Threads: 12
Likes Received: 5 in 5 posts
Likes Given: 10
0 Hey guys. I feel like my 75x HD just wants to fall out of the air....something to do with gravity haha. What betaflight settings will get it to float more so that it can fly more like a 5" drone and I don't have to be on the throttle all the time?
Thanks!
Threads: 172
Likes Received: 2,287 in 1,834 posts
Likes Given: 4,737
100 if my interpretation is right, you can try a throttle curve. possibel on bf or on your transmitter. on the transmitter is pretty usfull to do adjustments..
Threads: 125
Likes Given: 99
388 Unfortunately there isn't any setting to make it float. Airmode or idle up is probably the closest things. You probably feel like it is dropping off more because you probably fly the 75X closer to the ground. If you fly higher, that drop off feeling will likely be less. You might also be underpowered. Not seeing the hangtime you get with the 5 inch.
