DJI 03 unit problem
Hello everyone hope I can solve this enigma together,
Recently I´ve been working on my new project an 5'' quad with a Speedybee F7 v3 stack and DJI 03 and Expresslrs, all good until this:
System in general works, comunication between Tx works, arms, angle, beeper all good. My headache comes here:
My OSD does not display info, I mean no bat, no armed status etc. I remark that drone operates properly because I´ve did a flight and in general responses ok.
Other fact is that the O3 unit shows up, that little text in right bottom side ''low power motor status'' (I´m translating lit from my language), and the speed of
transmission in between googles v2 and unit never rises up of 5/8mb.
At first I thought ok, could be a problem of general firmware upgrade, so I upgrade googles, unit, FC. Nope, kept searching and in one video saw that might be bad communication of the white wire, so there I went to spend more money on 3 in 1 connectors, but even tho trying full wire connections and DJI controler does not show info at all, obviously using Express none too.
Before all, want to to clarify that this FC and stack is for lazy people like me and has mostly all in fast connectors to reduce sodering. All UARTS are correct and the o3 preset was installed in the UART of the O3.
With all my question guys is: is the unit broken and should I claim it? Am I doing something extra wrong?
Thanks in advice.
Just a thought, as all connections are plugs, maybe a bent pin in one of the connectors and not getting a connection?
[-] The following 1 user Likes Timmyhawk 2's post:
  • ph2t
Hello Kishuke, I have the previous version DJI air unit and it has the WTF is on it however what I have learned is there are two OSDs. One is DJI, in my case bottom right and the other is Betaflights. The Betaflights setup starts at flashing a new version and in my case selecting HD osd. There are then tabs to find and selections to make in the Betaflights setup. The goggles themselves then have tabs to enable and disable OSDs. Took me a while to get my head round it all.
Sounds like msp communication is not working. The main two symptoms are low power mode never turning off when you arm and the lack of OSD.
Check out this youtube vid, may help.
https://m.youtube.com/watch?v=gQFcvDB5RC...e=youtu.be
(29-Feb-2024, 07:36 AM)ph2t Wrote: Sounds like msp communication is not working. The main two symptoms are low power mode never turning off when you arm and the lack of OSD.
Jeeeeeeeeez thank you mate !!!!! solved!
now theres only one more reminding problem I cant see battery levels, I have on sight db but not battery and the tab is on.
Video Lights.. Camera.. (DJI) Action! davejavu 14 1,315 31-May-2023, 11:26 PM
  Dji o3 vs gopro hero 6 Kanez 2 1,402 21-Apr-2023, 02:46 AM
Last Post: cali_quad
  Gopro H7B really weird problem Pekka 3 377 09-Mar-2022, 10:39 PM
Last Post: kafie1980
  Dji osmo action 2 ....modular jasperfpv 36 3,605 12-Nov-2021, 07:14 AM
Exclamation Caddx Orca and problem access Wifi Zero13 7 2,795 26-Oct-2021, 12:07 PM
Last Post: Zero13
