Posts: 21,253 Threads: 587 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 Posts: 223 Threads: 7 Likes Received: 202 in 114 posts Likes Given: 105 Joined: Jun 2022 Reputation: 4 Will be interesting to see if there's any other features that are different from the goggles 2. I see there's diopter lenses next to the goggles? • Posts: 21,253 Threads: 587 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 (27-Mar-2023, 12:42 PM)Lukeman Wrote: Will be interesting to see if there's any other features that are different from the goggles 2. I see there's diopter lenses next to the goggles? Well if you look at the underside of the DJI Goggles Integral in the first photo there are only IPD sliders and no adjustable diopter focus knobs, so these new goggles will require physical diopter inserts to be used if you don't have 20/20 vision. A few other things to take note of: - There is no touch pad on the right-hand side but instead there is a 5-way joystick on the top like the original DJI FPV Goggles V1 & V2. You can see that in the second photo on the right-hand side peeking out from the folded down antenna.
- The micro SD Card slot and the 3.5mm audio socket on the bottom right of the goggles is missing. Maybe they have no audio capabilities and only have built in storage, or no ability to record on the goggles at all. I would also hazard a guess that the DLNA streaming is also probably missing as well, especially if there is no longer an audio output socket.
- There is a larger hump on top of the goggles in the centre with a slot in for an over-the-head strap to help counter-balance the weight of the battery inside that housing on the back of the strap. This extended hump / strap slot doesn't exist on the DJI Goggles 2.
- It's possible that LCD screens have been used in these goggles rather than OLED screens but no-one knows yet. If DJI want to get the price down then LCD screens will probably be the only real way of taking a big chunk out of the current price of the DJI Goggles 2
• Posts: 21,253 Threads: 587 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 28-Mar-2023, 06:29 PM (This post was last modified: 28-Mar-2023, 06:34 PM by SnowLeopardFPV. Edit Reason: Additional info added. ) The DJI Goggles Integral were released today. Full specs details are on the DJI website at the links below with the information also copied into this post. The price is $499, so $150 cheaper than the DJI Goggles to which are $649. DJI Wrote:Overview DJI Goggles Integra features an integrated design, adopts two 1080p Micro-OLED screens with up to 100Hz refresh rate, and supports ultra-low-latency video transmission, delivering a more immersive flight experience. - Combined for Convenience
DJI Goggles Integra combines headband and battery into one, getting rid of pesky cables. Light and compact, the goggles weigh about 410 g with foldable antennas. And with a two-hour battery life, you can fly comfortably and worry-free for extended flights. - HD Display, Stunning Colors
DJI Goggles Integra has two 1080p Micro-OLED screens to deliver true-to-life colors and highlight-shadow details. Enjoy brilliant views with a screen brightness of up to 700 nits and a refresh rate of up to 100 Hz. DJI Goggles Integra is also TÜV Rheinland Low Blue Light Certified, so you can rest assured your flight is easy on the eyes. - Ultra-Low Latency, Stable Video Transmission
DJI Goggles Integra adopts DJI O3+ video transmission, boasting latency as low as 30 ms. The goggles automatically switch frequency bands and possess strong anti-interference capabilities so that you can soar uninterrupted. - Share the Sky
Connect to the DJI Fly app and display a real-time camera view to your goggles and smartphone so you can share your view. Goggle Specifications:- Model: RCDS13
- Weight: Approx. 410 g (battery included)
- Dimensions (L×W×H): With antennas folded: 170×104×74.44 mm; With antennas unfolded: 205×104×104 mm
- Display Technology: Micro-OLED
- Screen Size (single screen): 0.49-inch
- Resolution (single screen): 1920×1080
- Refresh Rate: Up to 100 Hz
- Max Brightness: 700 nits
- IPD Range: 56-72 mm
- FOV (single screen): 44°
- Video Recording Format: MOV
- Supported Video Playback Formats: MP4, MOV (video formats: H.264, H.265; audio formats: AAC, PCM)
- Operating Temperature: -10° to 40° C (14° to 104° F)
- Power Input: Built-in battery
- Supported SD Cards:
- microSD (up to 512 GB)
- Recommended microSD Cards
- SanDisk Extreme U3 V30 A1 32GB microSDXC
- SanDisk Extreme Pro U3 V30 A1 32GB microSDXC
- Lexar 1066x U3 V30 A2 64GB microSDXC
- Lexar 1066x U3 V30 A2 128GB microSDXC
- Lexar 1066x U3 V30 A2 256GB microSDXC
- Lexar 1066x U3 V30 A2 512GB microSDXC
- Kingston Canvas Go! Plus U3 V30 A2 64GB microSDXC
- Kingston Canvas Go! Plus U3 V30 A2 128GB microSDXC
- Kingston Canvas React Plus U3 V90 A1 64GB microSDXC
- Kingston Canvas React Plus U3 V90 A1 128GB microSDXC
- Kingston Canvas React Plus U3 V90 A1 256GB microSDXC
- Samsung EVO Plus U3 V30 A2 512GB microSDXC
Video Transmission Specifications:- Video Transmission:
- When used with different aircraft, the goggles will automatically select the corresponding firmware to match the video transmission specification of the aircraft.
- DJI Avata: O3+
- Operating Frequency:
- 2.4000-2.4835 GHz
- 5.725-5.850 GHz
- The 5.8 GHz frequency band is currently banned in certain countries or regions. For details, please refer to local laws and regulations.
- Transmitter Power (EIRP):
- 2.4000-2.4835 GHz: < 30 dBm (FCC); < 20 dBm (CE/SRRC/MIC/KC)
- 5.725-5.850 GHz: < 30 dBm (FCC); < 23 dBm (SRRC); < 14 dBm (CE/KC)
- Transmission Latency:
- 1080p/100fps: as low as 30 ms
- 1080p/60fps: as low as 40 ms
- Measured in an open outdoor environment without interference. Actual data varies with different aircraft models.
- Max Transmission Distance: When used with different aircraft, the goggles will automatically select the corresponding firmware to match the video transmission specification of the aircraft.
- DJI Avata: 12 km (FCC); 6 km (CE/SRRC/MIC)
- DJI O3 Air Unit: 10 km (FCC); 2 km (CE); 6 km (SRRC)
- Measured in an open outdoor environment without interference. Actual data varies with operating environment.
- Max Video Bitrate: 50 Mbps (Measured in an open outdoor environment without interference. Actual data varies with operating environment)
Battery Specifications:- Weight: Approx. 185 g (headband included)
- Dimensions (L×W×H): 120×48.8×71 mm
- Capacity: 2450 mAh
- Voltage: 5.6-8.4 V
- Type: Li-ion
- Chemical System: LiNiMnCoO2
- Energy: 17.64 Wh
- Charging Temperature: 5° to 45° C (41° to 113° F)
- Max Charging Power: 15 W (charging when powered off)
- Operating Time: Approx. 2 hours (Measured with an ambient temperature of 25° C (77° F), screen brightness at 4, connection to DJI Avata, the video transmission mode set to 1080p/100fps, head tracking off, and the goggles' battery fully charged and not supplying power to external devices such as smartphones).
In The Box- DJI Goggles Integra × 1
- USB-C OTG Cable × 1
- DJI Goggles Integra Eyeglass Frames (Pair) × 2
- DJI Goggles Integra Corrective Lenses (Pair) × 11
- DJI Goggles Integra Top Headband × 1
- Lens Cleaning Cloth × 1
Compatibility- DJI Avata
- DJI O3 Air Unit
- DJI Motion Controller
- DJI RC Motion 2
- DJI FPV Remote Controller 2
- DJI FPV Air Unit Module
• Posts: 21,253 Threads: 587 Likes Received: 8,962 in 6,632 posts Likes Given: 1,425 Joined: Jun 2018 Reputation: 787 Here is Ian's hands-on review of the DJI Goggles Integra. One thing to note is that unlike with the DJI Goggles 2, the fold down antennas on the Intrgra goggles are NOT removeable so there will be no option for installing some different / better antennas (unless you want to start hacking up a $500 pair of goggles). You will therefore be stuck with whatever DJI have provided. Overall, with that and the built in battery these aren't very mod friendly and it seems that DJI are trying to provide a non-modular out-of-the box experience for normal run-of-the-mill consumer type users. |
