Can't bind FS-i6x to X6B
Hi
My FlySky FS-i6x worked fine with the X6B out of the box I was able to bind. Then I decided to upgrade the firmware (to get RSSI etc). Then it wasn't working anymore.
I tried several firmwares and now installed again the original firmware.
Since I first flashed the firmware I am no longer able to bind the reciver to the Tx.
The i6x just says "RX binding .." and is stuck there.
Please help me! Thanks
It looks exactly like in this video:
i dont know a reason for your problem. probably a multiprotocol module could be a way around this software issue, could be a cheap reason.. i try bit didnt find in a short time..
I assume the video isn't yours.
What firmware did you update? Where did you source it from?
I don't think Flysky have official firmware. You are probably using an open source firmware.
Anyway, it probably doesn't matter, but the manual say to power off the B/VCC after binding.
I got the firmware from this website: https://www.flysky-cn.com/fsi6x
Currently I have the "1.0 2019-Dec-11" version installed (see website).
The binding procedure for the X6B is very simple and I tried it several times.
The procedure in the manual is for the FS-iA6.
...any other ideas?
Have you tried updating the receiver firmware? I think receiver firmware are not official, only open source.
  Help Step by step instructions for FS-X6B FS-iA10B FS-i6B Twooten39 4 859 01-May-2024, 10:01 PM
Last Post: SeismicCWave
  Tip & Trick FlySky i6X + OpenTX + ELRS + INAV screen psicho100pro 9 8,220 14-Apr-2024, 09:05 AM
Last Post: psicho100pro
  Help FrSky r xsr receiver not entering bind mode August 1 184 05-Mar-2024, 08:49 PM
Last Post: August
  ELRS Boxer Beta SPI Rx no bind husafreak 6 651 27-Oct-2023, 05:16 PM
Last Post: husafreak
  Help Receiver work but not bind to TX!HELP! ThunDezer 0 246 20-Sep-2023, 05:54 PM
Last Post: ThunDezer
