[RESOLVED]iNavFlight/LuaTelemetry - Battery critical warning and Fuel % showing 0
I am new to taranis. I setup iNavFlight/LuaTelemetry on x9 lite. And it all come up fine on Taranis.
Issue is,
Whenever I arm, it warms me "Battery critical and Battery left 0%"
Fuel is always shows as 0%.
What I am doing wrong?
Thanks.
Warning from radio or INAV OSD? And does it continues?
(15-Dec-2019, 08:43 AM)voodoo614 Wrote: Warning from radio or INAV OSD? And does it continues?
Warning is from radio and osd looks fine.
And yes it continues from the beginning of flight through out end.
On the radio, you need to probably set logic switch.
https://oscarliang.com/taranis-logical-s...age-alarm/
Here is a video taken where I am trying to explain the issue.
The "Fuel" value for the amount if current drawn from the LiPo since the quad was armed. As this value is showing zero then that is likely the reason you are getting "Critical Battery" warnings.
Have you set up your current sensor and set the correct capacity for the LiPo in iNav?
(15-Dec-2019, 10:25 AM)SnowLeopardFPV Wrote: The "Fuel" value for the amount if current drawn from the LiPo since the quad was armed. As this value is showing zero then that is likely the reason you are getting "Critical Battery" warnings.
Yes I have, it’s virtual current sensor I am using.
OSD Amperage and mah used is pretty accurate.
I think the issue is since Fuel is never read, tarnis think battery as empty and warning.
Issue resolved.
Some time back I had renamed the sensor name from Fuel to Mah in Telemetry screen.
That must have caused it.
So I deleted all sensors and rediscovers them all.
That resolved the issue.
OK, that's great news. I guess the LUA script is looking for a sensor with the name "Fuel" and because you renamed it, the LUA script could no longer find a sensor with that name.
Out of interest, in the actual sensor discovery page against the model (not the LUA script page), does the Fuel value start at 0% and go UP (1%, 2%, 3% and so on) the longer the LiPo is left plugged in, or does the value start at 100% and go down?
I've never use the Fuel value on my transmitter, but in the sensor discovery page on mine, the value starts at 0% and goes up rather than starting at 100% and going down. Maybe the LUA script itself reverses the values and shows the latter (100% down to zero).
EDIT: Don't worry. I found the answer. The "Fuel" percentage sensor value always counts up from 0%, and in fact it can exceed 100% if you don't set the Battery Capacity in Betaflight/iNav to match the capacity of the LiPo you are using. I guess the iNav LUA scripts are just reversing the value with a real Fuel sensor value of 0% being translated to 99%, a real Fuel sensor value of 1% being translated to 99%, and so on down to 0%.
(15-Dec-2019, 11:14 AM)SnowLeopardFPV Wrote: OK, that's great news. I guess the LUA script is looking for a sensor with the name "Fuel" and because you renamed it, the LUA script could no longer find a sensor with that name.
When I plugin battery, it would show as some percent (72% for eg.)
After some time, it would keep going down.
And yes, in INAV i have set my battery capacity.
  Average Cell Voltage not showing on OSD brownviper1966 5 1,053 09-Jan-2022, 12:28 AM
Last Post: kaitylynn
  Althold issue after battery change. finnigan 2 460 08-Jul-2021, 10:08 AM
Last Post: finnigan
  [RESOLVED] iNavFlight/LuaTelemetry - horizon working inverted when roll sim_tcr 3 1,558 16-Dec-2019, 05:34 PM
