Threads: 17
Likes Received: 3 in 3 posts
Likes Given: 18
0 I set the ALthold on my quad.
It works fine with a 4S LiOn pack but when i connect MyLiPo 3S 850mah, the quad jumps and keep climbing.
The hover throttle is, more or less, the same.
Threads: 38
Likes Given: 430
118 08-Jul-2021, 02:30 AM (This post was last modified: 08-Jul-2021, 02:30 AM by kafie1980.) Why will the power source affect AltHold? Do you have a barometer onboard or externally connected to the FC?
If the hover throttle value is the same then the resulting lift on a 3S should be less than a 4s lion.
Unless your 4s lion pack was struggling to provide the required amps and you adjusted the throttle value according to that deficiency and now on a lipo pack the system is able to draw more amps to meet the expected throttle value.
Threads: 17
Likes Given: 18
0 Hi, thanks for reply.
The FC is an Omnibus nano v6.2, the onboard baro is the BMP280.
The Lion pack is a 4x samsung 18650, homemade and well working. 3000 Mah, its weight is 206 grams
The Lipo battery is an Infinity 3S, 850 mah brand new, 85C, weight about 70 grams.
I use a spring-centered throttle, i set the curve so i can hover with few inputs, tthe battery compensation is ON. This throttle curve works well with both batteries.
Concerning the configurator, the hover trottle is set on 1430
