My reciver is bound but not working is betaflight
So the backstory of my problem is that I first bought all my drone stuff. Soldered it correctly and got is working in betaflight (even my reciver). Then when I got to the motors tab i cranked up the motors and the esc burned up... So I bought a new stack and solderd it togheter. Now im in betaflight hell again and cant get my reciver working. I have looked all over forums and stuff but everyone just says Rx to Tx and Tx to Rx and dont forget the uart. But ofc ive checked that and its correct. (ive tried with and without battery aswell)
If you need more photos im happy to send.
Please help!
YT over drone and betaflight
[Image: BKtI1Rzl.jpg]
Can you post pictures of your work and what list what components are you using?
 Is your receiver binding/working?
Here’s a good tutorial that explains how to setup betaflight.
https://oscarliang.com/betaflight-firmware-setup/
I watched the video,
Your wiring looks correct and you are using uart 2.
You can turn on telemetry in betaflight receiver tab.
Is your radio telemetry sensors working?
When you turn off radio with receiver powered up does transmitter give a message that receiver is still on or if you power off receiver do you hear telemetry lost message?
(01-Aug-2023, 05:54 PM)Rob3ddd Wrote: Can you post pictures of your work and what list what components are you using?
Hi! yea so the reciver is steady green when i turn on the controller. Wich as far as I know means binded. (Tried rebinding worked fine). Telemetry turned on now. Radio telemetry sensors should work how do I check? Dont hear any telemetry lost message. Were should i hear that? radio?
Component list: Speedybee stack f7 BL32 50A
Walksnail HD kit v2 5,8Ghz
Emax 1700 KV
Crossfire Nano reciever
and some Rline tattu 6s bats
Radiomaster TX12
Fatshark dominator HD
.[Image: aCxqx9Il.jpg][Image: reVbuD6l.jpg][Image: PF81j3Rl.jpg][Image: K2kEcdsl.jpg][Image: xrpqEx6l.jpg]
(04-Aug-2023, 09:04 PM)Nilsson Wrote: Hi! yea so the reciver is steady green when i turn on the controller. Wich as far as I know means binded. (Tried rebinding worked fine). Telemetry turned on now. Radio telemetry sensors should work how do I check? Dont hear any telemetry lost message. Were should i hear that? radio?
Emax 1700 KV
Radiomaster TX12
   To see if the sensors are working go to the telemetry screen on your radio.
 You will see “discover new “ as you scroll down the list of sensors.Click on “discover new “ with receiver on and you will see values fill in or there will be values already there.
  [Image: UDulV4Xl.jpg]
  Another way to know if telemetry is working is on the first screen on radio you will see a set of bars next to battery bar meter with receiver and radio on.Right above the 3 in Avio 3 you will see the graph I’m referring to in the picture below.
  [Image: UvzYxVdl.jpg]
  Given the above is working should hear telemetry lost when you power off receiver with transmitter left on.
  If everything is working as in above the following video should get you setup in betaflight.
  https://youtu.be/Ypn71lIu8l8?si=nxNpWd8GSIWXkYRV
Hey!
When I press discover new noting new fills in. Its just ---. How long does it take to fill in. And maybe a retarded question but im new after all Wink but do I have to be connected to the reciver to see the telematry fill in? How do i fix it?
(29-Aug-2023, 05:59 PM)Nilsson Wrote: Hey!
The receiver led can be solid green and need updating so try rebinding the receiver using Agent Light.
It’s a quick process.
Just use Agent light and bind the receiver.You’ll see a message to update if it needs it.
If not you know for certain it’s bound and up to date.
 The telemetry sensors will fill in immediately after pressing “discover new” given telemetry is turned on in Agent light.
  If still no results,I suggest starting from the beginning,read the manual and/or by use this video to set up XF.
  https://youtu.be/Ypn71lIu8l8?si=XWjJozZ00KlLupm8
  CrossFire Connection Issues-Radio Master Zorro- No Betaflight input Apex FPV 3 162 06-May-2024, 02:35 PM
  BetaFlight Connection Issues..... Coleon 17 724 02-Apr-2024, 12:26 PM
  Betaflight 4.4.3 on Speedybee F4V4 Ladu 4 259 14-Mar-2024, 04:45 PM
Last Post: Ladu
  New FC H743 UART1 not working ken-real 3 202 28-Feb-2024, 10:28 PM
Last Post: ken-real
  No inputs after crash, still bound to reciver FPVManiac 5 234 03-Feb-2024, 10:05 PM
