Threads: 65
Likes Received: 119 in 66 posts
Likes Given: 111
3 Hello, in reality i don't know if tittle is wrong or not but i have a strange problem.
4in1 esc , firmware blheli32 , version 32.8.
Sometimes (2 times in few months) 1 esc have a corrupted firmware.
I back home , reflash firmware and all back ok for months.
Yesterday i flashed to 32.9 and i'll try this setup.
Someone with the same problem?
Threads: 38
Likes Given: 430
118 If you can be specific with the ESC brand/specs then that will help anyone that is facing the same issue know.
Any chance you ran those flights at very low voltages? Even some FC's lose all the settings/configuration at low voltage.
Threads: 65
Likes Given: 111
3 28-Jun-2022, 08:29 AM (This post was last modified: 28-Jun-2022, 03:42 PM by zerogravity.) Esc is a diatone f50 32 pro, and is always esc 2 with that issue. Is really strange. Never low voltage, i don't like drain battery to their limit. That is the second time with 32.8 firmware. Luckily when happen i can take off and after 2 seconds drone fall in runaway error. So never done hard crash but is annoying. Now i'll check with 32.9.
