Beginner question: Radio?
Hey everyone.
All new, and looking to get into the game.
I've just bought a Tiny Whoop, for indoor practice.
But was thinking of buying a "real" radio for it, binding it - and also being able to practice through simulator.
Which should I buy?
Can I bind it to "everything"?
Does anyone have experience buying from places like "banggood" and having it shipped to Denmark?
It needs to be something I can use in the future, but also somewhat easy to configure for the simulator, which i believe im gonna spend most of my time.
Been looking at these;
FlySky fs-i6x
Taranis 7
Thanks a ton.
Simon.
i would suggest the „jumper t16 pro hall“, it has the same opensource firmware as the frsky models use; opentx. hall gimbals... it has a multiprotocoll module, possibility to comunicate with alot different protocols; frksy, spektrum, futaba, flysky... can be bind to the most usual protocolls
( https://www.team-blacksheep.com/products...er_t16_pro out of stock at the tbs store at the moment, but you will probably find it in an other store in the area of denmark)
https://m.banggood.com/da/FlySky-i6-FS-i...mds=search
for a very budget friendly option, you can do a mod and you will be able to use 10channels as the fs-i6x. i have the fs-6i in use, its very tiny and handy, i like it. but simulater wouldnt be as easy like a jumpert16pro or a qx7. you will need an extra cable.
[-] The following 2 users Like hugnosed_bat's post:
  • Krohsis, xERRR
(09-Dec-2019, 07:58 PM)hugnosed_bat Wrote: i would suggest the „jumper t16 pro hall“, it has the same opensource firmware as the frsky models use; opentx. hall gimbals... it has a multiprotocoll module, possibility to comunicate with alot different protocols; frksy, spektrum, futaba, flysky... can be bind to the most usual protocolls
Thanks!
If I "only" need a cable extra - I think the FlySky would be my choice.
Would you agree?
flsyky does have less featers and less quality parts, you can only use receivers with flysky protocoll... its a lot more limited... but it isnt bad, its very inexpensive.
the jumpert16 pro hall would give you all featers and future options, like ability for tbs crossfire module... if you can spend the money for the t16, i guess you will be happy with it in longterm use...
there is also the ergonomie, hands can be different... you need to try..
there are the frsky controllers in the „gamepad design“, or the flysky nirvana... you can take a look at them aswell.
(09-Dec-2019, 08:38 PM)hugnosed_bat Wrote: flsyky does have less featers and less quality parts, you can only use receivers with flysky protocoll... its a lot more limited... but it isnt bad, its very inexpensive.
What about something like this?
https://www.elefun.dk/p/prod.aspx?v=45587
x9d lite is a bit more modern than the qx7, it is less big than the qx7, less expensive aswell - usualy; i personaly would choose it befor the qx7, but i still own a qx7...
x9d light, you have to use frsky receivers, for a crossfire module are mods needed, no hallgimbals...
would be alot of information;
https://oscarliang.com/choose-rc-transmi...uadcopter/
(09-Dec-2019, 11:56 PM)xERRR Wrote: What about something like this?
Recently bought a x9d lite. Loving it.
I switched from fs-i6.
Depending on what receiver your "tiny whoop" has, if you get the X9 Lite, you will probably also need this:
https://www.banggood.com/URUAV-TMX5-Lite...house=GWTR
I also recommend the Jumper T16 Pro instead.  It has a built-in multiprotocol module.
You can get one here: https://hobbycool.com/collections/new-pr...ransmitter
Or here: https://shop.makerfire.com/collections/r...ransmitter
(You can check AliExpress too)
best price for Jumper T16 pro is at rcpapa.com. i have ordered a few times from them without issue. based in HK,
https://rcpapa.com/collections/multiroto...l-rc-radio
(10-Dec-2019, 09:04 AM)sloscotty Wrote: Depending on what receiver your "tiny whoop" has, if you get the X9 Lite, you will probably also need this:
What does the "multiprotocol module" mean?
Does it have the possibility to connect to more?
(10-Dec-2019, 10:00 AM)xERRR Wrote: What does the "multiprotocol module" mean?
Yes.  You can connect to many different brands of receiver, including many toy-type quads.
You can connect to spektrum, futaba, frsky, and many more.  Your "tiny whoop" may be one of these.  (In fact, whatever protocol your tiny-whoop uses, it probably can NOT be connected to the X9 Lite without a multiprotocol module.) The X9 Lite has ACCESS and ACCST-D16 protocols only without a module.
If I was to get a new radio, despite already having a QX7 like so many others around I would definitely go with a Jumper T16 Pro Hall.
As some good reviews an okay format in the hands and great "upgrade-ability".
It would help if you could provide us with a budget however most will agree that a radio is something that's bought for the long run.
(10-Dec-2019, 10:50 AM)brnmd Wrote: If I was to get a new radio, despite already having a QX7 like so many others around I would definitely go with a Jumper T16 Pro Hall.
Budget would be around 150 dollars - so i believe i've found a T16, within the budget.
I believe the possibility for it to connect to a wider range of quads and tiny whoops, would be the thing for me.
[-] The following 1 user Likes xERRR's post:
  • sloscotty
(10-Dec-2019, 12:55 PM)xERRR Wrote: Budget would be around 150 dollars - so i believe i've found a T16, within the budget.
Just be sure to get the T16 "Pro" - that's the one with the built-in module.
  Throttle control question WattsFPV 17 450 10-Jun-2024, 03:56 AM
Heart Drone Build List for Beginner martyxfly 6 2,458 07-Jun-2024, 07:59 AM
Last Post: joe.x
  What "trick" next for a beginner? KENN 7 389 05-Jun-2024, 01:53 AM
  CrossFire Connection Issues-Radio Master Zorro- No Betaflight input Apex FPV 3 261 06-May-2024, 02:35 PM
  Binding TinyHawk 3 Plus ExpressELRS/Betafpv Lite Radio 3 fpvNewbie 25 1,052 21-Apr-2024, 08:00 AM
Last Post: NewToFPV
