Threads: 2
Likes Received: 0 in 0 posts
0 Id like to add more down tilt to the camera on my fpv wing, but the allowed range for artificial horizon offset is only -2 - 2. Running inav 7. Is there a way to increase this allowable range? i also tried using camera tilt angle in osd settings but that didnt seem to make any difference. Right now im using horizon offset of 2 and that does work, just not enough to get my horizon where it needs to be. using dji o3 if that makes any difference. i do have it in betaflight osd mode to make it work properly with dji.
Threads: 1
Likes Received: 11 in 11 posts
Likes Given: 1
1 if you're using "osd_horizon_offset" then you limit is +2/-2 degrees as you have it but that is for the entire OSD including the side bars. for pixel osd (not sure under what your dji 03 goes) use "osd_ahi_vertical_offset". if you want only to shift your AHI then try using "osd_camera_uptilt". also play around with "osd_ahi_camera_uptilt_comp" on/off to see if that gets you the result you want.
