Bind and Arm Beta85 Pro 2 without Bind Button
I have posted some of this elsewhere. After learning about this portal, I though it a more appropriate residence for my question. Let me know if I have transgressed.
I’m trying to Bind and Arm Beta85 Pro 2s.  My TX is the ACCST model of the Taranis X9D. There is no BIND button on the 85s I have.
My Bind process for Beta85 Pro 2 is as follows:
Connected USB cable to BF on computer; then go through the process listed below:
1.      Place TX 4ft away from Quad
2.      Have TX with Bind blinking
3.      Plug USB cable from Quad into computer
4.      Select Receiver tab
5.      Click Bind receiver
6.      Click Save
7.      Press Enter on blinking Bind, then EXIT
After that process, the sliders on the Receiver tab work properly and the Arm, Mode, etc. switches work properly on the Modes tab.
Next, I disconnect, plug a battery in and throw the Arm switch.  Nothing happens.
The only difference I can detect between my Beta75Xs which do arm and fly and the Beta85 is this:
I must perform the complete BIND process every time to see any action on the 85s; whereas, on my 75Xs, plugging in a battery when connected causes sliders and switches to show action.
Question: Am I bound?  If yes, any arming suggestions?
Did you check to see if you have any Arming Disable status flags preventing it from arming?
go into the CLI of betaflight and type in "status" At the bottom it should say "Arming Disable Status Flags: xxx" What does it say there? It will tell you why it won't let you arm.
(01-Oct-2021, 07:05 PM)MrSolo Wrote: Did you check to see if you have any Arming Disable status flags preventing it from arming?
Just saw this.  I'm new to the website.  Don't know my way around.
Thanks for your response.
I have been able to bind, arm and fly.
  Help LiteRadio 3 Pro CC2500 SD Card Content? Sersandy 0 145 02-May-2024, 08:45 AM
Last Post: Sersandy
  Help FrSky r xsr receiver not entering bind mode August 1 171 05-Mar-2024, 08:49 PM
Last Post: August
  Solved Jumper T Pro - S2 switch shows as Pot in EdgeTX maxer 7 664 25-Dec-2023, 06:19 PM
  ELRS Boxer Beta SPI Rx no bind husafreak 6 629 27-Oct-2023, 05:16 PM
Last Post: husafreak
  Tango 2 Pro Throttle Issue TheFPVMoron 10 1,306 01-Oct-2023, 11:40 AM
