08-Sep-2022, 08:16 PM
OK. Continuing to learn on my Chimera 7, and my Radiomaster TX16s MAX.
I have a battery alert set for 3.7v per cell. This is giving me a voltage in Red at the bottom of my OSD when I reach about 22.2V.
I have noticed, I'm pretty sure after it happening a couple times, that when the battery voltage warning pops up in red I can no longer change modes on my receiver, for example Angle to Horizon or the opposite.
Is there some relationship between the battery alert being triggered and changing modes?
This has happened to me when I have been coming in to land in horizon and wanted to change to angle and it would not let me.
And just to test it I tried to switch from angle to horizon after it came on and it would not switch.
If there is a relationship between the warning and the modes, would it affect my failsafe or my GPS return as well. I have not been brave enough to try them when the warning is on. I still have failsafe assigned to a switch just to make sure the GPS return worked as a failsafe. Should probably remove it now that I know it works, but I do have GPS return assigned to a switch just in case I loose my goggle signal.
Mike.
Mike.
