Project 399 Super G+ 7inch + DJI by d00lar
#91
Yes bangood have it
AliExpress had - I bought first on Ali with better price second on bangood
But when I bought second from Ali seller canceled my order and told me that they cannot ship it anymore because it is over 100ah and this is the limit now for them and this battery is 104ah ;/
Banggood sends probably from some europe warehouse cause it arrived with in 2 weeks and I had some points because of they delay in sendinsending googles so finaly it was like 85$ for me
Ps after while I think that this lihv can do some stronger punch for me and more speed cause 1500kv is 1500rpm per volt and lihv have like almost 1volt more on 6s ;p
#92
i have alot of oscilations on pinch axis when i fly with 30-40% throttle usualy straight as on attachment
does it mean that i have to less filtering ? os something is oscilating like antena etc?
[Image: cGSMUkZl.jpg]
same on attachment with better resolution
they are about 123-128hz - can i force filter to target this frequency especialy ?
thanks Wink
#93
I wish I knew how to even look at that!
#94
(15-Jun-2021, 07:35 AM)d00lar Wrote: mine now are bearly hot now max 40 celcius so 104f
check filters etc - mine are realy hot if any vibrations happening etc - if everything is tight / props not bended etc then usualy they are cold even after hard flight
i use DALPROP CYCLONE T7056 Pro 7056 7X5.6X3 3-Blade  only
i have motor timming to 20 now and runpup power 22
do you have DYNAMIC_FILTER  enabled?
How are those T7056 Pros hold up for you? I read that the old "non Pro" had some issues. I have a couple of bags of the Pros but not tried em out yet. Are they good?
#95
i never had no pro so nothing to compare but they are really good
what issues they had ?
#96
(09-Jul-2021, 08:28 AM)d00lar Wrote: i never had no pro so nothing to compare but they are really good
I see. On 6S rigs the none pro could rip apart at the hub. The Pros have thicker connection between the hub and blades.
#97
i never had any issues - not bending to easly and uset like 10x4pcs at least Wink
[-] The following 1 user Likes d00lar's post:
  • Myman
#98
i will share with you my antenna idea
it is not the pretty one but it works with the same or better range than stock dji antennas
i bought some long one over 13cm with about 8-10cm of hard plastic
then i used lighter to heat this up and did 360 on rear arms and used some zip tights to make it not lose at all
impossible to brake / lose / disconnect
im 1000% happy with this although i check like 20 other mounting options with some tpu / sma etc
everything else i broke on some crash sooner or latter
and this is with me like 2 months , many crashes and still fine Wink
what do you guys think ?
they are mounted a 'bit' diferently especialy so polarization is not 100% equal on them - more chance of better link when not fli straight (in my opinion - im not sure if it is better or worse scenario Big Grin - imho better)
regards Wink
[Image: NgN4kLVl.jpg][Image: z0IbK32l.jpg]
#99
If you do alot of agressive flying were crashing is a high risk then its probably good as they wont rip apart/get damaged as easy.
Not sure about reception but if it works fine when you test it i dont see a problem with the mounting.
Only thing is 5.8Ghz dont like sharp bends but with the tubing i guess it cant bend that sharp anyway.
I am impressed with the flight performance you seem to get out of your quad, good for both cruising and freestyle. Might build somthing simular some day..
For now i have one cruiser and one for freestyle but would be cool to have one that can do both.
it is not so perfect for freestyle as i thought because of weight
but i guess with time i will be better of handling this weight with freestyle. power is inscredible so probably it is my skills that are writing that is havy ;P
Exclamation SDA/SCL remap on mamba DJi mini jules94 5 1,282 30-Jan-2024, 12:58 PM
Last Post: PeladoMat
Question Help INAV - Apparently random current spikes on 7inch moserello 0 405 30-Jan-2023, 02:57 PM
Last Post: moserello
  Build CHALLENGE : Sub 250 - 30 min - 10K : 4" to 5" Class : Tubular5 "DJI" Felias 0 480 22-Jul-2022, 05:47 PM
Last Post: Felias
  Build LEAP 4” Long range project Joshua_A 51 5,863 24-May-2022, 11:44 PM
Last Post: Joshua_A
  Discussion (let's debate) With the DJI antennas, gain is more important than axial ratio BigBeard 1 396 27-Apr-2022, 06:07 AM
Last Post: jasc
