28-Jan-2020, 09:56 PM
Hello,
I have a Betafpv 75 pro 2. I am a beginner so usually I fly it at home in 1s. After a crash the front lens of the camera (Z02 AIO) was broken. I manage to fix it using parts from other discarded cameras, but image is not very clear, so I need to replace the camera. VTX is working fine.
I am considering buying the Caddx EOS2 micro camera and install it to the Betafpv VTX. However, that camera voltage range in the specs sheet is 3.3v to 5v and in my Betafpv tiny whoop on 1s it can go down to 3v or even 2.9 v very fast after flying 1.5-2 minutes.
Should I try with the Caddx EOS2 or try to but the original camera from BetaFPV?
Thanks
Thanks
