23-Jun-2020, 09:32 AM
In the mean time I now have the Mobula 6 and 7 both running BF4.2 and with RPM filtering enabled (JESC).
No issues whatsoever. They fly very nicely.
Mobula 7 HD does not retain its settings |
23-Jun-2020, 09:32 AM In the mean time I now have the Mobula 6 and 7 both running BF4.2 and with RPM filtering enabled (JESC). No issues whatsoever. They fly very nicely. 12-Aug-2020, 05:30 PM 03-Oct-2020, 03:53 PM (12-Aug-2020, 05:30 PM)Oxize Wrote: I still have problems. Running also BF 4.2.0, and the lastest JESC. Hi. I'm experiencing this problem too. Does anyone have a fix? I have just bought a Mobula 7 HD (with a Crazybee F4FS Pro v3). I've plugged into Betaflight, set all my settings - modes, pids, rates, OSD options. All saved fine. However, after unplugging the drone, when I go back into Betaflight a short time later all the settings have been lost. The drone initially came with Betaflight 4.1.1 and when I started to experience this issue I decided to flash to 4.2.3. But the problem still persists. Any suggestions? Is it likely to be an issue with the ESC? Or am I just doing something wrong? I've not flown it yet and I've only put in a couple of lipos, which were flat (I'm still waiting for my charger to arrive!). Total noob so apologies if non of the above makes sense. 05-Oct-2020, 10:21 AM (03-Oct-2020, 03:53 PM)m0nkmaster Wrote: Hi. I'm experiencing this problem too. Does anyone have a fix? I've managed to figure out what's going on here so I just wanted to note it down here, you never know, it might be useful to someone else. I found that it was a problem caused by one of my batteries! When I connected this one particular battery to my drone all the Betaflight setup got wiped. When I plugged this battery into the charger I got the error "The voltage of single cell is too high or too low". So it's a broken battery! Weird but that was the problem for me - connect the battery, bam all the config lost. Since disposing of that battery, I've not had any config loss. |
Help Problem binding Happy Model Mobula 6 to Radiometer tx16s | zdviet | 2 | 156 | 29-May-2024, 03:45 AM Last Post: Suros | |
Mobula 8 FC replacement | soky157 | 9 | 201 | 25-May-2024, 12:23 AM Last Post: Rob Axel | |
Help Need help connecting Mobula 8 and Meteor 85 to Radiomaster Pocket. | Todd_Froggington | 7 | 343 | 14-May-2024, 03:20 AM Last Post: SeismicCWave | |
Help Mobula 8 not binding/not flashing | Todd_Froggington | 5 | 316 | 12-May-2024, 12:05 AM Last Post: SeismicCWave | |
Mobula 8 X12 5-IN-1 AIO FRSKY missing beeper ? | norseman73 | 2 | 223 | 30-Mar-2024, 06:53 PM Last Post: norseman73 |
