27-Jul-2021, 12:46 AM
Review: https://oscarliang.com/holybro-kopis-freestyle-4-inch/
Not stock CLI, but the last working dump (Diff)
# Betaflight / STM32F7X2 (S7X2) 4.1.6 Apr 25 2020 / 05:12:26 (283bda8bf) MSP API: 1.42
# manufacturer_id: HBRO board_name: KAKUTEF7MINIV3 custom defaults: NO
# start the command batch
batch start
board_name KAKUTEF7MINIV3
manufacturer_id HBRO
# name: Holybro 4inch Fr
# resources
resource BEEPER 1 C08
resource MOTOR 1 B00
resource MOTOR 2 B01
resource MOTOR 3 B04
resource MOTOR 4 B05
resource MOTOR 5 B06
resource MOTOR 6 B07
resource PPM 1 A03
resource LED_STRIP 1 A08
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 A00
resource SERIAL_TX 6 C06
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 A01
resource SERIAL_RX 5 D02
resource SERIAL_RX 6 C07
resource I2C_SCL 1 B08
resource I2C_SDA 1 B09
resource LED 1 D02
resource LED 2 B04
resource LED 3 B06
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource CAMERA_CONTROL 1 B03
resource ADC_BATT 1 C00
resource ADC_RSSI 1 C02
resource ADC_CURR 1 C01
resource PINIO 1 A00
resource FLASH_CS 1 B12
resource OSD_CS 1 A15
resource GYRO_EXTI 1 A04
resource GYRO_CS 1 B02
resource USB_DETECT 1 C09
# timer
timer B04 AF2
# pin B04: TIM3 CH1 (AF2)
timer B05 AF2
# pin B05: TIM3 CH2 (AF2)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer B03 AF1
# pin B03: TIM2 CH2 (AF1)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer B07 AF2
# pin B07: TIM4 CH2 (AF2)
timer A08 AF1
# pin A08: TIM1 CH1 (AF1)
timer A03 AF3
# pin A03: TIM9 CH2 (AF3)
timer C07 AF3
# pin C07: TIM8 CH2 (AF3)
timer A02 AF1
# pin A02: TIM2 CH3 (AF1)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer E13 AF1
# pin E13: TIM1 CH3 (AF1)
timer E09 AF1
# pin E09: TIM1 CH1 (AF1)
timer E11 AF1
# pin E11: TIM1 CH2 (AF1)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer D12 AF2
# pin D12: TIM4 CH1 (AF2)
# dma
dma ADC 1 0
dma pin B04 0
dma pin B05 0
dma pin B00 0
dma pin B01 0
dma pin B03 0
dma pin B06 0
dma pin B07 0
dma pin A08 2
# pin A08: DMA2 Stream 3 Channel 6
dma pin C07 0
# pin C07: DMA2 Stream 2 Channel 0
dma pin A02 0
# pin A02: DMA1 Stream 1 Channel 3
dma pin C08 0
dma pin E13 1
# pin E13: DMA2 Stream 6 Channel 6
dma pin E09 2
# pin E09: DMA2 Stream 3 Channel 6
dma pin E11 1
# pin E11: DMA2 Stream 2 Channel 6
dma pin C09 0
dma pin D12 0
# pin D12: DMA1 Stream 0 Channel 2
feature RX_SERIAL
feature TELEMETRY
feature LED_STRIP
feature OSD
# beacon
beacon RX_SET
serial 3 1024 115200 57600 0 115200
serial 5 64 115200 57600 0 115200
led 0 4,5::C:12
led 1 5,5::C:12
led 2 6,5::C:12
led 3 7,5::C:12
led 4 8,5::C:12
led 5 9,5::C:12
aux 0 0 0 1700 2100 0 0
aux 1 1 1 1700 2100 0 0
aux 2 13 2 1700 2100 0 0
aux 3 35 2 1700 2100 0 0
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable band 3 BOSCAM_E E CUSTOM 5705 5685 5665 5645 5885 5905 5925 5945
vtxtable powerlevels 4
vtxtable powervalues 0 1 2 3
vtxtable powerlabels 25 200 500 800
# master
set acc_calibration = -7,174,-120
set mag_bustype = I2C
set mag_i2c_device = 1
set mag_hardware = NONE
set baro_bustype = I2C
set baro_i2c_device = 1
set baro_hardware = NONE
set min_check = 1010
set rssi_channel = 12
set serialrx_provider = CRSF
set blackbox_p_ratio = 64
set dshot_idle_value = 600
set dshot_burst = ON
set motor_poles = 12
set failsafe_procedure = AUTO-LAND
set vbat_warning_cell_voltage = 370
set current_meter = ADC
set battery_meter = ADC
set vbat_scale = 111
set ibata_scale = 275
set beeper_inversion = ON
set beeper_od = OFF
set beeper_dshot_beacon_tone = 3
set small_angle = 180
set gps_auto_baud = ON
set deadband = 4
set yaw_deadband = 4
set pid_process_denom = 1
set tlm_inverted = ON
set tlm_halfduplex = OFF
set osd_vbat_pos = 14756
set osd_rssi_pos = 2116
set osd_tim_1_pos = 12747
set osd_tim_2_pos = 14774
set osd_flymode_pos = 12683
set osd_current_pos = 14765
set osd_mah_drawn_pos = 2403
set osd_warnings_pos = 2345
set osd_avg_cell_voltage_pos = 2436
set debug_mode = GYRO_SCALED
set vtx_band = 4
set vtx_channel = 1
set vtx_power = 1
set vtx_low_power_disarm = ON
set vtx_freq = 5740
set max7456_spi_bus = 3
set max7456_preinit_opu = ON
set dashboard_i2c_bus = 1
set pinio_box = 40,255,255,255
set flash_spi_bus = 2
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_align_yaw = 2700
set gyro_2_spibus = 1
set name = Holybro 4inch Fr
# rateprofile 0
set roll_rc_rate = 110
set pitch_rc_rate = 110
set yaw_rc_rate = 110
set roll_expo = 7
set pitch_expo = 10
set yaw_expo = 10
set roll_srate = 72
set pitch_srate = 72
set yaw_srate = 72
# end the command batch
batch end
