Fried something on my FC, can power via USB but not battery
First build here, no prior experiences with electronics and diy at this level.
I'm using OmnibusF4 pro with built in OSD + BEC. I've soldered FS-X6B transmitter and a Matek buzzer + LED to the FC and tested + configured with USB and betaflight. I'm using a Zippy compact S3, 25c 1300mah.
For power cable, I've wired battery+ to BAT+ pad, and battery- to GND pad on the FC.
When I plug in the battery for the first time, the LED on FC lighted up briefly and then died off and then there's some smoke, thou I didn't notice where exactly it is from, too busy removing the battery.
After this point, I can no longer power the FC directly from the battery. So I tried to wired my battery directly to Matek PDB-XT60, and wired power and ground from PDB to FC. Plug in battery, the PDB LED lighted up, but nothing from the FC.
When I plug in the USB to FC, it can power up the FC and the attached FS-X6B. And if my battery is plugged in, the voltage on betaflight shows 11v, if I unplug the battery the voltage in betaflight is 2.7v.
So question is, is there any thing I can do to power my FC with the battery? or do I need to buy a new FC?
Post some pictures from both sides I may help u here!!
Regards
[Image: sdYN5sB.jpg]
Overview
[Image: ppRECj6.jpg]
FC front
[Image: nNSq9tn.jpg]
FC back
[Image: VCNnZkv.jpg]
Powered by Lipo battery
[Image: k2oM95g.jpg]
Powered by USB, somehow the FS-X6B isn't powered now...
Can you make clear pictures as close as u can front and back
P.S can you see transistor named KL3?
Regards
[Image: fapCone.jpg]
Front
[Image: NSRoU7n.jpg]
Back
Can't really get a good clear photo with my phone. Anyway, I can't find any KL3 anywhere on the board. There's several LG33, 1AM, S4, E39, B340.
More info if you need:
[Image: gEzaDHi.png]
[Image: 7galtDp.png]
Can you check this one marked in red?
(06-Jun-2017, 12:07 PM)Darozas Wrote: Can you check this one marked in red?
It's the soldering flux or something related to the solder, shiny coated surface. but I guess replacing/repairing component like this is beyond my current skill level.
Is there any way to re-configure the wiring or simple fix? If not probably the best option is to burn some cash to get a new FC.  Cry
Did you try feeding it 5V through the motor pins?
(06-Jun-2017, 09:10 PM)fftunes Wrote: Did you try feeding it 5V through the motor pins?
The motor pins? erm.. where exactly is that?
(07-Jun-2017, 03:59 AM)godzilla Wrote: The motor pins? erm.. where exactly is that?
Here
(07-Jun-2017, 08:46 AM)Darozas Wrote: Here
[Image: vavySSU.jpg]
Instant smoke from the squared area when I plug in the battery. Does it mean the end of this FC?
(07-Jun-2017, 12:44 PM)godzilla Wrote: [Image: vavySSU.jpg]
don't say you connected  direct from battery??????????????? its 5V as I stated in screen shot.
You better get new FC
Regards
(07-Jun-2017, 01:20 PM)Darozas Wrote: don't say you connected  direct from battery??????????????? its 5V as I stated in screen shot.
Regards
The battery is connected to Matek PDB, and i connected wires from the PDB GND and VCC to the FC
You should have used the 5V from the Matek.
Can you still power it with USB? I guess it is dead now...
(07-Jun-2017, 12:44 PM)godzilla Wrote: Instant smoke from the squared area when I plug in the battery. Does it mean the end of this FC?
Ahw sh...   i told you 5V Confused  think you can be pretty sure it's dead now.
  Trouble connecting taranis X-lite pro to Win 11 USB skipSSnova 7 2,320 05-May-2024, 05:46 PM
Last Post: BadRaven
  SPARKS WHEN I PLUG IN THE BATTERY JakeTheNut 14 263 01-May-2024, 06:32 PM
  Fried VTx?! cycloholic 5 183 30-Apr-2024, 01:52 PM
Last Post: cycloholic
  Best Battery Option for Build - Begginer Arkadius27 7 280 19-Mar-2024, 04:40 PM
  Smoke, Fire, and Sparks when I plug in battery NickyWicker 7 1,803 06-Mar-2024, 09:39 AM
Last Post: home003
