Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 12-Jun-2022, 01:39 PM (This post was last modified: 18-Sep-2022, 04:28 PM by iFly4rotors.) 2022-06-12 GT-LT6-X1 (sub-250 6 inch) Build # 16 Last Post My Journal GT-LT6-X1 is build #16 and is intended to be a sub-250 gram 6 inch craft. Even though this is a 6 inch build, it is not intended for Long Range, so I am posting this in the Mini-Quad section. The quad will be a very light weight cruiser. The frame is one of gt40's custom designs. Thank You gt40. Contact gt40 if you want one of these frames. It is the same frame used in gt40's custom 6" lightweight build . I really like the design; It is very strong, very light, and looks really COOL My bottom plate weighed in at 32.4 grams; the top plate weighs 4.5 grams; this brings the total frame weight (less any hardware - not supplied) to about 36.9 grams. This is the lightest 6 inch frame that I have seen so far. Plus, it is drilled for 20x20, 30x30, and 26x26 whoop FC boards. I just had to have one. With this frame, I believe that I can build a decent sub-250 gram 6 inch quad. WOW !!! My goal is to have a nice 6 inch cruiser that fits my easy cruising flying style. It will be interesting to see how my build compares to gt40's custom 6" lightweight build . _______________ PARTS LIST ___________________________ Frame: Custom 6 inch design by gt40 Cam Brace: FC: iFlight BEAST H743 55A AIO (whoop) Motors: BrotherHobby VY 1507 4150 KV w 5mm prop shaft HGLRC Aeolus 1804 3500kv T-Mount VTX: VTX Antenna: Camera: Foxeer Razer Nano 1200 TVL <-- this is my standard camera. Camera: Caddx Baby Ratel 2 Rx Receiver: FrSky XM+ (ACCST) <------- I have a bunch of these in the parts bin. RX Antenna: included with receiver GPS: Matek M8Q-5883 Capacitor: 1000 uf 35V <------- I have a bunch of these in the parts bin. Props: ============================================================== 2022-07-19 I have found enough components in the parts bin to complete this build. There was an unused JHEMCU GHF405 35A AIO that I have had for a while now, so it very likely has all good chips on it. I bought this before all the chip shortages. Of the motors that I have found, I think that the BrotherHobby 1507 4150KV motors should work just fine since the 1504.5 version of this motor spins 5 inch props just fine. Since the 1507s have a 5mm prop shaft, they will work with the variety of props that I have with 5mm hub hole; 6 inch, 5 inch, and maybe 7 inch {yeah, 7 inch props will actually fit on the frame}. Even with the 6 inch props, I will offset the motor height on one of the diagonal motor sets as the clearance is extremely tight. With the offset, the 7 inch props will also work. These motors weigh 16.5 grams each with wires. These motors and the frame are coming in a about 100 grams. That leaves me a 50 gram allowance for the electronics and props. If I can get this thing built with a dry weight at 150 grams, then I will be very pleased. I found a Caddx Baby Ratel 2 which I want to try. If I like it, then I will keep it, if I don't, then I will swap it out for the Foxeer Razer Nano. 2022-07-23 I plugged a USB cable into the JHEMCU GHF405 to work on the Betaflight settings, however it would not power up. Grrrr. So...back to the parts bin. I have a brand new (Mfg Date 2020) iFlight BEAST H743 55A AIO (whoop) that I will use. Hey, why not. This is a good build for that FC. Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 12-Jun-2022, 01:41 PM (This post was last modified: 12-Jun-2022, 01:42 PM by iFly4rotors.) The BUILD continues: This will be the actual build process. • Posts: 6,106 Threads: 172 Likes Received: 2,283 in 1,830 posts Likes Given: 4,733 Joined: Feb 2019 Reputation: 100 13-Jun-2022, 12:12 AM (This post was last modified: 13-Jun-2022, 12:12 AM by hugnosed_bat.) maybe an unify nano pro32 at 1g, as no lr is aimedi would use the lightweight stock dipole. what motorsize and voltage will you choose for your goal or what directions do you aim? • Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 (13-Jun-2022, 12:12 AM)hugnosed_bat Wrote: maybe an unify nano pro32 at 1g, as no lr is aimedi would use the lightweight stock dipole. what motorsize and voltage will you choose for your goal or what directions do you aim? Hi Bat, Since I don't fly ACRO and this build wouldn't be that anyway...it is an "easy cruiser" so I don't need a lot of "hi-performance" ... just need enough to take off and cruise. So... I am thinking something between 1507 and 2004 motors with high enough KV to only need a 3S battery. I want Fly Time, not 2 minutes of gut wrenching stunts. Also, I want to keep the total motor weight as much below 80 grams as I can get. I would like to keep the frame and motors less than 120 grams. I haven't decided on the VTX, but I will want it small. I actually have a couple that are very tiny one...yeah, I don't need super high mW. Yeah, I might just use the dipole that comes with the VTX. Keep it light. I will try to use the supplied top plate, but will fabricate my own if I need to. It just depends on how things fit together. I do want the battery on top so that will have some bearing on the build. It will be interesting. • Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 2022-06-27 UPDATE This build will be delayed a bit due to receiving two Faulty FC boards. I had purchased two JHEMCU GH743 F7 40A AIO (whoop) boards; one for the Rescue Quad and one for this build. Sadly, both boards have failed. So, now I am looking through my parts bin to see what FC boards I have that might be used. The first board will go in the Rescue Quad. If I find a second board, it will go in this build. What I don't find, I will have to buy. So, we will just see how much things are delayed by this little issue. • Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 2022-07-09 With the Rescue Quad back together and operational, I will be getting the parts ready for this build. I am anxious to see if I can build a nice sub-250 gram 6 inch cruiser. Since this one doesn't have to be a heavy lifter nor a "Hi" performance craft, it will be based on 2S-4S components. I will start with my standard 3S 1100 mAh GNB battery which weighs about 70 grams. The finished dry weight of the quad will determine my final battery weight allowance. I strive to allow 100 grams for the battery so that I might run a 2S 18650 pack and larger 4S batteries, however, 75 grams will still work for me which would still allow for a 4S 660 mAh battery. Now, I need to go through my parts bin and see what I have on hand. • Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 2022-07-19 In the parts bin, I have found all of the components necessary to complete this build. I found a JHEMCU GHF405 35A AIO that was purchased before all of the chip shortages started effecting products. So...I am hoping this board will be quality and work for me without any issues. Of the motors that I could find, the BrotherHobby VY 1507 4150KV 5mm shaft motors should work fine and easily handle the 6 inch props. At this point, the frame and motors are coming in at about 100 grams. NICE. That leaves 50 grams for the electronics and props to keep the dry weight at about 150 grams. This is the goal. I have also found a Caddx Baby Ratel 2 camera that I want to try so it will be mounted first. If I like it, then I will keep it, if not, then swap it for the Foxeer Razer Nano. Since the Rescue Quad is together and awaiting testing, I will have some time to work on this build. Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 20-Jul-2022, 12:55 PM (This post was last modified: 20-Jul-2022, 01:09 PM by iFly4rotors.) In searching for alternate motors, I have just purchased a set of HGLRC Aeolus 1804 3500KV 12.7 gram T-Mount motors which are 3.8 grams lighter than the 5mm shaft BrotherHobby 1507's. Additionally, the T-Mount 6 inch bi-blade props are lighter than the 6 inch 5mm shaft props. So, this change will reduce the weight by about 20 grams. The 1804s have a little less stator volume than the 1507s, but I don't know what, if any, difference this makes. So, potentially I will have 2 motor options. Which one I end up with will depend on the weight of the electronics package, any additional plates, and any frame hardware. I really want to keep a 100 gram battery allowance, but could marginalize this to a some degree. Battery Options that are 100 grams or less: 4S 1100 mAh 16.72 wH 92 gram GNB or any 4S that is 1000 mAh or less. 3S 1550 mAh 17.67 wH 100 gram GNB or any 3S that is 1100 mAh or less. 2S 2000-3000 mAh 100 gram Li-Ion pack. {you might think this marginal; maybe it is}. As I work with this sub-250 gram 6 inch build, I am coming to the following conclusions: For a sub-250 gram build, the weight really breaks down into 3 categories: 1) Battery ........................... 100 gram allowance 2) Electronics ...................... 50 gram allowance <-- Including Action Cam 3) Frame + Drive Train ........ 100 gram allowance ---------------- 250 grams (Yeah, take 1 gram from somewhere) In reality, the only way this build is actually possible is the use of a light weight frame. Thank You, gt40, for a nice 32 gram 6 inch frame... AND Keeping the motors and props to about 15-16 grams. The total Frame, Motors, and Props needs to come in right at 100 grams...and NOT much more or you will need to compromise something else. There may be a little buffer space in the Electronics; or maybe not. I do intend to use a GPS module and I won't compromise on the VTX antenna; plus I may use a TPU whoop canopy to mount the camera. Everything counts. It will be interesting to see if I can run 7 inch props and keep the AUW less than 250 grams. The size of the props is more or less an irrelevance as long as the motors will pull them. Keep in mind the AUW is still less than 250 grams so the "load" on the Drive Train is pretty close to the same whether the build is a 3 inch or a 6 inch {or even 7 inch}. That said, the larger builds will likely be cruisers rather than Freestyle, ACRO, performers. To use heavier motors, the build needs a lighter frame {say about 20 grams} which you might get in a 3 inch frame, maybe. The battery allowance could also be reduced for an ACRO performer so that heavier motors could be used. This is why I predict that, in the sub-250 gram category, it will be the 3 to 3.5 inch quads that will be the hi-performance craft. So, now I can work on the electronics while I wait for the new motors to arrive. • Posts: 4,073 Threads: 75 Likes Received: 2,548 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 20-Jul-2022, 09:40 PM (This post was last modified: 20-Jul-2022, 09:43 PM by Lemonyleprosy.) The wider 1804’s should be more efficient and stable in the low to mid throttle range, while sacrificing some of the high end speed/power of the taller 1507’s. Slightly less stator volume will mean slightly less torque. That’s my understanding of it anyhow- I could be wrong. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 (20-Jul-2022, 09:40 PM)Lemonyleprosy Wrote: The wider 1804’s should be more efficient and stable in the low to mid throttle range, while sacrificing some of the high end speed/power of the taller 1507’s. Slightly less stator volume will mean slightly less torque. That’s my understanding of it anyhow- I could be wrong. Hi Lemony, Yep, that's pretty much how I figure it; the motors are more or less equivalent especially for the way that I fly. It will really come down to weight which I think the 1804 T-Mount motors have it over the 1507 5mm shaft ones...including props. So, if I am tight on the weight it will definitely be the ones that weigh less. On the other hand, I will consider the 1507s if I have extra allowance for it. That is, the dry weight with the 1507s is 145 grams or less. I really want this to be a sub-250 gram craft and still have 100 gram allowance for the battery. The dry weight simply can not exceed 147 grams. Yeah, that leave 2 grams margin in there. We will see how it goes. By the way, I have 6 and 7 inch props in both 5mm and T-Mount. That's right, Gemfan makes a 7 inch with they "hybrid" mount that will fit on T-Mount motors. NICE. So, I will be able to run both 6 and 7 inch props with either motor. Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 23-Jul-2022, 09:10 PM (This post was last modified: 23-Jul-2022, 09:15 PM by iFly4rotors.) 2022-07-23 The HGLRC Aeolus 1804 3500Kv motors have arrived. These T-Mount motors only weigh 12.6 grams. With a Gemfan 6 inch prop, the weight is 15.7 grams. On the other hand, the BrotherHobby 1507's with 5mm shaft weigh 15.7 alone; with a similar bi-blade prop the total is 21.8 grams. That is a 6.1 gram difference per motor/prop set. Yep, the full drive train using the 1507s with 5mm shaft is 24.4 grams more than the 1804 T-Mount set. If I use the 1804s the total drive train weight is only 62.8 grams; these and the 32 gram frame will be less than 100 grams total. Now, we are talking. That will give me a solid 50 grams for the electronics and still leave 100 gram allowance for the battery. This will also allow a little head room for the 7 inch props. I plugged a USB cable into the JHEMCU GHF405 today and NOTHING !! No lights at all. I am not even going to think about debugging at this point. Ok, so let's use the iFlight BEAST H743 55A AIO (whoop). Why not? Let's see if we can get this thing wired up and working. • Posts: 4,073 Threads: 75 Likes Received: 2,548 in 1,858 posts Likes Given: 3,949 Joined: May 2021 Reputation: 121 Man, you seem to be having a bad run with JHEMCU fc’s lately. They were my favorite brand for cost/durability. On the off chance the same thing happens with iFlight beast, maybe try a different usb cable. That is a significant amount of weight savings with the 1804’s. Dangerous operations. Disclaimer: I don’t know wtf I’m talking about. I wish I could get the smell of burnt electronics out of my nose. Posts: 5,867 Threads: 47 Likes Received: 2,779 in 2,241 posts Likes Given: 7,635 Joined: Jul 2019 Reputation: 97 (23-Jul-2022, 10:03 PM)Lemonyleprosy Wrote: Man, you seem to be having a bad run with JHEMCU fc’s lately. They were my favorite brand for cost/durability. On the off chance the same thing happens with iFlight beast, maybe try a different usb cable. That is a significant amount of weight savings with the 1804’s. Hi Lemony, Yeah, I really thought the F405s would be ok since they were bought before the chip crisis. I have had very good luck with them in the past. This is sort of FREAKING me out. It is not the USB cable. That said, I will try a different cable just to be sure. On the other hand, The BEAST fired up just fine. I am back on track. I have been wanting to use this FC, but just didn't want to put it in a small quad or whoop. Yeah, this thing would fit my Tiny-Black-85, but Man, talk about overkill. A 55A board in an 2 inch whoop. I have sort been saving it for an appropriate build. Well, I guess this is it. It seems that I am quickly clearing out my stock of FC boards. Yes, the weight difference between the 1507's and 1804's is quite significant. Using the 1804's will give me some breathing room in the weight department. A few years ago, everyone would think that I am crazy {well, maybe I am...or at least eccentric} for pairing 1804's with a 6 or 7 inch prop. However, I have come to a realization that is slightly different than "Old School" thinking. They refer to the motor not being able to spin the prop, however, this is not exactly the case. The motor will definitely spin the prop, however, the real issue is how much the motor loads trying to lift the weight of the craft...not the prop by itself...and how much acceleration power you have; how fast the motor spins up. Again, it is not just the prop, but rather the load. In the old days {of just a few years ago} a 6 or 7 inch quad weighed, what, 500-700 grams {maybe more with payload}. So the real question is how much it takes for the drive train to pull all that weight. NOW, a 6 or 7 inch quad that only weighs 150 grams dry weight is quite a different thing. The thrust requirements are quite different. It just doesn't take a bazillion pounds of thrust to lift. Plus, if you don't ask the motors to go from idle to 10,000 RPMS in 0.5 seconds, well...you just aren't loading the motor as much. The real load on the motors is what it takes to lift the quad, NOT what it takes to spin any given prop. Anyway, we are going to see how those 1804's perform... to spin or not to spin...that is the question. |
