02-Mar-2021, 05:05 AM
EVILsteve's FR7!!!
I picked up this FR7 frame sometime ago to test out some of my more serious equipment on a small platform. I quickly realized that for such a large frame there really was not enough room for the components I selected. Ive since designed a new frame more tailored to this project but this will be the prefect test platform while I get my cnc router finished up.
The specs.
FC: Matek F405 (w. barometer)
ESC: Aikon 50A esc
Motors: Emax eco 2807 1500kv
GPS: Matek M8Q-5883 (w. Compass)
VTX: TBS 2.4, Matek 1.3 (haven't decided yet)
TX: Dragonlink advanced 433mhz / mini receiver
I didn't like the captains chair camera setup or whatever its called with the fpv cam above the gopro. I kept thinking every branch Id pass would be waiting to play T-ball with my camera. I also knocked it down to 25 degrees when I redesigned the mount.
![[Image: mJKxRtxl.jpg]](https://i.imgur.com/mJKxRtxl.jpg)
![[Image: POmuJcml.jpg]](https://i.imgur.com/POmuJcml.jpg)
The camera mount is printed from TPU and the bracket assembly is PETG. Theres a groove running down the bracket and a ridge on the camera mount that fit together, RTV bonds these together, Ive used this design without issue many times before. The front screws sandwich these together on the 10mm standoffs for extra security in case of a front impact. I went through many many variations to dial in the vibration damping without being too soft or too rigid.
![[Image: fF6OAI5l.jpg]](https://i.imgur.com/fF6OAI5l.jpg)
The video system has proven to be a challenge on this build. With a Caddx Vista or DJI air unit installed the dragonlink receiver will only fit behind the camera with the antenna mounted in front of the frame in the worst place possible for long range. With a TBS 2.4 or Matek/RMRC 1.3 I am able to stack the VTX and TX in the rear and place the dragonlink antenna basically anywhere. I will probably have to give them all a fair try and see what performs best for this build.
![[Image: JdlQKUKl.jpg]](https://i.imgur.com/JdlQKUKl.jpg)
The specs.
ESC: Aikon 50A esc
![[Image: a4dIme4l.jpg]](https://i.imgur.com/a4dIme4l.jpg)
