01-Apr-2024, 06:36 PM
It has always been a bit of an Achilles heel with INAV that any of the autonomous flight modes including Return To Home required an active working compass to be connected to the FC. Well with the release of INAV 7.1 this is no longer the case. You can use all autonomous flight modes without a compass. This is achieved with the use of some clever new sensor fusion logic in INAV 7.1 which is able to determine the heading of the quad without the use of a compass. See Pawel's video below for a demonstration.
Pawel mentions at the end of the video that a compass is still required to initially set up INAV after which the compass can then be disabled, but someone in the comments has pointed out that you don't to do that and can just set the compass type to "FAKE" which will then let you configure the autonomous navigation modes after which you can then disable the fake compass completely.
