Hi Guys,
I'm new to LoRa, till now I only fly semi LoRa with a LW GEPRC Crocodile Baby 5".
At the last weeks I build an 7" from the GEPRC Crocodile 7 analog frame version which was on Sale at GEPRC.
My Setup is following:
-GEPRC Crocodile 7" analog Frame (I constructed all TPU Parts)
-Emax ECO II 2807 1300kV
-DJI Air Unit with Nebula Pro cam and long iFlight Albatross Antennas.
-868Mhz ELRS @ Frsky R9 Slim+ (Immoral T Antenna and DIY Dipole Antenna which is tuned)
-iFlight F7 FC
-iFlight 55A ESC
-Flywoo GPS with compass
-Vifly Finder 2
-6S 3200mAh 75C (I guess 60C or a little bit lower is the true C rate)
So far I've only flown with the 3200mAh Lipo. I already have 21700 Molicel P42A and experience with spot welding li-ion packs.
With the 7" I'm not sure which variant is the smartest. 3 rows with 2 cells each or all cells in two rows.
With the long version, the space for the gopro is tight.
What do you think is the smartest solution?
![[Image: IMG-20230109-110210.jpg]](https://i.ibb.co/CsSZ6kZ/IMG-20230109-110210.jpg)
![[Image: IMG-20230109-110339.jpg]](https://i.ibb.co/tcJhtv2/IMG-20230109-110339.jpg)
br
TC×FPV
-iFlight F7 FC
-iFlight 55A ESC
-Vifly Finder 2
br
TC×FPV
