Long Range Leap
#31
Still doing the same thing. Can't be right....
Deal
Here's the Deal
10" 6S FR10-G Long Range, 5" 6S Rooster, 5" 6S Badger, 5" 6S QAV-S, 5" 4S Badger, 5" 4S Phreakstyle Slam, 5" 6S Yema, 5" 4S Stark, 3" 4S Gecko, and a 3S 2.5" Tadpole, all of which are Crossfire.  Tinyhawk, Tinyhawk S, and a DJI Spark.  And projects on the bench....
#32
Now the module doesn't even say updating anymore....
Deal
Here's the Deal
#33
My patience ran out so I unplugged everything and shut down everything. Retried, and BOOM, success. Updated module and VTX in about 15 seconds each, hehe. It was definitely frozen.
I assume I do the same for the diversity Nano RX once I get power to it.
Deal
Here's the Deal
#34
(03-Dec-2019, 06:00 PM)Deal-E-O Wrote: FR10-G frame ordered, paid for, and being cut today.  Motors to arrive Friday.
Coolness!
GPG module and Crossfire gear, for the most part, has arrived.  So have some questions, with more to come I'm sure, hehe.
Sorry for the re-asking of a question or two here, but this will keep any answers organized for me to refer to in the future.
I have a Taranis X9D+, non-2019 version, with an aftermarket 3S battery inside.  I read that the input voltage range for the LITE is 3.5-13V, so I'm okay keeping the 3S battery, correct?
If I'm running 1W or greater should I still use an external power source, or it will the 3S battery in the radio suffice?  And if an external battery is needed, I need suggestions for those.
Running high wattage will drain the TX battery fast.  Even at 500mW running from the TX will eat the battery.  If you don't want to field charge the TX battery or swap out TX batteries all the time, get a external battery.  When you attach it to a TX kickstand it's very convenient.  I have a 2000mAh battery for my external and I've never ran the battery low at 500mW with several hours of flying.  If you think you may run at 1-2W a lot and fly most of the day, you may want to go bigger than 2000mAh.  That's one of those things that you have to figure out from trial and error.   A kickstand is one of THESE if you don't know what I'm talking about.  Not recommending this one necessarily, just for info.
With the True-Mox 915, it is placed in a vertical position, not flat, correct?  Vertical polarization....
Yes, vertical polarization and not flat is vertical. Big Grin
Using TBS Agent, when plugged into a USB it says it doesn't recognize the device and asks me to update.  I say yes, it says update finished, and I click okay, but then the screen comes back up and says device not recognized and asks to update.  Click yes and the screen goes away.  It shows the device under the name, but firmware version 1.08, but I read somewhere that there is/was a 1.13.  Is this working correct?  I checked the  module with Agent, and firmware is up to date at 2.42.  Correct?
After all this I realized I had an old version of TBS Agent....  Correcting that now and hopefully everything can be update to the latest firmware versions.
So, you're ok with updating or not?
Deal
#35
Everything is updated, I think, and I hope to get it setup on one of my quads by this weekend. As long as I can get everything wired correctly....
Deal
Here's the Deal
#36
Okay LITE installed on radio. When using the "joystick" on the back of the LITE to change the RF power, if I select 1W or 2W it gives me a warning it might damage my remote. Do I just leave it at 500mW until I have an external battery? And speaking of this battery, is there a preferred "C" rating?
Deal
Here's the Deal
#37
Just lost my entire post. I'll try again....
On Oscar's blog he wired the non-diversity Crossfire Nano Rx with just four wires. There are a lot more options with the Diversity model. Do I use those same instructions, but add additional wires between the Diversity Nano and the Unify Pro32(ch3 and ch4)? Crossfire Receiver (CRSF TX)→Unify PRO32 (CRSF RX) and Crossfire Receiver (CRSF RX)←Unify PRO32 (CRSF TX) is stated in the Pro32 manual. How/Where do I wire the backup battery connection on the Diversity Nano to?
Is there any other benefit to powering and grounding the FPV camera through the Unify Pro32 other than freeing up pads on the FC?
Wow, Crossfire can be a little daunting, but I believe it will be worth it in the end.
Deal
Here's the Deal
#38
My understanding is, if you wire the Unify to the Nano, you can use Crossfire Lua Script or the LCD on the Lite to change and view VTX settings. If you wire the Unify to the FC, then you can only change VTX settings through OpenTX Lua Script and the BF CMS menu.
Some people say the powering the camera through the VTX provides cleaner video due to common ground and extra power filtering by the VTX.
#39
Thanks. I'll go the Unify Pro32-Nano route, and my first ever camera power through the Unify Pro32. What about the backup battery connection wiring?
Deal
Here's the Deal
#40
(04-Dec-2019, 08:27 PM)Deal-E-O Wrote: Thanks. I'll go the Unify Pro32-Nano route, and my first ever camera power through the Unify Pro32. What about the backup battery connection wiring?
Deal
I haven't found any great way to run the external lipo.
#41
Me neither. Still looking for ideas on the external LiPo for the Crossfire LITE as well.
Deal
Here's the Deal
#42
Motors have arrived. Antennas have arrived. Frame has shipped....
All I'm missing is an FC, ESC's, and some props. Getting close now....
Deal
Here's the Deal
[-] The following 1 user Likes Deal-E-O's post:
  • Krohsis
#43
(07-Dec-2019, 07:59 PM)Deal-E-O Wrote: Motors have arrived.  Antennas have arrived.  Frame has shipped....
Deal
In case you aren't excited....yeah right! Big Grin
You can look at your frame HERE...
#44
A little info on the backup battery for the Crossfire Diversity Nano. I found this video on YouTube. At around the 10:00 mark he talks about it. Apparently you have to provide a 1S battery and wire it directly to the RX.
The issue I have with this is that the battery would always have a charge on it. So you'd be keeping a 1S battery in various states of charge on you quad at all times.... You'd think they could have came up with something similar to how the buzzers with their own batteries. Maybe that's in the works for the future, hehe.
Deal
Here's the Deal
#45
I personally believe if you're flying LR you need to have an independant system like Marco Polo.  But that is just me.  All the other stuff is mediocre at best, and completely worthless typically.  A buzzer is almost worthless on a LR platform.  And this system with the Diversity Nano is a hassle to do correctly like Deal mentions.   MP is a bit costly at 250.00, but recovering a lost quad will have it pay for itself double.  With a range of a 2 mile radius, if you can't tell where you went down within 2 miles, well your situational awareness sucks.  But I understand why 250.00 is a tough pill for some to swallow.  So far as I know, MP has been 100% in recoveries by those I know have used it.  And it is almost zero hassle to use.
But if you fly with the Diversity Nano you won't need a separate battery if you fly with Velcro or 3M dual lock, you will NEVER eject a battery.  Umagrip, well....you may want to check prices on a 1S battery.  Big Grin
  Long Range Setup für 2024 Kepnik 1 530 16-Mar-2024, 12:15 AM
Last Post: Phoenix.-
  5" Mid range motor sizing help B4tn 4 399 01-Mar-2024, 12:25 AM
Last Post: B4tn
  Build APEX 6 HD long range MomoBrut 34 4,147 15-Jan-2024, 02:23 PM
Last Post: Diver
  Build Best Long Range Antenna for O3 Airunit Akuzo 7 4,864 10-Jan-2024, 01:45 PM
Last Post: Klingus
  Long range on a different axis 33km out mstc 0 413 22-Dec-2023, 06:01 PM
