F4 SucceX-E F405 + TBS UNIFY PRO32 Smartaudio not working
Big Grin
Hi,
I had to replace my VTX ( I fried my T805  Angry  ). I solved the same problem in this thread https://intofpv.com/t-f4-succex-e-f405-e...e-settings
I bought TBS UNIFY PRO32 nano but I can´t get the Smartaudio to work. VTX is unlocked by pressing the button - solid blue and solid red LED is on. I also updated the VTX table (v 2.1). Smartaudio still doesn´t work and in VTX OSD menu I see only the dashes.
I also updated my FC firmware to the last version from April...
Can you help me?
diff all
# Betaflight / STM32F405 (S405) 4.1.6 Apr 25 2020 / 05:11:18 (283bda8bf) MSP API: 1.42
# manufacturer_id: FPVM   board_name: BETAFLIGHTF4   custom defaults: YES
# start the command batch
batch start
defaults nosave
board_name BETAFLIGHTF4
manufacturer_id FPVM
mcu_id 00560034594d500120303046
signature
# name: Elegant
# resources
resource MOTOR 1 C08
resource MOTOR 4 B00
feature RX_SERIAL
feature TELEMETRY
feature LED_STRIP
feature DISPLAY
# beeper
beeper -RX_LOST_LANDING
beeper -ARMING_GPS_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper -ACC_CALIBRATION
beeper -CRASH_FLIP
# map
map TAER1234
serial 2 16384 115200 57600 0 115200
serial 5 2048 115200 57600 0 115200
led 0 0,0::C:2
led 1 0,1::C:5
led 2 0,2::C:10
led 3 1,0::C:2
led 4 1,1::C:5
led 5 1,2::C:10
aux 0 0 0 1775 2100 0 0
aux 1 1 1 1300 1700 0 0
aux 2 2 1 1800 2075 0 0
# rxrange
rxrange 0 987 2011
rxrange 1 987 2011
rxrange 2 987 2011
rxrange 3 987 2011
# vtxtable
vtxtable bands 5
vtxtable channels 8
vtxtable band 1 BOSCAM_A A FACTORY    0 5845 5825 5805 5785 5765 5745    0
vtxtable band 2 BOSCAM_B B FACTORY    0 5752 5771 5790 5809 5828 5847    0
vtxtable band 3 BOSCAM_E E FACTORY    0    0    0    0    0    0    0    0
vtxtable band 4 MYBAND   M CUSTOM  5745 5769    0 5806    0 5843    0    0
vtxtable band 5 RACEBAND R FACTORY    0    0    0 5769 5806 5843    0    0
vtxtable powerlevels 3
vtxtable powervalues 14 20 26
vtxtable powerlabels 25 100 400
# master
set gyro_calib_duration = 50
set gyro_calib_noise_limit = 0
set gyro_overflow_detect = OFF
set acc_calibration = -89,34,-410
set align_mag = CW180
set mag_align_yaw = 1800
set mag_hardware = NONE
set baro_hardware = NONE
set min_check = 1030
set max_check = 2000
set serialrx_provider = FPORT
set serialrx_halfduplex = ON
set blackbox_device = SERIAL
set dshot_idle_value = 450
set failsafe_switch_mode = KILL
set current_meter = ADC
set battery_meter = ADC
set ibata_scale = 100
set 3d_deadband_throttle = 20
set small_angle = 90
set pid_process_denom = 2
set osd_vbat_pos = 2092
set osd_rssi_pos = 2103
set osd_tim_1_pos = 2359
set osd_flymode_pos = 2393
set osd_throttle_pos = 2305
set osd_crosshairs_pos = 2253
set osd_ah_sbar_pos = 2254
set osd_ah_pos = 2253
set osd_mah_drawn_pos = 2424
set osd_gps_lat_pos = 361
set osd_power_pos = 2147
set osd_warnings_pos = 14729
set osd_avg_cell_voltage_pos = 2402
set osd_core_temp_pos = 2371
set osd_stat_battery = ON
set vtx_pit_mode_freq = 5865
set vcd_video_system = NTSC
set gyro_2_sensor_align = DEFAULT
set name = Elegant
# profile 0
set i_pitch = 70
set p_roll = 41
set i_roll = 60
set p_yaw = 35
set i_yaw = 100
profile 1
# profile 1
set i_pitch = 70
set i_roll = 60
set p_yaw = 35
set i_yaw = 100
profile 2
# profile 2
set i_pitch = 70
set i_roll = 60
set p_yaw = 35
set i_yaw = 100
# rateprofile 0
set thr_expo = 15
set roll_expo = 60
set pitch_expo = 60
set yaw_expo = 60
set tpa_rate = 50
set tpa_breakpoint = 1500
set throttle_limit_type = SCALE
set throttle_limit_percent = 90
rateprofile 1
# rateprofile 1
set thr_mid = 30
set thr_expo = 15
set roll_expo = 30
set pitch_expo = 30
set yaw_expo = 30
set roll_srate = 65
set pitch_srate = 60
set yaw_srate = 65
rateprofile 2
# rateprofile 2
set thr_expo = 20
set roll_expo = 30
set pitch_expo = 30
set yaw_expo = 30
rateprofile 3
rateprofile 4
rateprofile 5
rateprofile 1
# save configuration
save
DMA
dma
dma ADC 1 1
dma pin B00 0
dma pin B01 0
dma pin C09 0
dma pin C08 0
dma pin B06 0
dma pin A09 0
dma pin A10 0
dma pin A02 0
dma pin B10 0
dma pin B11 0
# pin B11: DMA1 Stream 7 Channel 3
Make sure your TBS Unify Pro32 Nano set to use the SmartAudio protocol. I think it is set to use CRSF protocol from the factory.
See pages 4-7 in the manual linked to below to find out how to determine what protocol it is currently set to from the LED colour codes, and how to switch the protocol if you need to using the button on it.
https://www.team-blacksheep.com/tbs-unif...manual.pdf
Hi Leo, thanks for reply...
I can't get it to work, VTX is set to Sa2.1. Red blink 6 times and blue 3 times. Smartaudio is wired to TX6...
Can you please post another new full CLI dump of all your settings.
Sure...
# dump
batch start
# name: Elegant
# resources
resource BEEPER 1 B04
resource MOTOR 2 B01
resource MOTOR 3 C09
resource MOTOR 5 B06
resource MOTOR 6 NONE
resource MOTOR 7 NONE
resource MOTOR 8 NONE
resource SERVO 1 NONE
resource SERVO 2 NONE
resource SERVO 3 NONE
resource SERVO 4 NONE
resource SERVO 5 NONE
resource SERVO 6 NONE
resource SERVO 7 NONE
resource SERVO 8 NONE
resource PPM 1 B08
resource PWM 1 B08
resource PWM 2 NONE
resource PWM 3 NONE
resource PWM 4 NONE
resource PWM 5 NONE
resource PWM 6 NONE
resource PWM 7 NONE
resource PWM 8 NONE
resource SONAR_TRIGGER 1 NONE
resource SONAR_ECHO 1 NONE
resource LED_STRIP 1 B06
resource SERIAL_TX 1 A09
resource SERIAL_TX 2 A02
resource SERIAL_TX 3 B10
resource SERIAL_TX 4 NONE
resource SERIAL_TX 5 NONE
resource SERIAL_TX 6 C06
resource SERIAL_TX 7 NONE
resource SERIAL_TX 8 NONE
resource SERIAL_TX 9 NONE
resource SERIAL_TX 10 NONE
resource SERIAL_TX 11 NONE
resource SERIAL_TX 12 NONE
resource SERIAL_RX 1 A10
resource SERIAL_RX 2 A03
resource SERIAL_RX 3 B11
resource SERIAL_RX 4 NONE
resource SERIAL_RX 5 NONE
resource SERIAL_RX 6 C07
resource SERIAL_RX 7 NONE
resource SERIAL_RX 8 NONE
resource SERIAL_RX 9 NONE
resource SERIAL_RX 10 NONE
resource SERIAL_RX 11 NONE
resource SERIAL_RX 12 NONE
resource INVERTER 1 NONE
resource INVERTER 2 C13
resource INVERTER 3 NONE
resource INVERTER 4 NONE
resource INVERTER 5 NONE
resource INVERTER 6 NONE
resource INVERTER 7 NONE
resource INVERTER 8 NONE
resource INVERTER 9 NONE
resource INVERTER 10 NONE
resource INVERTER 11 NONE
resource INVERTER 12 NONE
resource I2C_SCL 1 NONE
resource I2C_SCL 2 NONE
resource I2C_SCL 3 NONE
resource I2C_SDA 1 NONE
resource I2C_SDA 2 NONE
resource I2C_SDA 3 NONE
resource LED 1 B05
resource LED 2 NONE
resource LED 3 NONE
resource RX_BIND 1 NONE
resource RX_BIND_PLUG 1 NONE
resource TRANSPONDER 1 NONE
resource SPI_SCK 1 A05
resource SPI_SCK 2 B13
resource SPI_SCK 3 C10
resource SPI_MISO 1 A06
resource SPI_MISO 2 B14
resource SPI_MISO 3 C11
resource SPI_MOSI 1 A07
resource SPI_MOSI 2 B15
resource SPI_MOSI 3 C12
resource ESCSERIAL 1 B08
resource ADC_BATT 1 C02
resource ADC_RSSI 1 NONE
resource ADC_CURR 1 C01
resource ADC_EXT 1 NONE
resource BARO_CS 1 NONE
resource BARO_EOC 1 NONE
resource BARO_XCLR 1 NONE
resource COMPASS_CS 1 NONE
resource COMPASS_EXTI 1 NONE
resource SDCARD_CS 1 NONE
resource SDCARD_DETECT 1 NONE
resource PINIO 1 NONE
resource PINIO 2 NONE
resource PINIO 3 NONE
resource PINIO 4 NONE
resource USB_MSC_PIN 1 NONE
resource FLASH_CS 1 A15
resource OSD_CS 1 B12
resource RX_SPI_CS 1 NONE
resource RX_SPI_EXTI 1 NONE
resource RX_SPI_BIND 1 NONE
resource RX_SPI_LED 1 NONE
resource GYRO_EXTI 1 C04
resource GYRO_EXTI 2 NONE
resource GYRO_CS 1 A04
resource GYRO_CS 2 NONE
resource USB_DETECT 1 C05
resource VTX_POWER 1 NONE
resource VTX_CS 1 NONE
resource VTX_DATA 1 NONE
resource VTX_CLK 1 NONE
resource PULLUP 1 NONE
resource PULLUP 2 NONE
resource PULLUP 3 NONE
resource PULLUP 4 NONE
resource PULLDOWN 1 NONE
resource PULLDOWN 2 NONE
resource PULLDOWN 3 NONE
resource PULLDOWN 4 NONE
# timer
timer B08 AF3
# pin B08: TIM10 CH1 (AF3)
timer B00 AF2
# pin B00: TIM3 CH3 (AF2)
timer B01 AF2
# pin B01: TIM3 CH4 (AF2)
timer C09 AF3
# pin C09: TIM8 CH4 (AF3)
timer C08 AF3
# pin C08: TIM8 CH3 (AF3)
timer B06 AF2
# pin B06: TIM4 CH1 (AF2)
timer A09 AF1
# pin A09: TIM1 CH2 (AF1)
timer A10 AF1
# pin A10: TIM1 CH3 (AF1)
timer A02 AF2
# pin A02: TIM5 CH3 (AF2)
timer A03 AF3
# pin A03: TIM9 CH2 (AF3)
timer B10 AF1
# pin B10: TIM2 CH3 (AF1)
timer B11 AF1
# pin B11: TIM2 CH4 (AF1)
# dma
dma SPI_TX 1 NONE
dma SPI_TX 2 NONE
dma SPI_TX 3 NONE
dma SPI_RX 1 NONE
dma SPI_RX 2 NONE
dma SPI_RX 3 NONE
dma ADC 1 1
dma ADC 2 NONE
dma ADC 3 NONE
dma UART_TX 1 NONE
dma UART_TX 2 NONE
dma UART_TX 3 NONE
dma UART_TX 4 NONE
dma UART_TX 5 NONE
dma UART_TX 6 NONE
dma UART_TX 7 NONE
dma UART_TX 8 NONE
dma UART_RX 1 NONE
dma UART_RX 2 NONE
dma UART_RX 3 NONE
dma UART_RX 4 NONE
dma UART_RX 5 NONE
dma UART_RX 6 NONE
dma UART_RX 7 NONE
dma UART_RX 8 NONE
dma pin B08 NONE
dma pin B00 0
dma pin B01 0
dma pin C09 0
dma pin C08 0
dma pin B06 0
dma pin A09 0
dma pin A10 0
dma pin A02 0
dma pin A03 NONE
dma pin B10 0
dma pin B11 0
# mixer
mixer QUADX
# servo
servo 0 1000 2000 1500 100 -1
servo 1 1000 2000 1500 100 -1
servo 2 1000 2000 1500 100 -1
servo 3 1000 2000 1500 100 -1
servo 4 1000 2000 1500 100 -1
servo 5 1000 2000 1500 100 -1
servo 6 1000 2000 1500 100 -1
servo 7 1000 2000 1500 100 -1
# servo mixer
smix reset
feature -RANGEFINDER
feature -OSD
feature -TRANSPONDER
feature -AIRMODE
feature -RX_SPI
feature -SOFTSPI
feature -ESC_SENSOR
feature -ANTI_GRAVITY
feature -DYNAMIC_FILTER
feature RX_SERIAL
feature TELEMETRY
feature LED_STRIP
feature DISPLAY
feature OSD
feature AIRMODE
feature ANTI_GRAVITY
feature DYNAMIC_FILTER
# beeper
beeper GYRO_CALIBRATED
beeper RX_LOST
beeper DISARMING
beeper ARMING
beeper ARMING_GPS_NO_FIX
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -RX_SET
beeper ACC_CALIBRATION_FAIL
beeper READY_BEEP
beeper MULTI_BEEPS
beeper DISARM_REPEAT
beeper ARMED
beeper SYSTEM_INIT
beeper ON_USB
beeper BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper CAM_CONNECTION_OPEN
beeper CAM_CONNECTION_CLOSE
beeper RC_SMOOTHING_INIT_FAIL
# beacon
beacon -RX_LOST
beacon -RX_SET
# map
map TAER1234
led 0 0,0::C:2
led 1 0,1::C:5
led 2 0,2::C:10
led 3 1,0::C:2
led 4 1,1::C:5
led 5 1,2::C:10
led 6 0,0::C:0
led 7 0,0::C:0
led 8 0,0::C:0
led 9 0,0::C:0
led 10 0,0::C:0
led 11 0,0::C:0
led 12 0,0::C:0
led 13 0,0::C:0
led 14 0,0::C:0
led 15 0,0::C:0
led 16 0,0::C:0
led 17 0,0::C:0
led 18 0,0::C:0
led 19 0,0::C:0
led 20 0,0::C:0
led 21 0,0::C:0
led 22 0,0::C:0
led 23 0,0::C:0
led 24 0,0::C:0
led 25 0,0::C:0
led 26 0,0::C:0
led 27 0,0::C:0
led 28 0,0::C:0
led 29 0,0::C:0
led 30 0,0::C:0
led 31 0,0::C:0
# color
color 0 0,0,0
color 1 0,255,255
color 2 0,0,255
color 3 30,0,255
color 4 60,0,255
color 5 90,0,255
color 6 120,0,255
color 7 150,0,255
color 8 180,0,255
color 9 210,0,255
color 10 240,0,255
color 11 270,0,255
color 12 300,0,255
color 13 330,0,255
color 14 0,0,0
color 15 0,0,0
# mode_color
mode_color 0 0 1
mode_color 0 1 11
mode_color 0 2 2
mode_color 0 3 13
mode_color 0 4 10
mode_color 0 5 3
mode_color 1 0 5
mode_color 1 1 11
mode_color 1 2 3
mode_color 1 3 13
mode_color 1 4 10
mode_color 1 5 3
mode_color 2 0 10
mode_color 2 1 11
mode_color 2 2 4
mode_color 2 3 13
mode_color 2 4 10
mode_color 2 5 3
mode_color 3 0 8
mode_color 3 1 11
mode_color 3 2 4
mode_color 3 3 13
mode_color 3 4 10
mode_color 3 5 3
mode_color 4 0 7
mode_color 4 1 11
mode_color 4 2 3
mode_color 4 3 13
mode_color 4 4 10
mode_color 4 5 3
mode_color 5 0 0
mode_color 5 1 0
mode_color 5 2 0
mode_color 5 3 0
mode_color 5 4 0
mode_color 5 5 0
mode_color 6 0 6
mode_color 6 1 10
mode_color 6 2 1
mode_color 6 3 0
mode_color 6 4 0
mode_color 6 5 2
mode_color 6 6 3
mode_color 6 7 6
mode_color 6 8 0
mode_color 6 9 0
mode_color 6 10 0
mode_color 7 0 3
aux 3 0 0 900 900 0 0
aux 4 0 0 900 900 0 0
aux 5 0 0 900 900 0 0
aux 6 0 0 900 900 0 0
aux 7 0 0 900 900 0 0
aux 8 0 0 900 900 0 0
aux 9 0 0 900 900 0 0
aux 10 0 0 900 900 0 0
aux 11 0 0 900 900 0 0
aux 12 0 0 900 900 0 0
aux 13 0 0 900 900 0 0
aux 14 0 0 900 900 0 0
aux 15 0 0 900 900 0 0
aux 16 0 0 900 900 0 0
aux 17 0 0 900 900 0 0
aux 18 0 0 900 900 0 0
aux 19 0 0 900 900 0 0
# adjrange
# rxrange
rxrange 0 987 2011
rxrange 1 987 2011
rxrange 2 987 2011
rxrange 3 987 2011
# vtxtable
vtxtable bands 5
vtxtable channels 8
# vtx
vtx 0 0 0 0 0 900 900
vtx 1 0 0 0 0 900 900
vtx 2 0 0 0 0 900 900
vtx 3 0 0 0 0 900 900
vtx 4 0 0 0 0 900 900
vtx 5 0 0 0 0 900 900
vtx 6 0 0 0 0 900 900
vtx 7 0 0 0 0 900 900
vtx 8 0 0 0 0 900 900
vtx 9 0 0 0 0 900 900
# rxfail
rxfail 0 a
rxfail 1 a
rxfail 2 a
rxfail 3 a
rxfail 4 h
rxfail 5 h
rxfail 6 h
rxfail 8 h
rxfail 9 h
# master
set gyro_sync_denom = 1
set gyro_lowpass_type = PT1
set gyro_lowpass_hz = 200
set gyro_lowpass2_type = PT1
set gyro_lowpass2_hz = 250
set gyro_notch1_hz = 0
set gyro_notch1_cutoff = 0
set gyro_notch2_hz = 0
set gyro_notch2_cutoff = 0
set gyro_offset_yaw = 0
set yaw_spin_recovery = ON
set yaw_spin_threshold = 1950
set gyro_to_use = FIRST
set dyn_notch_range = MEDIUM
set dyn_notch_q = 120
set dyn_notch_min_hz = 150
set dyn_lpf_gyro_min_hz = 200
set dyn_lpf_gyro_max_hz = 500
set acc_hardware = AUTO
set acc_lpf_hz = 10
set acc_trim_roll = 0
set mag_align_roll = 0
set mag_align_pitch = 0
set mag_bustype = I2C
set mag_i2c_device = 2
set mag_i2c_address = 0
set mag_spi_device = 0
set mag_declination = 0
set mag_calibration = 0,0,0
set baro_bustype = I2C
set baro_spi_device = 0
set baro_i2c_device = 2
set baro_i2c_address = 0
set baro_tab_size = 21
set baro_noise_lpf = 600
set baro_cf_vel = 985
set rssi_channel = 0
set rssi_scale = 100
set rssi_offset = 0
set rssi_invert = OFF
set rc_interp = AUTO
set rc_interp_ch = RPYT
set rc_interp_int = 19
set rc_smoothing_input_hz = 0
set fpv_mix_degrees = 0
set max_aux_channels = 14
set serialrx_inverted = OFF
set spektrum_sat_bind = 0
set srxl2_unit_id = 1
set srxl2_baud_fast = ON
set sbus_baud_fast = OFF
set rx_spi_bus = 0
set adc_device = 1
set blackbox_p_ratio = 32
set blackbox_record_acc = ON
set blackbox_mode = NORMAL
set min_throttle = 1070
set max_throttle = 2000
set dshot_burst = OFF
set dshot_bidir = OFF
set dshot_bitbang = AUTO
set use_unsynced_pwm = OFF
set motor_pwm_rate = 480
set motor_pwm_inversion = OFF
set motor_poles = 14
set thr_corr_value = 0
set thr_corr_angle = 800
set failsafe_delay = 4
set failsafe_off_delay = 10
set failsafe_throttle = 1000
set failsafe_procedure = DROP
set align_board_yaw = 0
set gimbal_mode = NORMAL
set bat_capacity = 0
set vbat_hysteresis = 1
set use_vbat_alerts = ON
set use_cbat_alerts = OFF
set cbat_alert_percent = 10
set vbat_cutoff_percent = 100
set vbat_lpf_period = 30
set ibat_lpf_period = 10
set vbat_scale = 110
set vbat_divider = 10
set vbat_multiplier = 1
set ibata_offset = 0
set ibatv_scale = 0
set ibatv_offset = 0
set beeper_inversion = ON
set beeper_od = OFF
set beeper_frequency = 0
set yaw_motors_reversed = OFF
set 3d_limit_low = 1000
set 3d_limit_high = 2000
set 3d_switched_mode = OFF
set servo_center_pulse = 1500
set servo_pwm_rate = 50
set servo_lowpass_hz = 0
set tri_unarmed_servo = ON
set gps_provider = NMEA
set gps_sbas_mode = AUTO
set gps_auto_config = ON
set gps_auto_baud = OFF
set gps_use_3d_speed = OFF
set gps_rescue_angle = 32
set gps_rescue_yaw_p = 40
set gps_rescue_min_sats = 8
set gps_rescue_min_dth = 100
set gps_rescue_use_mag = ON
set deadband = 0
set yaw_deadband = 0
set thrust_linear = 0
set tlm_inverted = OFF
set tlm_halfduplex = ON
set frsky_default_lat = 0
set frsky_default_long = 0
set frsky_gps_format = 0
set frsky_unit = IMPERIAL
set frsky_vfas_precision = 0
set hott_alarm_int = 5
set pid_in_tlm = OFF
set report_cell_voltage = OFF
set ledstrip_grb_rgb = GRB
set ledstrip_profile = STATUS
set sdcard_mode = OFF
set sdcard_dma = OFF
set sdcard_spi_bus = 0
set sdio_clk_bypass = OFF
set sdio_use_cache = OFF
set sdio_use_4bit_width = OFF
set osd_units = METRIC
set osd_warn_crash_flip = ON
set osd_warn_esc_fail = ON
set osd_warn_core_temp = ON
set osd_warn_fail_safe = ON
set osd_warn_rssi = OFF
set osd_rssi_alarm = 20
set osd_rssi_dbm_alarm = 60
set osd_cap_alarm = 2200
set osd_alt_alarm = 100
set osd_esc_temp_alarm = -128
set osd_esc_rpm_alarm = -1
set osd_core_temp_alarm = 70
set osd_ah_max_pit = 20
set osd_ah_max_rol = 40
set osd_ah_invert = OFF
set osd_tim1 = 2560
set osd_tim2 = 2561
set osd_rssi_dbm_pos = 234
set osd_tim_2_pos = 234
set osd_g_force_pos = 234
set osd_vtx_channel_pos = 234
set osd_current_pos = 234
set osd_motor_diag_pos = 234
set osd_craft_name_pos = 234
set osd_gps_speed_pos = 234
set osd_gps_lon_pos = 234
set osd_gps_sats_pos = 234
set osd_home_dir_pos = 234
set osd_home_dist_pos = 234
set osd_flight_dist_pos = 234
set osd_compass_bar_pos = 234
set osd_altitude_pos = 234
set osd_pid_roll_pos = 234
set osd_pid_pitch_pos = 234
set osd_pid_yaw_pos = 234
set osd_debug_pos = 234
set osd_pit_ang_pos = 234
set osd_rol_ang_pos = 234
set osd_disarmed_pos = 234
set osd_nheading_pos = 234
set osd_nvario_pos = 234
set osd_esc_tmp_pos = 234
set osd_esc_rpm_pos = 234
set osd_flip_arrow_pos = 234
set osd_log_status_pos = 234
set osd_stat_tim_1 = OFF
set osd_stat_tim_2 = ON
set osd_stat_max_spd = ON
set osd_stat_max_dist = OFF
set osd_stat_min_batt = ON
set osd_stat_endbatt = OFF
set osd_stat_min_rssi = ON
set osd_stat_max_curr = ON
set osd_stat_used_mah = ON
set osd_stat_max_alt = OFF
set osd_stat_bbox = ON
set osd_stat_bb_no = ON
set osd_stat_max_fft = OFF
set osd_stat_total_time = OFF
set osd_stat_total_dist = OFF
set osd_profile = 1
set osd_profile_1_name = -
set osd_profile_2_name = -
set osd_profile_3_name = -
set system_hse_mhz = 8
set task_statistics = ON
set debug_mode = NONE
set rate_6pos_switch = OFF
set cpu_overclock = OFF
set pwr_on_arm_grace = 5
set vtx_band = 0
set vtx_channel = 0
set vtx_power = 0
set vtx_freq = 0
set vtx_halfduplex = ON
set vtx_spi_bus = 0
set vcd_h_offset = 0
set vcd_v_offset = 0
set max7456_clock = DEFAULT
set max7456_spi_bus = 2
set max7456_preinit_opu = OFF
set frsky_spi_autobind = OFF
set frsky_spi_tx_id = 0,0
set frsky_spi_offset = 0
set frsky_x_rx_num = 0
set led_inversion = 0
set dashboard_i2c_bus = 2
set dashboard_i2c_addr = 60
set pinio_config = 1,1,1,1
set usb_hid_cdc = OFF
set usb_msc_pin_pullup = ON
set flash_spi_bus = 3
set rcdevice_feature = 0
set gyro_1_bustype = SPI
set gyro_1_spibus = 1
set gyro_1_i2cBus = 0
set gyro_1_i2c_address = 0
set gyro_1_align_roll = 0
set gyro_1_align_pitch = 0
set gyro_1_align_yaw = 1800
set gyro_2_bustype = SPI
set gyro_2_spibus = 0
set gyro_2_i2cBus = 0
set gyro_2_i2c_address = 0
set gyro_2_align_roll = 0
set gyro_2_align_pitch = 0
set gyro_2_align_yaw = 0
set i2c1_pullup = OFF
set i2c1_overclock = ON
set i2c2_pullup = OFF
set i2c2_overclock = ON
set i2c3_pullup = OFF
set i2c3_overclock = ON
set mco2_on_pc9 = OFF
set gyro_rpm_notch_q = 500
set gyro_rpm_notch_min = 100
set dterm_rpm_notch_q = 500
set dterm_rpm_notch_min = 100
set rpm_notch_lpf = 150
set flysky_spi_tx_id = 0
set stats = OFF
set stats_total_flights = 0
set stats_total_time_s = 0
set stats_total_dist_m = 0
set name = Elegant
set display_name = -
# profile 0
set profile_name = -
set dyn_lpf_dterm_min_hz = 70
set dterm_lowpass_type = PT1
set dterm_lowpass_hz = 150
set dterm_lowpass2_type = PT1
set dterm_lowpass2_hz = 150
set dterm_notch_hz = 0
set dterm_notch_cutoff = 0
set vbat_pid_gain = OFF
set pid_at_min_throttle = ON
set anti_gravity_gain = 5000
set acc_limit_yaw = 0
set acc_limit = 0
set crash_dthreshold = 50
set crash_gthreshold = 400
set crash_time = 500
set crash_delay = 0
set crash_recovery_angle = 10
set crash_recovery_rate = 100
set crash_limit_yaw = 200
set crash_recovery = OFF
set iterm_rotation = OFF
set iterm_relax = RP
set iterm_relax_cutoff = 20
set iterm_windup = 100
set iterm_limit = 400
set pidsum_limit = 500
set pidsum_limit_yaw = 400
set yaw_lowpass_hz = 0
set throttle_boost = 5
set acro_trainer_gain = 75
set p_pitch = 46
set i_pitch = 70
set d_pitch = 38
set f_pitch = 95
set p_roll = 41
set i_roll = 60
set d_roll = 35
set f_roll = 90
set p_yaw = 35
set i_yaw = 100
set d_yaw = 0
set f_yaw = 90
set angle_level_strength = 50
set horizon_transition = 75
set level_limit = 55
set horizon_tilt_effect = 75
set abs_control_gain = 0
set abs_control_limit = 90
set abs_control_cutoff = 11
set use_integrated_yaw = OFF
set d_min_roll = 20
set d_min_pitch = 22
set d_min_yaw = 0
set d_min_boost_gain = 27
set d_min_advance = 20
set motor_output_limit = 100
set launch_angle_limit = 0
set launch_control_gain = 40
set ff_interpolate_sp = AVERAGED
set ff_spike_limit = 60
set ff_max_rate_limit = 100
set ff_boost = 15
set idle_min_rpm = 0
set idle_p = 50
set idle_pid_limit = 200
set idle_max_increase = 150
rateprofile 1
# rateprofile 1
set rateprofile_name = -
set thr_mid = 30
set thr_expo = 15
set rates_type = BETAFLIGHT
set roll_rc_rate = 100
set pitch_rc_rate = 100
set yaw_rc_rate = 100
set roll_expo = 30
set pitch_expo = 30
set yaw_expo = 30
set roll_srate = 65
set yaw_srate = 65
set tpa_rate = 65
set tpa_breakpoint = 1250
set tpa_mode = D
set roll_rate_limit = 1998
set pitch_rate_limit = 1998
set yaw_rate_limit = 1998
# end the command batch
batch end
Everything looks correct to me.
Yep, all Betaflight settings look fine to me as well.
@OP - Can you please try running the following in the CLI and see if the VTX changes it's band / channel to Band B, Channel 4 (5790GHz). I just want to see if there is any communication going on at all between the flight controller and the Unify Pro32 Nano in case it is just the CMS menu that is somehow messed up.
set vtx_band = 2
set vtx_channel = 4
set vtx_power = 1
set vtx_pit_mode_freq = 0
save
No reaction at all...
In Betaflight - VTX device not ready
I´ve measured connection between Smartport and TX6 and it´s ok...
Save a "diff all" of your current settings and try re-flashing the Betaflight firmware to the FC with the "Full chip erase" switched on. Then restore your current settings again and see if doing that changes anything.
How did you fry your TX805? I'm wondering if that happening has somehow also killed UART6 on the FC.
I´ve switched 5V and BAT+ (25,2V) pin. T805 was dead in second. I needed longer wire but I didn´t look carefully.
TX1 wasn´t working at all with T805, I used your advice to move to TX6 from my previous thread and it worked. Maybe UART6 is killed too, he got 25V shot :-)
I´ll try to reflash firmware in FC.
Yes, 25V shoved into one of the UART pins on the FC won't do it any good whatsoever.
If after reflashing Betaflight it still doesn't work, we can test the Unify Pro32 Nano on UART3 instead to see if SmartAudio is actually working at all on the Nano. You would have to temporarily remove the connections for your RunCam / Caddx camera to do that and then temporarily reconfigure UART3 to be for SmartAudio.
Okay, I´ll try it...
Here´s the changelog from April, do you think the fault that caused the TX1 wasn´t working is already fixed? I didn´t find it...
Target: STM32F405
Version: 4.1.6
Binary: betaflight_4.1.6_STM32F405.hex
Date: 26-04-2020 01:44
Release notes:
Maintenance Release
Please read the Betaflight 4.1 Release Notes.
This release contains bugfixes and target changes only. For a full list of new features see 4.1.0.
We have tried to make this release as bug free as possible. If you still find a bug, please report it back to us by opening an issue here.
If you want to talk about Betaflight, ask configuration questions, or just hang out with fellow pilots, you can do this in our Facebook group.
Betaflight also has a presence in the Slack messaging platform. Register here, and then come join us in Slack. Most developers hang out there, so this is a great place to talk about the things you are tinkering with in Betaflight, or get help with really complicated configuration problems.
Safety Improvements:
fixed disabling of dynamic idle when bidirectional Dshot is not enabled (#9719, #9728);
fixed arming prevention when bidirectional Dshot is enabled but not working with bitbanged Dshot enabled (#9730).
Fixes:
added exclusion of SWD pins from being initialised as pull up if unused (#9420);
fixed bug in positioning of the OSD 'RSSI dBm' element (#9602);
added re-initialisation of mixer elements when switching PID profiles (#9608);
added missing definition of the SPI1_MOSI pin on H7 (#9610);
fixed the display of the GPS based absolute altitude before arming (#9616);
fixed the DMA options for ADC5 (#9625);
fixed lockup when battery capacity set to 0 and 'battery usage' OSD element enabled (#9644);
fixed lockup when sticks are completely centered in crash flip mode (#9647);
fixed inconsistent line endings in CLI responses (#9657);
added missing pin for I2C2 on F446 (#9662, #9695);
fixed bug potentially causing a lockup when in MSC mode (#9672);
added missing timer IRQ handlers for H7 (#9700);
fixed a bug potentially causing a lockup when using a dashboard display (#9701);
fixed inconsistency in gyroanalyse code (#9702);
fix sending of Dshot commands with 'dshotprog' in CLI (#9712);
fixed CMS over CRSF (#9720);
fixed resetting of filters when switching between PID profiles (#9723).
(01-May-2020, 11:06 PM)ericz Wrote: Here´s the changelog from April, do you think the fault that caused the TX1 wasn´t working is already fixed? I didn´t find it...
Nope. I just looked at the commit history for the BETAFLIGHTF4 unified target config and nothing has been changed in it since 2nd December 2019. The thing is, I'm not entirely sure if a shared DMA resource is permitted or not in the context of a single UART becasue I found a number of other boards with the same setup and I don't see anyone having raised any bug reports for them, which I would expect if it really was a problem. Maybe it's just down to bad iFlight FC design again. The iFlight SuccesX-E F405 flight controller seems to be a bit of an Achilles heel and ugly duckling in the FC world at the moment.
Okay.
If I find out the TX6 is killed, I would rather use TX3 for my RunCam Oscar´s edition (pretty good camera)settings. So I´ll try reflash my FC and if it doesn´t help, I´ll set VTX directly by pressing button. I don´t need change VTX settings very often. I know only one addicted pilot from my town.
Quote:The iFlight SuccesX-E F405 flight controller seems to be a bit of an Achilles heel and ugly duckling in the FC world at the moment.
Yeah, it must be sure because I´ve choosen it for my very first build  Dodgy
#15
The days that we are done with F4 FC in general, it will be a happy day.
  Help GepRc Vtx 600mW not working/ not turning on Spb2005 3 613 21-May-2024, 11:40 AM
Last Post: Spb2005
  TBS Unify Pro32 HV and SpeedyBee F405 issues Shoto 5 413 02-May-2024, 11:17 PM
  Help OSD Working but Grey Screen Caelus_fpv 4 392 25-Apr-2024, 03:14 PM
Last Post: Caelus_fpv
  Betaflight OSD not showing any information, but OSD menu is working gwennoyel 22 11,917 19-Apr-2024, 08:35 PM
Last Post: Maxym666
  TBS Fusion vs Rapidfire vs Speedybee VRX modules at same price, which is best? Luk5569 21 1,715 09-Apr-2024, 09:03 PM
Last Post: SeismicCWave
