Posts: 10 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Mar 2021 Reputation: 0 Hey Everyone, At this point I had tried to bind them for 2-3 days and it didnt give me any results. I have bought Nazgul 5 with R-XSR and Jumper T-Lite for it. It is my first quad, and I have no idea what I'm doing but I have tried and I really need help to understand it. Software : R-XSR FCC ACCST 191112.frk - Receiver OpenTx Version 2.3.11 jumper (factory 84c86f71) - transmitter Not Supported Yet, so i probably can't update OpenTx. MultiProtocol Software - multi-stm-serial-Aetr-v1.3.2.30.bin Bind Procedure: 1)Push bind button on receiver, and then with pushed button connect PC Cabble to run it out. 2)Green,Blue and Red light are solid flashing. 3)From a distance +/- 1 meter i start to use bind on Transmitter Transmitter Bind Options: Type: FrSkyX SubType: D16 Bind>Ch1-8 Telem ON 4)After the transmitter stop buzzing, there is still solid Green,Blue and Red light. • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 After you try binding, and power cycle, what led lights up on the receiver? • Posts: 10 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Mar 2021 Reputation: 0 (24-Mar-2021, 02:45 AM)voodoo614 Wrote: After you try binding, and power cycle, what led lights up on the receiver? Red blinking and solid blue. • Posts: 2,331 Threads: 117 Likes Received: 809 in 657 posts Likes Given: 126 Joined: Feb 2021 Reputation: 20 Have you configured it in betaflight BEFORE you tried binding?? I’ve seen ready to fly (with rx installed) quads not have things proper in betaflight • Posts: 10 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Mar 2021 Reputation: 0 24-Mar-2021, 03:29 PM (This post was last modified: 24-Mar-2021, 03:51 PM by miudi12732.) (24-Mar-2021, 03:21 PM)Rob Axel Wrote: Have you configured it in betaflight BEFORE you tried binding?? I’ve seen ready to fly (with rx installed) quads not have things proper in betaflight No, i just run betaflight once or twice but i dont know is it configured right. Link to video with my settings: • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 (24-Mar-2021, 11:20 AM)miudi12732 Wrote: Red blinking and solid blue. Red blinking does mean you are not bound. Try the 191128 firmware on the Frsky website. • Posts: 10 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Mar 2021 Reputation: 0 (24-Mar-2021, 04:12 PM)voodoo614 Wrote: Red blinking does mean you are not bound. Try the 191128 firmware on the Frsky website. I have found only version with FPORT : RXSR-FPORT_FCC_ACCST_191128.frk ( R-XSR FCC ACCST 191112.frk comes from the same package) My receiver has 3 wires, and there shouldn't be 4 for FPORT to work? • Posts: 10 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Mar 2021 Reputation: 0 24-Mar-2021, 05:03 PM (This post was last modified: 25-Mar-2021, 07:32 PM by miudi12732.) Using RXSR-FPORT_FCC_ACCST_191128.frk, all of them still solid flashing. I have no idea what to do next. • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 Do you have a spare R-XSR to try? you might have a bad receiver. • Posts: 10 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Mar 2021 Reputation: 0 26-Mar-2021, 04:21 AM (This post was last modified: 26-Mar-2021, 04:21 AM by miudi12732.) (26-Mar-2021, 12:43 AM)voodoo614 Wrote: Do you have a spare R-XSR to try? you might have a bad receiver. Unfortunettly not, but i will propably need to buy one. • Posts: 10 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Mar 2021 Reputation: 0 I have bought new R-XSR and I still cant bind them together. Any idea? • Posts: 2,331 Threads: 117 Likes Received: 809 in 657 posts Likes Given: 126 Joined: Feb 2021 Reputation: 20 FRSKY STRIKES AGAIN!! Simple, find the biggest hammer in your tool box and... I’m just kidding.. Seriously, Frsky has updated firmware on new RXs and it is causing major frustration throughout the RC community... My solution was easy. I changed to crossfire.. • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 31-Mar-2021, 09:25 PM (This post was last modified: 31-Mar-2021, 11:45 PM by voodoo614.) (31-Mar-2021, 02:08 PM)miudi12732 Wrote: I have bought new R-XSR and I still cant bind them together. Any idea? Have you reflash the firmware. The newer receiver might have the new firmware which is not compatible. • Posts: 10 Threads: 1 Likes Received: 0 in 0 posts Likes Given: 0 Joined: Mar 2021 Reputation: 0 (31-Mar-2021, 09:25 PM)voodoo614 Wrote: Have you reflash the firmware. The newer receiver might have the new firmware which is not compatible. Sorry for long time not responding, yeah it was the first what i have done to know what version i have on it. It seems to that they cant bind together, like it was with previous one. I started to think maybe there is something bad with controller, but it should work. I had never run it without antenna, or put the battery in wrong order. • Posts: 12,099 Threads: 125 Likes Received: 3,739 in 2,836 posts Likes Given: 99 Joined: Feb 2017 Reputation: 388 I assume you don't know anyone with a radio you can test against. Might be time to contact the vendor and get a replacement radio. • |
