Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 That's the plan. If I don't like what I get with the 5 inch props, I will back down to 4 inch props. That IS the beauty of using a frame for 1 prop size larger. The Flywoo FC from RDQ has just arrived today, so I can get on with the build. Stay tuned .... Posts: 3,288 Threads: 129 Likes Received: 2,740 in 1,644 posts Likes Given: 2,969 Joined: Apr 2017 Reputation: 65 Staying tuned! ❤️? SoCal Kaity :D OMG, no one told me it would be this much fun! Addicted :) Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 Yeah, I know, it has been a while. I just had a lot going on and still collecting things for this build. Guess I am following Snow for long build time. Ha, Ha. Anyway...now I am getting back to it. I have received fiberglass sheets and have been redesigning the frame...will be cutting fiberglass soon. I am anxious to see how the weight compares to carbon fiber. Since a unibody frame is harder for me to fabricate, I am going with a multi-part frame; separate arms and central fuselage plates. An advantage to a multi-part frame is that I can swap arms or central plates and get different configurations. I am also working on a holder for 18650 cells that somehow will incorporate into the frame. Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 12-Jun-2021, 10:26 PM (This post was last modified: 13-Jun-2021, 01:10 PM by iFly4rotors.) 2021-06-12 I have been working on fabricating a custom frame which has been a little more interesting than I would have thought. I have went through a variety of designs. I tried to incorporate the 18650 holder, but nothing seemed to work out the way that I wanted. So...I ditched the idea of an incorporated holder and worked to simplify the design. Keep in mind that I don't have precision cutting devices so this is all fabricated with hand tools. Pictures added to Post #1 Here is a picture of the frame. 2021-06-13 Edit: At 32.5 grams, the frame is little heavier than I wanted, but I decided to leave the arms wide for strength rather than cut them down or skeletonize them. The arms are also long enough to accommodate 5 inch props. I could probably shave off several grams from these arms; plus, a set of 4 inch arms will be lighter; I will likely cut new arms which will be shorter and I might cut down the width a little, too; if I decide to go with 4 inch props. Posts: 6,106 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,733 Joined: Feb 2019 Reputation: 100 12-Jun-2021, 11:02 PM (This post was last modified: 12-Jun-2021, 11:20 PM by hugnosed_bat.) intressting material choice, i always liked to get one of those fpv360 frames :-) why did you choose splitarm over unibody? edit; found the answer in post #41 i builded with a buddy a quad 1404 2750kv on hq5030 biblades at 100g weight, we didnt try 4inch - we got 35min of true flighttime with gently freestyle. i dont remember the used battery. i cant imagine it can be even extended with 4inch :-) awaiting your results ifly :-) believing it will takes some time - in the aimed way ;-) Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 Hi Bat, I am hoping to keep the total dry weight as close to 100 grams as possible...and the race is on. Now, the actual build begins.... stay tuned... |
