Posts: 932 Threads: 49 Likes Received: 192 in 157 posts Likes Given: 186 Joined: Jul 2020 Reputation: 11 18-Feb-2021, 06:18 PM (This post was last modified: 28-Mar-2021, 09:57 PM by Kevin2112.) Hello gang! Well with COVID still the big news I’m building this instead of my racer. Soooo snow and ice in south Texas! I’m sure my order for motors and camera and all the other goodies are frozen in the quantum space time continuum somewhere, cause it ain’t here! So I’m stuck inside cause idiots in TX don’t know how to drive in this , it’s so very probable someone will run into you! So this is kinda my excitement today because I’m snowed in! So this is just for fun, serious build pics to come. I should be building today but...super excited to join the LR crowd with a screamer but also a LR cruiser. This is what I have planned so far. Does anyone have any battery thoughts, like how many mah I can go? Thinking 6S but may jump it up to 7S if components will allow. Haven’t really researched that much on what size will work. Crazy snow for here! It’s not but every 40 years it gets down to 8F. @ kaitylynn this props for you. I know nothing! (Pun intended) Build specs: Armattan Chameleon 7” TI LR frame Lumenier lux F7 ultimate Lumenier 55-65 4-1 ESC TBS unify pro 32HV Frsky MXR9 OTA receiver Brother hobby avenger 2810 1500KV Foxeer T-Rex 1500TVL 1.7 camera Matek M9M-5883 GPS Various props of different pitches Green/black toxic wire braid I think the landscaping is dead fosure! Posts: 195 Threads: 28 Likes Received: 29 in 17 posts Likes Given: 22 Joined: Feb 2021 Reputation: 1 i think that you can go even over 4200mah with thease motors ;D ps nice grinder =] Posts: 1,492 Threads: 93 Likes Received: 574 in 468 posts Likes Given: 0 Joined: Nov 2020 Reputation: 27 wow. killer parts. Beast class. 2810 is huge (and heavy) for 7" Xing2 has 3106 and Kabab fpvcycle also has 310x Maybe the weak spot is the frame. Website says 4mm, 303mm and 150g. Thats not thick/strong enough. 6mm min for 7"+ or untunable frame resonance. • Posts: 932 Threads: 49 Likes Received: 192 in 157 posts Likes Given: 186 Joined: Jul 2020 Reputation: 11 Would that be more for replaceable arms? Not many frames come unibody anymore. • Posts: 932 Threads: 49 Likes Received: 192 in 157 posts Likes Given: 186 Joined: Jul 2020 Reputation: 11 28-Feb-2021, 09:59 PM (This post was last modified: 28-Mar-2021, 09:03 PM by Kevin2112.) Today just seeing how much spread I can get between the FC and ESC. The chameleon only has 22mm of headroom. Cutting it close, I’m at 20.50mm with 24mm screws. Looks like that will allow good airflow with 7.3mm between and 5.75mm off the frame. One thing I noticed with the FC is that to access the micro USB port/micro sd from the side the motor connector has to be on the outside. Not sure if I’m ok with that. If I turn it, my camera wires won’t reach! Will have to ponder on that one. Learning from my first build, just figure the height of the stack using one screw and don’t fight having all four screws in! Those little silicone spacers are tight and you could damage the board trying to slide down multiple times. This is where purchasing the extra screws and spacers really came in handy. Just temporarily mounted the motors with two screws to see how long to make the braided wire sleeves. Check to make sure the motor mount screws don’t touch windings! 8mm worked perfect with the TPU soft motor mount/arm protectors. Going with a toxic green overall look on this build, a little disappointed about the darker green and black. I thought it was going to be a little brighter green and black. I really like the heat shrink idea. Really neatens things up! Posts: 288 Threads: 56 Likes Received: 47 in 43 posts Likes Given: 13 Joined: Sep 2020 Reputation: 2 (28-Feb-2021, 09:59 PM)Kevin2112 Wrote: Today just seeing how much spread I can get between the FC and ESC. The chameleon only has 22mm of headroom. Cutting it close, I’m at 20.50mm with 24mm screws. Looks like that will allow good airflow with 7.3mm between and 5.75mm off the frame. One thing I noticed with the FC is that to access the micro USB port/micro sd from the side the motor connector has to be on the outside. Not sure if I’m ok with that. If I turn it, my camera wires won’t reach! Will have to ponder on that one. Learning from my first build, just figure the height of the stack using one screw and don’t fight having all four screws in! Those little silicone spacers are tight and you could damage the board trying to slide down multiple times. This is where purchasing the extra screws and spacers really came in handy. Just temporarily mounted the motors with two screws to see how long to make the braided wire sleeves. Check to make sure the motor mount screws don’t touch windings! 8mm worked perfect with the TPU soft motor mount/arm protectors. Going with a toxic green overall look on this build, a little disappointed about the darker green and black. I thought it was going to be a little brighter green and black. Kevin— Where at in south Texas are you? I’m in north Houston, TX and caught quite a bit of snow myself. I have a few videos but I havent posted it. Last, what do you consider Long Range? I’m curious where you plan on flying this in Texas to not have power lines and WiFi routers killing your range! • Posts: 932 Threads: 49 Likes Received: 192 in 157 posts Likes Given: 186 Joined: Jul 2020 Reputation: 11 (01-Mar-2021, 04:32 AM)luispequeno Wrote: Kevin— Where at in south Texas are you? I’m in north Houston, TX and caught quite a bit of snow myself. I have a few videos but I havent posted it. Last, what do you consider Long Range? I’m curious where you plan on flying this in Texas to not have power lines and WiFi routers killing your range! I live out near luling along 10. There’s nobody around here. I think long range is how far and what I have to walk through to get a crashed quad. I’d like to earn that 5km badge someday! I’ve not noticed even big power lines effecting the quad. My cousins got some of those couple hundred feet tall ones. I’ve never had even static in my googles from them. I’ve never had WiFi interference so don’t even know what that would appear as. • Posts: 288 Threads: 56 Likes Received: 47 in 43 posts Likes Given: 13 Joined: Sep 2020 Reputation: 2 (01-Mar-2021, 04:46 AM)Kevin2112 Wrote: I live out near luling along 10. There’s nobody around here. I think long range is how far and what I have to walk through to get a crashed quad. I’d like to earn that 5km badge someday! I’ve not noticed even big power lines effecting the quad. My cousins got some of those couple hundred feet tall ones. I’ve never had even static in my googles from them. I’ve never had WiFi interference so don’t even know what that would appear as. That’s awesome, I guess that is still South Texas..... On a diff.note I’m considering going to the hill country area (San Antonio) to find some hills and fly.... Is there anything near you similar to this? My max range has been 1.1km so far.... • Posts: 288 Threads: 56 Likes Received: 47 in 43 posts Likes Given: 13 Joined: Sep 2020 Reputation: 2 Sweet man, I will look into those place in the future. — I’m looking to drive 2-3hrs west of Houston and pull over somewhere, do a long range fly, and go back home LOL I had FPV Crate package fall off the map due to the snow storm. It shipped on 2/12 (from Florida) and arrived today, 2/28 LOL. Then I had a Rush Solo come from ProgressiveRC (from Seattle Washington) and it shipped on 2/22 and arrived yesterday 2/27. So depending where your stuff is coming from and when it left... you could have FredEX packages stuck somewhere — I would like to see videos of this 7” LR drone... it seems like it’ll be heavy, need a larger battery pack, but probably tons of thrust to carry it all. The best feature of heavy drones (from what I see/read, not from experience) is they do very well with cinematic type flying. I have 3 - 5” drones and they’re all pretty much on the heavy side.. so they fly real steady (in my opinion) — my lightest one I use to do freestyle stuff!! • Posts: 932 Threads: 49 Likes Received: 192 in 157 posts Likes Given: 186 Joined: Jul 2020 Reputation: 11 28-Mar-2021, 09:18 PM (This post was last modified: 28-Mar-2021, 09:20 PM by Kevin2112.) Posts: 932 Threads: 49 Likes Received: 192 in 157 posts Likes Given: 186 Joined: Jul 2020 Reputation: 11 28-Mar-2021, 09:53 PM (This post was last modified: 28-Mar-2021, 10:16 PM by Kevin2112.) Posts: 288 Threads: 56 Likes Received: 47 in 43 posts Likes Given: 13 Joined: Sep 2020 Reputation: 2 Is this flying yet? What size of battery did you go with? I have Emax 2807 eco ii 1500kv coming in soon — these are good for 3s-5s and I think I’m going with 4s so I can have the best flight times — I’m gonna end up playing with batteries though.. So I’m curious if you’ve done playing around w/batteries yet? • Posts: 932 Threads: 49 Likes Received: 192 in 157 posts Likes Given: 186 Joined: Jul 2020 Reputation: 11 No it’s not flying yet. It’s as far as the build pictures go. I was waiting for a piece. Now I have everything I will start to finish it. Still not sure what I’m going to do with the RX antenna and gps. Posts: 6,157 Threads: 172 Likes Received: 2,297 in 1,844 posts Likes Given: 4,753 Joined: Feb 2019 Reputation: 103 build it! :-) i like to see how the huge motors work on that frame and how it performs :-) • Posts: 5,966 Threads: 47 Likes Received: 2,798 in 2,259 posts Likes Given: 7,776 Joined: Jul 2019 Reputation: 97 Hi Kevin, GOOD LOOKING Build Very CLEAN. I like the paracord for the motor wires. Look forward to seeing the finished quad. • |
