18-Feb-2024, 11:36 AM (This post was last modified: 18-Feb-2024, 11:37 AM by Dronewhooper.)
GPS showing red in betaflight |
18-Feb-2024, 11:49 AM 18-Feb-2024, 12:13 PM A red icon means that the GPS module has a connection and is successfully communicating with the FC, but it does not have a 3D satellite fix yet. The icon will turn yellow when the GPS module gets a 3D satellite fix. You will likely need to take the quad outside where it has a clear view of the sky to get a 3D fix. 20-Feb-2024, 02:33 PM (18-Feb-2024, 12:13 PM)SnowLeopardFPV Wrote: [...] The icon will turn yellow when the GPS module gets a 3D satellite fix. You will likely need to take the quad outside [...] That's exactly how SnowLeopard says. I have the same FC and I was also concerned about the red icon, as everyone says: yellow means it's communicating with the FC, but it was red. So I flashed the BetaFlight to version 4.5 and even resoldered the GPS from UART 6 to UART 3 (which required connecting a battery pack to power the GPS module) but nothing changed. I soldered it back to UART 6 and thought it might have to get the fix to turn yellow. So, I connected the FC to the laptop, went out to the balcony, and after a minute I had a fix from 7 satellites, and the icon turned yellow. Either way, flashing BetaFlight to 4.5 was a good move. It seems to handle the GPS with the M10 chip quite well. When I took my quad for its maiden flight, it got the fix from 17 satellites in less than a minute. |
Betaflight GPS rescue with or without Magnometer? | Sir Brokalot | 6 | 1,631 | 07-Jun-2024, 09:40 PM Last Post: cycloholic | |
GPS and performance for BF RTH without barometer | Krohsis | 11 | 4,930 | 11-Apr-2024, 01:21 AM Last Post: hawk01 | |
GPS Wiring (SCL SDA) | HiThere | 22 | 16,468 | 30-Jan-2024, 12:54 PM Last Post: PeladoMat | |
Using Bigaole GL-6G-AP for GPS RTH?? | PJKMBAKER | 0 | 214 | 01-Jan-2024, 11:49 AM Last Post: PJKMBAKER | |
Help GPS - Wiring the Compass on Matek M8Q-5883 | iFly4rotors | 41 | 17,091 | 06-Sep-2023, 09:43 PM Last Post: Camilosuaz |
