(06-May-2019, 09:06 PM)SnowLeopardFPV Wrote: That final dump is much better. Now it's readable :)Hi snowleopardFPV , here is a link to a picture, its wired the same way as it is in picture
You say you have the yellow (IBUS) wire from the FS-XB6 to the RX1 pad on your FC. Are you sure about that? Your Betaflight settings are configured for Serial RX and IBUS Telemetry on UART3, so if your yellow IBUS wire really is connected to the RX1 pad (UART1) then nothing is going to work.
Until you are able to confirm the actual receiver to FC wiring with some photos then I can't explain why you're seeing VBAT on your transmitter, because that would come via the telemetry data between the FC and receiver, but according to your wiring description and Betaflight configuration settings, I don't see how that can be possible. Photos of the wiring will hopefully reveal more.
https://drive.google.com/file/d/0B6gin9G...p=drivesdk
