05-Sep-2021, 04:55 PM
I recently built a little backyard ripper around a Crazybee X on a 78mm frame, using 1102 13500kv motors with Gemfan 2023 props. It was flying fine for a while but in the middle of maybe its sixth or seventh flight it did a death spiral and now one of the ESCs appears to be done - I've swapped in a new motor but it still doesn't spin. I wasn't doing anything particularly demanding at the time it did the spiral, the OSD indicates I was drawing about 8 amps at the time. I'm wondering if this is just bad luck, or is this motor/prop combo too demanding for the board's 5-amp ESCs. Should I just replace the board, or do I need to reduce the kv of the motors?
