Is there a way to run TBS Agent X on Linux ? (Crossfire)
paralells desktop does provide user friendly graphic interface, but not for free. trial might work?
(10-Feb-2021, 03:08 PM)hugnosed_bat Wrote: paralells desktop does provide user friendly graphic interface, but not for free. trial might work?
it worked.
along the way i had bricked the controller, then revived it using impulcerc driver fixer blah b;lah....
[-] The following 1 user Likes doronba's post:
  • hugnosed_bat
Good news. At least you got it working.
When the TBS Agent M app is officially released with its full set of features, you'll be able to flash new firmware to your TBS products from your mobile phone, assuming you have an Android phone that is and not an iPhone.
#19
Yes, this will be nice.
But now I have the same problem as many other people had, and i have read some of the long threads....
There is binding between the tx and rx (green lights), but no stick movement in betaflight.
I copied an existing model, then I replaced the internal rf with the CRSF.
the FC is success-e f405
the connections are as follows :
the 3rd pad (counting from 1=GND) in the nano rx ---->  R2 in the FC
the 4th pad in the nano rx ----> T2 in the FC
photo : https://photos.app.goo.gl/7ZLg7Z7KJ34Ff1wo6
and in betaflight i also set everything as i undersood.
Snow - you are the master in this field - what cli command should i type to finally see the sticks movement and be able to arm the quad (i did not mention it, but i can not arm with the switch) ?
thnx
#20
Your wiring looks fine. Can you please run both the "dump" and "diff all" commands in the Betaflight Configurator CLI tab and copy/paste the results back here.
#21
# dump
# Betaflight / BETAFLIGHTF4 (BFF4) 4.0.4 Jun 30 2019 / 14:01:59 (f3a95efa3) MSP API: 1.41
# start the command batch
batch start
board_name BETAFLIGHTF4
manufacturer_id
# name
name SOURCE 1
# resources
resource BEEPER 1 B04
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 C09
resource MOTOR 4 C08
resource MOTOR 5 B06
resource MOTOR 6 NONE
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 B08
resource PWM 1 B08
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource LED_STRIP 1 B06
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 NONE
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 C06
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource INVERTER 1 NONE
resource INVERTER 2 C13
resource INVERTER 3 NONE
resource INVERTER 4 NONE
resource INVERTER 5 NONE
resource INVERTER 6 NONE
resource INVERTER 7 NONE
resource INVERTER 8 NONE
resource INVERTER 9 NONE
resource INVERTER 10 NONE
resource INVERTER 11 NONE
resource INVERTER 12 NONE
resource I2C_SCL 1 NONE
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SDA 1 NONE
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource LED 1 B05
resource LED 2 NONE
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource ESCSERIAL 1 B08
resource ADC_BATT 1 C02
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 C01
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource COMPASS_CS 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 A15
resource OSD_CS 1 B12
resource GYRO_EXTI 1 C04
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A04
resource GYRO_CS 2 NONE
resource USB_DETECT 1 C05
# timer
timer B08 AF3
# pin B08: TIM10 CH1 (AF3)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer A09 AF1
# pin A09: TIM1 CH2 (AF1)
timer A10 AF1
# pin A10: TIM1 CH3 (AF1)
timer A02 AF2
# pin A02: TIM5 CH3 (AF2)
timer A03 AF3
# pin A03: TIM9 CH2 (AF3)
timer B10 AF1
# pin B10: TIM2 CH3 (AF1)
timer B11 AF1
# pin B11: TIM2 CH4 (AF1)
# dma
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 1
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin B08 NONE
dma pin B00 0
dma pin B01 0
dma pin C09 0
dma pin C08 0
dma pin B06 0
dma pin A09 0
dma pin A10 0
dma pin A02 0
# pin A02: DMA1 Stream 0 Channel 6
dma pin A03 NONE
dma pin B10 0
dma pin B11 0
# pin B11: DMA1 Stream 7 Channel 3
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mix
smix reset
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature SOFTSERIAL
feature TELEMETRY
feature LED_STRIP
feature OSD
feature AIRMODE
# beeper
beeper -GYRO_CALIBRATED
beeper -RX_LOST
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper ARMING_GPS_NO_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper RX_SET
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon -RX_LOST
beacon RX_SET
map TAER1234
serial 0 2048 115200 57600 0 115200
serial 30 32 115200 57600 0 115200
led 0 10,0::CB:10
led 1 10,1::CB:10
led 2 10,2::CB:4
led 3 10,3::CB:4
led 4 10,4::CB:2
led 5 10,5::CB:2
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 0 0 0 1650 2100 0 0
aux 1 1 1 900 1300 0 0
aux 2 2 1 1300 1700 0 0
aux 3 13 2 900 1325 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# rxrange
rxrange 0 1000 2000
rxrange 1 1000 2000
rxrange 2 1000 2000
rxrange 3 1000 2000
# vtx
vtx 0 0 0 0 900 900
vtx 1 0 0 0 900 900
vtx 2 0 0 0 900 900
vtx 3 0 0 0 900 900
vtx 4 0 0 0 900 900
vtx 5 0 0 0 900 900
vtx 6 0 0 0 900 900
vtx 7 0 0 0 900 900
vtx 8 0 0 0 900 900
vtx 9 0 0 0 900 900
# rxfail
rxfail 3 h
rxfail 5 h
# display_name
display_name -
# master
set gyro_sync_denom = 2
set gyro_lowpass_type = BIQUAD
set gyro_lowpass_hz = 150
set gyro_lowpass2_type = PT1
set gyro_lowpass2_hz = 150
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_calib_duration = 125
set gyro_offset_yaw = 0
set yaw_spin_recovery = ON
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_range = AUTO
set dyn_notch_q = 120
set dyn_notch_min_hz = 150
set dyn_lpf_gyro_min_hz = 150
set dyn_lpf_gyro_max_hz = 450
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_pitch = 0
set acc_trim_roll = 0
set acc_calibration = -200,13,73
set align_mag = DEFAULT
set mag_bustype = I2C
set mag_i2c_device = 2
set mag_i2c_address = 0
set mag_spi_device = 0
set mag_hardware = NONE
set mag_declination = 0
set mag_calibration = 0,0,0
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 2
set baro_i2c_address = 0
set baro_hardware = NONE
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set min_check = 1050
set max_check = 1900
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RPYT
set rc_interp_int = 19
set rc_smoothing_input_hz = 0
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_provider = CRSF
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set serialrx_halfduplex = OFF
set adc_device = 1
set blackbox_p_ratio = 32
set blackbox_record_acc = ON
set blackbox_mode = NORMAL
set min_throttle = 1070
set max_throttle = 2000
set dshot_idle_value = 200
set dshot_burst = OFF
set dshot_bidir = OFF
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 5
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_hysteresis = 1
set current_meter = ADC
set battery_meter = ADC
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_lpf_period = 30
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_scale = 400
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set small_angle = 25
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_rescue_angle = 32
set gps_rescue_yaw_p = 40
set gps_rescue_min_sats = 8
set gps_rescue_min_dth = 100
set gps_rescue_use_mag = ON
set deadband = 0
set yaw_deadband = 0
set pid_process_denom = 1
set thrust_linear = 0
set transient_throttle_limit = 15
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = OFF
set osd_warn_rc_smoothing = OFF
set osd_warn_fail_safe = OFF
set osd_warn_launch_control = OFF
set osd_warn_no_gps_rescue = OFF
set osd_warn_gps_rescue_disabled = OFF
set osd_rssi_alarm = 20
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_vbat_pos = 2413
set osd_rssi_pos = 2403
set osd_tim_1_pos = 234
set osd_tim_2_pos = 2422
set osd_flymode_pos = 2092
set osd_g_force_pos = 234
set osd_throttle_pos = 2086
set osd_vtx_channel_pos = 234
set osd_crosshairs_pos = 205
set osd_ah_sbar_pos = 206
set osd_ah_pos = 78
set osd_current_pos = 234
set osd_mah_drawn_pos = 234
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 234
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 234
set osd_gps_lat_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 234
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_power_pos = 234
set osd_warnings_pos = 2282
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_nvario_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_core_temp_pos = 234
set osd_log_status_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = OFF
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_endbatt = ON
set osd_stat_battery = ON
set osd_stat_min_rssi = ON
set osd_stat_max_curr = OFF
set osd_stat_used_mah = OFF
set osd_stat_max_alt = OFF
set osd_stat_bbox = OFF
set osd_stat_bb_no = OFF
set osd_stat_max_fft = OFF
set osd_profile = 1
set system_hse_mhz = 8
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set scheduler_optimize_rate = OFF
set vtx_band = 5
set vtx_channel = 8
set vtx_power = 3
set vtx_freq = 5917
set vtx_pit_mode_freq = 0
set vtx_halfduplex = ON
set vcd_video_system = AUTO
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set led_inversion = 0
set dashboard_i2c_bus = 2
set dashboard_i2c_addr = 60
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 3
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_2_bustype = SPI
set gyro_2_spibus = 1
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_rpm_notch_q = 500
set gyro_rpm_notch_min = 100
set dterm_rpm_notch_q = 500
set dterm_rpm_notch_min = 100
set rpm_notch_lpf = 150
# profile
set dyn_lpf_dterm_min_hz = 150
set dyn_lpf_dterm_max_hz = 250
set dterm_lowpass_hz = 150
set dterm_lowpass2_type = PT1
set dterm_lowpass2_hz = 100
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_gain = 5000
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set smart_feedforward = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 20
set iterm_windup = 100
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 0
set throttle_boost = 5
set acro_trainer_gain = 75
set p_pitch = 46
set i_pitch = 70
set d_pitch = 38
set f_pitch = 75
set p_roll = 42
set i_roll = 60
set d_roll = 35
set f_roll = 70
set p_yaw = 35
set i_yaw = 100
set d_yaw = 0
set f_yaw = 0
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 20
set d_min_pitch = 22
set d_min_yaw = 0
set d_min_boost_gain = 27
set d_min_advance = 20
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
# rateprofile
set thr_mid = 50
set thr_expo = 0
set rates_type = BETAFLIGHT
set roll_rc_rate = 100
set pitch_rc_rate = 100
set yaw_rc_rate = 100
set roll_expo = 0
set pitch_expo = 0
set yaw_expo = 0
set roll_srate = 70
set pitch_srate = 70
set yaw_srate = 70
set tpa_rate = 50
set tpa_breakpoint = 1500
set tpa_mode = D
set throttle_limit_type = OFF
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
# end the command batch
batch end
# diff all
batch start
defaults nosave
manufacturer_id
mcu_id 0035005c324d501020303256
signature
# name
name SOURCE 1
# resources
# timer
# dma
# servo
# servo mix
feature SOFTSERIAL
feature LED_STRIP
# beeper
beeper -RX_LOST
beeper -DISARMING
beeper -ARMING
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -READY_BEEP
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -CRASH_FLIP
# beacon
beacon RX_SET
map TAER1234
led 0 10,0::CB:10
led 1 10,1::CB:10
led 2 10,2::CB:4
led 3 10,3::CB:4
led 4 10,4::CB:2
led 5 10,5::CB:2
# color
# mode_color
# rxrange
# vtx
# rxfail
rxfail 3 h
# display_name
# master
set vtx_band = 5
set vtx_channel = 8
set vtx_power = 3
set vtx_freq = 5917
# profile
# profile
profile 1
# profile
profile 2
# rateprofile
# rateprofile
rateprofile 1
# rateprofile
rateprofile 2
# rateprofile
rateprofile 3
# rateprofile
rateprofile 4
# rateprofile
rateprofile 5
# save configuration
save
#22
People have a lot of problems with UART2 on the iFlight SucceX F405 FC's.
Try running the following CLI commands and see if that makes any difference:-
resource INVERTER 2 NONE
save
Also, with the Crossfire Nano RX powered up, run the Crossfire LUA script on your transmitter, connect to the XF Nano RX and check under the Output Map section that Channel 1 is set to CRSF TX and Channel 2 is set to CRSF RX.
#23
(10-Feb-2021, 09:36 PM)SnowLeopardFPV Wrote: People have a lot of problems with UART2 on the iFlight SucceX F405 FC's.
save
the code did not change anything.
i don't understand clearly everything that you mentioned in the second part.
today i did update the firmware of the qx7, it seems that it is acting weird, for example, now, while the rx is off, the crossfire module is inside the controller - and i couldn't get to the main menu by long pressing the menu button (also all the scrollings were very slow).
then, when i powered off the controller, took out the crossfire module, and powered on again, i could access the radio menu.
but it means, that while the rx is on (lipo connected to quad), and the crossfire module is in, i can't access the lua scripts (unless i don't understand something crucial).
everything here is new to me : lua, module, etc....
please enlighten me a bit :-)
EDIT :
I  managed to understand everything actually..
and everything is set as you said : Channel 1 is set to CRSF TX and Channel 2 is set to CRSF RX
I have'nt checked it in betaflight, but the quad does not arm. should it be something with betaflight setting that i forgot ? maybe in the modes tab ? just guessing....
meanwhile, i will connect to betaflight to see if there is something new...
#24
Before we go any further, have you done the Crossfire inverter mod on your QX7?
#25
1. yes. and it seems very well done, no smoke... LOL and other drones do fly well without the CSRF
2. i have now connected to betaflight, and there are no stick movements nor switches movements in the modes tab.
3. another weird behavior appears : after disconnecting the lipo, it takes 2 seconds before my taranis tells me loudly that there is no connection (i forgot for a second what the exact words are).
well ? LOL
#26
Is your QX7 on the latest version of OpenTX (currently 2.3.11)?
#27
(10-Feb-2021, 10:45 PM)SnowLeopardFPV Wrote: Is your QX7 on the latest version of OpenTX (currently 2.3.11)?
yes. did the update today
and it actually doesn't feel as smooth as my original version.
is it logic at all ?
#28
What is the baud rate of your transmitter set to?
#29
(10-Feb-2021, 10:55 PM)SnowLeopardFPV Wrote: What is the baud rate of your transmitter set to?
400.000
do you think that changing the connection to r3 and t3 and enable uart2 in betaflight might be the sumplest solution ?
#30
(10-Feb-2021, 11:06 PM)doronba Wrote: 400.000
You can try doing that but it doesn't explain the laggy menus in your QX7 or the inability to run the Crossfire LUA script. You usually only get those symptoms without the inverter mod, or with the baud rate set too high (where no inverter mod has been done). I'm wondering if you managed to mess something up with your transmitter when you did the inverter mod, or if there's a bad connection and it's just not working properly.
Try lowering the baud rate to 115,200 and see if the laggyness goes away and if you can then run the Crossfire LUA script.
  Discussion TBS Crossfire wllmlutz 8 1,810 16-Feb-2024, 07:17 PM
Last Post: IanS
  No 3d fix in new TBS GPS Apprehensivepilot 7 1,103 10-Mar-2023, 03:55 PM
Last Post: Apprehensivepilot
  TBS Caipirinha II battery with AtomRC Swordfish Aer0baticCat 3 1,142 01-Dec-2022, 03:20 AM
Last Post: burkeomatic
  How to use a TBS Crossfire 8ch with a TBS Wing Layer Aer0baticCat 0 455 07-May-2022, 08:45 PM
Last Post: Aer0baticCat
  TBS podracer AIO luke2152 1 766 23-Dec-2021, 12:57 AM
