an amazing setup for a 65 -- That is Walksnail?
I like the look of that VTX ORT antenna you have used.  That is the ORT Micro Vee 5.8GHz U.FL Antenna? It seems to be out of stock everywhere, is it any good?
#22
There is a 25mW setting for Walksnail 1s vtx.  The power drain between the 25mW, 200mW settings is pretty negligable.  It's the bloody motors that suck the juice, predominately.
It is the ORT micro vee, you are right.  There was a bloke in one of the aussie fpv groups that had imported a ton of them.
Here's the link: https://www.facebook.com/groups/51625215...8226771635
It is a great micro vtx antenna.  Better than the stock dipole on the 1s ws vtx in range and weight.
[-] The following 1 user Likes ph2t's post:
  • Cyberess
#23
There are gnb 380mah 90c batteries, doesnt fit 65mm frames.
The 60c batteries are usless.
We did 2s packs out of it to stay lightweight, but their perfoemance is so poor, even on half current as 2s, they did suffer in peeformance.
#24
(25-Jun-2024, 12:55 AM)hugnosed_bat Wrote: There are gnb 380mah 90c batteries, doesnt fit 65mm frames.
I have these GNB 90C 380 mah packs and they don't fit my 65mm frames. They are too wide. They do fit on my 75mm frame.
[Image: JqSOkPel.jpeg]
[-] The following 1 user Likes SeismicCWave's post:
  • ph2t
#25
The GNB I've used is this one, in stick format for the 65mm frames.
[Image: attachment.php?aid=12324]
  Help 75mm Tinywhoop wobbles/shakes/jello when using 3 or 4 blade props fpvgeten 6 212 18-Jun-2024, 07:38 PM
Last Post: fpvgeten
  Flight controller question again.... SeismicCWave 10 331 03-Jun-2024, 07:42 PM
  How do you store your Micros and Whoops? Cyberess 19 765 17-May-2024, 01:36 AM
Last Post: brettbrandon
  Carbon frames with separate ducts (whoops) a la fractal 65 Luk5569 7 433 27-Feb-2024, 11:05 AM
Last Post: Luk5569
  75mm whoop - budget conscious build Pathfinder075 25 1,291 13-Feb-2024, 05:48 AM
