Help please receiver
(06-May-2019, 09:06 PM)SnowLeopardFPV Wrote: That final dump is much better. Now it's readable :)
You say you have the yellow (IBUS) wire from the FS-XB6 to the RX1 pad on your FC. Are you sure about that? Your Betaflight settings are configured for Serial RX and IBUS Telemetry on UART3, so if your yellow IBUS wire really is connected to the RX1 pad (UART1) then nothing is going to work.
Until you are able to confirm the actual receiver to FC wiring with some photos then I can't explain why you're seeing VBAT on your transmitter, because that would come via the telemetry data between the FC and receiver, but according to your wiring description and Betaflight configuration settings, I don't see how that can be possible. Photos of the wiring will hopefully reveal more.
Hi snowleopardFPV , here is a link to a picture, its wired the same way as it is in picture
https://drive.google.com/file/d/0B6gin9G...p=drivesdk
If you have it on R3, try turn off IBUS telemetry. See if you get controls working.
Do as Voodoo said.
The X6B doesn't have bi-directional IBUS support so it doesn't get telemetry over IBUS. The X6B has a dedicated voltage sensor port for detecting VBAT. Therefore, the fact that you have IBUS telemetry switched on for UART3 is probably causing a conflict. I think that switching that off will solve your issue.
#19
Ok guys thanks for your help, iv been onto speedybee and they said to use rx2 ,
So i now have it on rx2 again, with same result?
****Your say switch off ibus telemetry but how do i do that***** ?
Speedybee said i need to go into cli and input
Set serialrx_provider =ibus save ???
They also said to input
Serial 1 64 115200 57600 0 115200
Serial 4 1 19200 57600 0 115200
So do i need to do that ? Will it do anything?
#20
You enter these commands in the CLI.
  • Leej8
#21
(07-May-2019, 09:46 PM)Leej8 Wrote: Ok guys thanks for your help,  iv been onto speedybee and they said to use rx2 ,
The following command sets the serial provider to be "IBUS" but you already have that set correctly so you don't need to run that command.
set serialrx_provider = ibus
save
The following command sets "Serial RX" to be switched on for UART2. You need to run this command.
save
The following command sets "MSP" to be switched on for UART5 but you already have that set correctly so you don't need to run that command.
serial 4 1 19200 57600 0 11520
save
You should also additionally also run the following command to ensure that both "Serial RX" and "IBUS Telemetry" is switched OFF on UART3.
serial 2 0 19200 57600 0 11520
save
  • Leej8
#22
Snowleopardfpv you are a star ! I don't know how i made that mistake of setting ibus in telemetry,
As you said turn it off and bang , all is now working as it should,
You guys should get paid for the work you put into this site ,
Thanks very very much.
Lee
#23
Solved!
#24
(09-May-2019, 08:14 PM)Leej8 Wrote: Solved!
Don't forget to rate them for their help! Big Grin
I'm really IntoFPV
[-] The following 1 user Likes bffigjam's post:
  • Leej8
  SpeedyBee Not Talking to Spektrum Receiver BobMaine 7 2,455 20-Jun-2024, 10:01 AM
  Receiver doesn't show up in Betaflight asdvcd 3 182 10-Jun-2024, 11:22 PM
Last Post: asdvcd
  2 Receiver on FC Eyes.fpv 9 278 28-Apr-2024, 09:50 PM
Question What is the best antenna for goggles with ONE receiver (Ls800d)? samysh 16 1,066 14-Mar-2024, 07:11 PM
Last Post: brettbrandon
  Connecting IA10B receiver to SpeedyBee F4V4 Ladu 2 187 12-Mar-2024, 05:46 PM
Last Post: Ladu
