25-Feb-2023, 05:43 PM
Betaflight allows the OSD to be turned off by your radio. You might want to double check this is not setup under your modes tab.
Betaflight OSD not showing any information, but OSD menu is working |
25-Feb-2023, 05:43 PM Betaflight allows the OSD to be turned off by your radio. You might want to double check this is not setup under your modes tab. 25-Feb-2023, 06:32 PM (This post was last modified: 25-Feb-2023, 06:37 PM by SnowLeopardFPV. Edit Reason: Added "EDIT" line. ) (25-Feb-2023, 05:43 PM)mstc Wrote: Betaflight allows the OSD to be turned off by your radio. You might want to double check this is not setup under your modes tab. You've found the OP's issue. I completely missed the configuration of the modes. The "19" in the configuration below for aux 2 & 3 from the OP's CLI dump is for switching the OSD on and off. The OP has a weird "OR" setup for that with the default middle position configured for the OSD to be OFF. @gwennoyel - go to the Modes tab and just delete the two entries for the "OSD DISABLE SW" mode by clicking on the cross on the right-hand side. I think you will then find that your issue is fixed, thanks to @mstc. Code: # aux EDIT: Here's a visual representation of how the Modes are currently configured... 05-Mar-2023, 12:52 AM Problem Solved!!! Amazing! I didn't realize there was a second page to this forum so it took me a bit to realize I can now have all the OSD my stack supports and everything is working just fine. Can't believe how good of a trouble shooter you guys are and I really feel like it's a blessing to have such people wanting to help out. Shoutouts to SnowLeopardFPV, mstc, Sherghan, and relentlesstech Thanks again! 27-Aug-2023, 06:33 PM OMG i have the exact same setup (450 f3 stack + Speedybee TX800 VTX + Foxeer T-Rex mini ) only i have the camera control soldered to cc , and have been having the exact same issue - THIS ^^ was the issue , i just set the disable osd to some unused switch on my tx16 and now i have the full betaflight osd - still working on how to disable the FOXEER on the bottom of my screen but thats just cosmetic , the important stuff , batt voltage etc , is there now THANK YOU 28-Aug-2023, 05:21 PM (27-Aug-2023, 06:33 PM)lucindrea Wrote: OMG i have the exact same setup (450 f3 stack + Speedybee TX800 VTX + Foxeer T-Rex mini ) only i have the camera control soldered to cc , and have been having the exact same issue - THIS ^^ was the issue , i just set the disable osd to some unused switch on my tx16 and now i have the full betaflight osd - still working on how to disable the FOXEER on the bottom of my screen but thats just cosmetic , the important stuff , batt voltage etc , is there now To get rid of that Foxeer logo you need to disable it in the camera settings. You can utilise Betaflight Camera Control to access the camera menus using stick commands on your transmitter (you will need a battery plugged in to do that). It can be hit and miss, especially on non-RunCam cameras and you may need to play around with some of the camera_control_* settings in the CLI to adjust reference voltage, key delay, and internal resistance. Oscar has a good article on that HERE. If you can't get it working via Betaflight Camera Control then just get yourself a Foxeer OSD programming board to change the camera settings. There is one at the link below... https://www.foxeer.com/osd-programing-bo...cams-g-216 Hello. I have a similar problem. With Speedybee 450 f3 stack, vtx 2.5w iflight blitz, dji v2 goggles(rooted fpv wtf) with analog module, I did all the previous manipulations except multimeter, but nothing solved this problem. still no OSD. could it be the reason that I soldered the wires from the camera to controller to get a longer length? Could you plese help Привіт. У мене подібна проблема. З Speedybee 450 f3 stack, vtx 2,5w iflight blitz, окуляри v2 з аналоговим модулем, я робив усі попередні маніпуляції, крім мультиметра, але нічого не вирішило цю проблему. досі немає екранного меню 14-Apr-2024, 03:09 PM In your first image, if you are seeing the Betaflight logo overlaid, then your camera/VTX wiring is working correctly. If you have Blackbox enabled, it seems the SpeedyBee F405 V3 was poorly designed and has DMA issues, so you cannot use both blackbox and OSD at the same time, you will have to choose one. Quote:(21-Dec-2023, 11:01 AM)SnowLeopardFPV Wrote: Just a PSA if you weren't already aware, but keep in mind that the SpeedyBee F405 V3 FC is plagued with hardware design flaws. So if you have a any strange issues then it might be down to that. One particular issue is that you can't have both OSD and blackbox logging switched on at the same time due to an SPI bus conflict. If you switch on blackbox logging you will lose the OSD. Likewise, there is a DMA conflict that can cause some issues with DSHOT. SpeedyBee claim to have fixed those issues in the newer V4 version of the same FC. 19-Apr-2024, 08:35 PM Thank mstc . You are right, after removing microsd- osd works |
Help GepRc Vtx 600mW not working/ not turning on | Spb2005 | 3 | 479 | 21-May-2024, 11:40 AM Last Post: Spb2005 | |
Help OSD Working but Grey Screen | Caelus_fpv | 4 | 262 | 25-Apr-2024, 03:14 PM Last Post: Caelus_fpv | |
Help OSD Not Displaying | Victory FPV | 11 | 771 | 20-Mar-2024, 11:43 AM Last Post: Victory FPV | |
Black video but with OSD | Dexter | 6 | 308 | 08-Mar-2024, 10:42 AM Last Post: Dexter | |
Black screen and no OSD: Eachine TX06 + EV800 + DarwinFPV F411 Ultralight/Whoop AIO | aprudnikoff | 1 | 238 | 05-Mar-2024, 09:18 PM Last Post: hugnosed_bat |
