Echine wizard 220 motor dont work
hello i buy from bangood a wizard 220 drone. yesterday i connect battery and the drone make some noise calibration i guess and then i In the controller it puts the drone to work the motors but never took off ... the fans are put in the correct way !! After several people try to help now the drone does not answer anything !! Neither the engines work and inside the drone there always appears a red light flashing ... did the same thing happen? I should have bought a cheap drone to learn, but not to spend a lot of money I was soon for a better one and now I do not know how it works. What disappointment
Thank you so much for your help and time.
Have you calibrated the accelerometer?
  • rcgomes
hello, no, frist time i try the drone make some noises and motores move, then i press trotle and fore the drone but never lift even in max RPM up!! dont dont do nothing only conect the batery make the noises and have interior red light fash and never fire up!! maby the radio? in radio options i do a factory reset and no work also. same thing never start drone
i think this was a ready to fly drone. need to conect to the computer before fly?
[Image: 16358721_1101183536659816_1758131526_n_1.jpg]
[Image: 16295267_1101184236659746_1325411122_n.jpg]
Although it's RTF, you do need to do a basic setup before you start. You need to calibrate the gyro & accel and it wouldn't hurt to calibrate the ESCs while you're at it. You'll need to download the Betaflight assistant software and as the Wizard comes pre-flashed with BF firmware, the defaults should be fine to start with. Here's a pretty decent setup guide to get you started.
https://uav-review.com/eachine-wizard-complete-guide/
  • rcgomes
  • rcgomes
thank you very much i will follow this and i will come here to tell if goes right
for conect need a special cable? the drone only comes with battery cable
you will need a micro usb cable. Same that comes with most android phones
Did you make sure that the receiver is bound?
(25-Jan-2017, 10:41 PM)Bollucks760 Wrote: Did you make sure that the receiver is bound?
 yes sir, the receiver works no problem
(25-Jan-2017, 10:56 PM)rcgomes Wrote:  yes sir, the receiver works no problem
If you want to make sure it's really bound to eliminate the possibility, you can check it in the receiver tab of betaflight configurator once you connect the drone to the computer. Here's a video for the FS-i6 in case it comes handy:
[-] The following 1 user Likes tozes's post:
  • rcgomes
(26-Jan-2017, 12:23 AM)tozes Wrote: If you want to make sure it's really bound to eliminate the possibility, you can check it in the receiver tab of betaflight configurator once you connect the drone to the computer. Here's a video for the FS-i6 in case it comes handy:
i think you have the right because we do a factory reset in the radio and i think remove the drone software maby. because in the betasoftware i can move all engines but no from radio. thank you
[-] The following 1 user Likes rcgomes's post:
  • tozes
hello! sp after a lot of videos etc i finaly conect the drone to the program. this video help me alot
my problem now is when i press litle the throttle in 25% +- and hold, the speed rises automatic. this is normal? in the betafligh in the receiver menu the throtle stay lets say in 1000/1200 but the speed rises in the drone automatic. what is the problem? because in the fly situation the drone will fly away for sure. thank you
(28-Jan-2017, 03:37 AM)rcgomes Wrote: hello! sp after a lot of videos etc i finaly conect the drone to the program. this video help me alot
Yes, this is normal when it's just sitting on the bench with no props on.  Just slap some props on and see how it flies!!  Don't worry, it won't fly away
i i end up sell the drone!!! i like to buy one Hubsan 501 now maby more easy and no need alot of programing and work right? thank you
  Motor under water Eyes.fpv 5 127 04-May-2024, 05:16 PM
  What motor to choose on 3.5" cinewhoop? Fpv_Snidde 4 261 02-May-2024, 11:21 AM
Last Post: Fpv_Snidde
  protect motor wires Eyes.fpv 12 244 01-May-2024, 09:03 AM
Last Post: Eyes.fpv
Wink 0% throttle motor dsync when flipping? mojohoojo 3 100 26-Apr-2024, 05:13 PM
Last Post: mojohoojo
  Transitioning from 4s to 6s: Motor KV and Props Relationship soldierace 9 207 25-Apr-2024, 06:45 PM
Last Post: soldierace
