(04-Apr-2021, 10:32 PM)V-22 Wrote: Can you post a dump and diff all from iNav?
Under the sensors tab, is the barometer providing good data?
Baro seems to be outputting accurate data through OSD. Here is a screenshot of the sensors tab:
I also have a blackbox log if that will help
Diff all:
# diff all
# INAV/HGLRCF722 2.6.1 Feb 25 2021 / 10:22:22 (64249b1a)
# GCC-9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599]
# start the command batch
batch start
defaults noreboot
# resources
# mixer
mmix 0 1.000 1.000 1.000 1.000
mmix 1 1.000 -1.000 1.000 -1.000
mmix 2 1.000 1.000 -1.000 -1.000
mmix 3 1.000 -1.000 -1.000 1.000
# servo mix
# servo
# safehome
# logic
# gvar
feature -AIRMODE
feature GPS
feature PWM_OUTPUT_ENABLE
# beeper
beeper -HW_FAILURE
# map
map TAER
serial 2 2 115200 38400 0 115200
serial 3 2097152 115200 115200 0 115200
# color
# mode_color
aux 0 0 0 1700 2100
aux 1 3 1 1300 1700
aux 2 11 1 1700 2100
aux 3 10 2 900 1300
aux 4 13 2 1700 2100
aux 5 26 0 1700 2100
# adjrange
# rxrange
# temp_sensor
# wp
#wp 0 invalid
# osd_layout
osd_layout 0 0 23 0 H
osd_layout 0 1 12 0 H
osd_layout 0 2 0 0 V
osd_layout 0 7 1 14 V
osd_layout 0 9 1 2 H
osd_layout 0 11 2 3 H
osd_layout 0 12 1 4 H
osd_layout 0 13 12 1 V
osd_layout 0 22 14 11 V
osd_layout 0 28 23 11 H
osd_layout 0 33 11 9 V
osd_layout 0 34 10 3 V
osd_layout 0 38 13 14 H
osd_layout 0 109 23 1 V
osd_layout 0 110 23 0 V
# master
set looptime = 500
set gyro_hardware_lpf = 256HZ
set gyro_lpf_hz = 110
set gyro_lpf_type = PT1
set dynamic_gyro_notch_enabled = ON
set dynamic_gyro_notch_q = 250
set dynamic_gyro_notch_min_hz = 120
set acc_hardware = MPU6000
set acc_lpf_hz = 102
set acczero_x = 1
set acczero_y = -4
set acczero_z = -2
set accgain_x = 4082
set accgain_y = 4086
set accgain_z = 4078
set align_mag = CW270
set mag_hardware = HMC5883
set mag_declination = 1140
set magzero_x = 107
set magzero_y = -89
set magzero_z = 272
set maggain_x = 345
set maggain_y = 369
set maggain_z = 491
set baro_hardware = BMP280
set pitot_hardware = NONE
set serialrx_provider = CRSF
set blackbox_rate_denom = 2
set motor_pwm_rate = 16000
set throttle_idle = 5.000
set failsafe_procedure = RTH
set model_preview_type = 3
set applied_defaults = 2
set gps_provider = UBLOX7
set mc_airmode_type = THROTTLE_THRESHOLD
set nav_use_midthr_for_althold = ON
set nav_user_control_mode = CRUISE
set nav_auto_speed = 500
set nav_manual_speed = 800
set nav_manual_climb_rate = 300
set nav_rth_altitude = 100
set nav_mc_hover_thr = 1000
set i2c_speed = 800KHZ
set tz_automatic_dst = USA
# profile
profile 1
set mc_p_pitch = 44
set mc_i_pitch = 75
set mc_d_pitch = 25
set mc_i_roll = 60
set mc_p_yaw = 35
set mc_i_yaw = 80
set dterm_lpf_hz = 110
set dterm_lpf_type = PT1
set dterm_lpf2_hz = 170
set dterm_lpf2_type = PT1
set heading_hold_rate_limit = 101
set d_boost_factor = 1.500
set antigravity_gain = 2.000
set antigravity_accelerator = 5.000
set setpoint_kalman_enabled = ON
set setpoint_kalman_q = 200
set tpa_rate = 20
set tpa_breakpoint = 1200
set rc_yaw_expo = 70
set roll_rate = 70
set pitch_rate = 70
set yaw_rate = 60
# profile
profile 2
# profile
profile 3
# battery_profile
battery_profile 1
# battery_profile
battery_profile 2
# battery_profile
battery_profile 3
profile 1
battery_profile 1
# save configuration
save
